Toymods » Tech & Conversions » ae86 efi tank help
SLY16V
camden
ae86 efi tank help Wed, 28 April 2004 08:29 Go to next message
heys guys,
im putting a 4age into an ae86 and i see some people on these forums talking bout efi fuel tanks for sprinter, as mine is aus spec it is obviously a carby tank, do i need a efi tank??? or can i run the aus spec tank with mods???
if this is any help i have a vl turbo pump and a surge i will be running....what else needs to be done???
all help is appreciated...
RobertoX
Re: ae86 efi tank help Wed, 28 April 2004 08:34 Go to previous messageGo to next message
you will need a fill pump that goes to the surge tank from the carby fuel tank... I recently saw some low pressure carby electric pumps for around $90, this may be suitable...(?)
Or you could mod your tank with an intank pump and baffle...
I have a 180sx turbo fuel pump for intank if you want it ($60)... would flow enough for a 4ag i think Smile
4a-c
Sutherland Shire
Re: ae86 efi tank help Wed, 28 April 2004 08:36 Go to previous messageGo to next message
Get a small electronic fuel pump, put it just above your diff. this pumps from the tank to the surge tank. after the surge tank have a small in line filter, then your vl pump, then to the engine. The hardest part in setting up your system is working out feed and return lines from the surge tank back to the main tank. if you also do a search theres heaps of info on this topic
SLY16V
camden
Re: ae86 efi tank help Wed, 28 April 2004 09:02 Go to previous messageGo to next message
sweet thanks guys...hey rob what is needed to be done in order to run that 180sx pump of yours???
shindeokure
melbourne
Re: ae86 efi tank help Wed, 28 April 2004 09:04 Go to previous messageGo to next message
get a low volume pump from an mazda fb-rx7 or 626.. or something similar.. and as 4a-c said, don't forget the efi filter.
fwiw, i think you should just do an intank setup.. i get too many raised eyebrows having mine set up in the engine bay, and there isn't much room under the car.
this is what my setup looks like:
http://members.optusnet.com.au/~shindeokure/mypic37.jpg
RobertoX
Re: ae86 efi tank help Wed, 28 April 2004 09:15 Go to previous messageGo to next message
Dont know exactly sorry, You would need somone to weld in a bracket in the tank that would hold a baffle and the pump. The top of the pump protrudes from the tank. The up side of this is you dont have to worry about externally mounting all this stuff, which I did and probably wouldnt next time. It would cost around $150-$200 to get the tank modified (although I didnt get any quotes on this...
go here to have a look at the pump:
http://www.geocities.com/robert_ae86/pump.htm
FKN16V
NSW, East Coast
Re: ae86 efi tank help Wed, 28 April 2004 09:57 Go to previous messageGo to next message
I went internal.
You'll need a vn commodore tank with the efi pump, take it and the carby sprinter tank to a metal fabrication shop and ask/get them the remove guts of one and place into the other, simple really, and it only cost me around the $275 mark.
No possibility of smells, no unnecessary efi lines, safer cleaner.
You will need to upgrade all rubber fuel hoses to efi grade hose. The standard stuff wont last long.
Steve
SLY16V
camden
Re: ae86 efi tank help Thu, 29 April 2004 13:36 Go to previous messageGo to next message
thanks for the info guys but i have a question, why cant i run the stockie fuel pump to the surge tank then the vl pump from the surge tank to the motor???
cheers guys
takai
Re: ae86 efi tank help Thu, 29 April 2004 14:32 Go to previous messageGo to next message
Cos im pretty sure the stock pump is mechanical.
RobertoX
Re: ae86 efi tank help Fri, 30 April 2004 00:31 Go to previous messageGo to next message
The mechaical fuel pump is attached to the side of your 4ac... The carby tank does not contain any pump at all...
SLY16V
camden
Re: ae86 efi tank help Fri, 30 April 2004 01:21 Go to previous messageGo to next message
oh ok i get you now, thanks for that im pretty sure what im going to use now....
takai
Re: ae86 efi tank help Fri, 30 April 2004 07:37 Go to previous messageGo to next message
Out of curiosity what do you intend to use.
Im probably going with a surge tank in the spare tyre well (if i can figure out a way of venting the well and sealing it off from the cabin) with a low pressure fill pump feeding this, and then a high pressure pump running to the engine.
SLY16V
camden
Re: ae86 efi tank help Fri, 30 April 2004 08:42 Go to previous messageGo to next message
hey mate, im going to run a 4age(for the time being) in tank pump to the surge tank then the vl turbo pump to the motor...if that fails probably build a crazy fuel tank myself with twin in tank bosch pumps and baffles into the surge tank then the vl turbo to the motor...
cheers mate
Flogbag
Sydney (Campbelltown...!)
Re: ae86 efi tank help Fri, 30 April 2004 09:32 Go to previous messageGo to next message
i have seen ppl use a battery box and put the setup in that and then seal it so no smell goes in the cabin, worked nicely
im putting a facet low pressure pump near the tank and then a surgy in the engine bay behind the drivers side headlight and then a vl pump in the line between surgy and fuel rail
the washer bottle and over flow tank get in the way so i have got a rolla tank with bracket that go next to the battery with a vr commodore over flow line as it has the 180 degree bend right after the cap so i can put it on the other side and then i have a cressida washer bottle up on the shock tower
should work nicely
i heard facet pumps pump enought to supply a V8 and vl pumps supply a 6 and the vl has the same pressure regulator releif pressure as a 4age so it should hold up ok
takai
Re: ae86 efi tank help Fri, 30 April 2004 10:13 Go to previous messageGo to next message
I guess thats another option. Im relocating the washer bottle and overflow bottles so ill have a bit of room on that side. As well as relocating the battery to the boot. So ill have coil/ignitor setup on the passenger side, and i guess i could put fuel on the drivers side.
Wouldnt want to have a crash though :S
Oh yeah, almost forgot. The problem with a sealed box is that you can get a positive pressure from the fumes and this can detonate. Hence the requirement of having a vented box. Obviously not to the cabin etiher, to the outside world.
[Updated on: Fri, 30 April 2004 10:14]
SLY16V
camden
Re: ae86 efi tank help Fri, 30 April 2004 13:05 Go to previous messageGo to next message
yeah my battery is getting relocated to the boot, im mounting the surge tank in the boot behind the plastics on the side and im not sure where im going to mount the commo pump...
cheers fellas
takai
Re: ae86 efi tank help Fri, 30 April 2004 22:43 Go to previous messageGo to next message
How are you going to vent that area?
SLY16V
camden
Re: ae86 efi tank help Sat, 01 May 2004 02:46 Go to previous message
drill some holes underneath... Rolling Eyes nah not really sure on that yet but im sure i will work something out...
chers mate
Previous Topic:quick ABS question
Next Topic:what can happen if offset is wrong?
Current Time: Wed Nov 18 21:03:17 UTC 2026
Total time taken to generate the page: 0.008368968963623 seconds
