Toymods » Tech & Conversions » 86kw + 100kw ... which ECU?
pepsicola
86kw + 100kw ... which ECU? Thu, 29 April 2004 12:18 Go to next message
I am thinking of building a engine with 86kw head and 100kw block.
I think I will use the 100kw injectors as they are bigger.
And I think I will also utilise the TVIS.
Any thoughts on which ECU I should use?
is it better to use the 86kw ECU with the 86kw injectors?
or can I use 100kw ECU with the bigger injectors?
anything else to consider?
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: 86kw + 100kw ... which ECU? Thu, 29 April 2004 12:32 Go to previous messageGo to next message
use the 100kw computer
pepsicola
Re: 86kw + 100kw ... which ECU? Thu, 29 April 2004 16:03 Go to previous messageGo to next message
yeh, i guess so.
after all i am just like,
*putting another slightly better set of cams into the 100kw.
*and port the head much larger than stock.
Scorpion
Menai area of Sydney
Re: 86kw + 100kw ... which ECU? Fri, 30 April 2004 12:09 Go to previous messageGo to next message
As far as I know, 100kw didn't come with TVIS (could be wrong - mine doesn't anyway) so the 100kw ECU won't know what TVIS is and you'll have little butterflies blocking your inlet tracts - therefore you'll have to use the 86kw ECU. I thought I saw a thread recently somewhere that said the two ECUs fire the injectors differently as well.
pepsicola
Re: 86kw + 100kw ... which ECU? Fri, 30 April 2004 14:57 Go to previous messageGo to next message
ok, what i mean was, use the 100kw on this application using the 100kw injectors on a 86kw head.
And also I am not utilising the TVIS with the 100kw ECU, but with some other device, so that when it revs to a certain point, it will open up the little butterflies.
pepsicola
Re: 86kw + 100kw ... which ECU? Sat, 01 May 2004 03:27 Go to previous messageGo to next message
here i have got another question.
i believe the 100kw coil, ignitor, and distributor is different of the ones in 86kw.
since i am using the 100kw ECU, i will be also using all these off the 100kw, will i be able to fit a 100kw distributor into a 86kw head?
EVOSTi
cambo
      no
Re: 86kw + 100kw ... which ECU? Sat, 01 May 2004 06:14 Go to previous messageGo to next message
mate just use the bigport head on the 100kw and use the 100kw manifolds. dont bother with the tvis cause then you can just use the 100kw computer with no trouble.
not sure on the distributor but im pretty sure it will fit the bigport head.
pepsicola
Re: 86kw + 100kw ... which ECU? Sun, 02 May 2004 04:27 Go to previous message
yeh, i will just disable the TVIS, and when i will enable it later with some sort of rev trigger device.
Previous Topic:2nd Gen 3sge info
Next Topic:t25 oil trouble
Current Time: Sat Oct 24 04:43:35 UTC 2026
Total time taken to generate the page: 0.0069799423217773 seconds
