Toymods » Tech & Conversions » t25 oil trouble
Ae86-Te
Tas, Australia
icon5.gif  t25 oil trouble Fri, 30 April 2004 10:39 Go to next message
hey guys..
ok, I've got a t25 from a sr20 on a 4agze, I rebuilt it (1200 bux - hybrid t28 thing)
Its been leaking oil just above the oil drain, not sure what its called, its between the two housings.
I've had it all checked out, the turbo pulled apart again and is spot on.
Its like the oil is not draining away properly and instead is squizzing out the oil seal or something!
the car is also puffing smoke when I back off after I put my foot into it... burning oil away.
Has anyone had a similar problem?
hope someone can help ..i'm out I've ideas
Brian
[Updated on: Sat, 01 May 2004 10:21]
AE86slut
Baulko Hillo
Re: t25 trouble Fri, 30 April 2004 11:03 Go to previous messageGo to next message
Sure sounds like a seal to me, but if you've had it apart and checked, that's a bit odd.
Grega
melbourne.victoria.austra...
Re: t25 trouble Fri, 30 April 2004 22:56 Go to previous messageGo to next message
brian whats the diameter of your drain pipe back to the sump?
i'd be checking to make sure the drain is not blocked, and, that its a good enough diameter to flow to the sump - also how high is the turbo mounted up - is there a long enough decent feed for gravity to drain back to the sump?
[Updated on: Fri, 30 April 2004 22:59]
Ae86-Te
Tas, Australia
Re: t25 trouble Sat, 01 May 2004 08:03 Go to previous messageGo to next message
thanx Grega, the inside diameter of the pipe to the sump is
1 1/4 inch .
the turbo is level with the camcovers,
so it should be right Rolling Eyes
could it be getting too much oil? there's no pump, just a pipe from the block in to the top of the turbo.
I took the oil drain hose off the turbo while the car was running and there was a thin constant flow of oil.. looked about 1mm thick.
Brian
CLG
Perth, Western Australia
Re: t25 trouble Sat, 01 May 2004 08:21 Go to previous messageGo to next message
Sump pressurisation, not allowing the oil to drain back. To test, crack the oil dipstick and take it for a drive, if it doesn't do it, that's the problem.
Clint
Ae86-Te
Tas, Australia
Re: t25 trouble Sat, 01 May 2004 09:03 Go to previous messageGo to next message
cool thanx again .. Cool
hopefully , ,that Sump pressurisation thing is it.. how could I fix that if it is?? just sum sort of breather!
take the dipstick completely out or just crack it?
brian.
CLG
Re: t25 trouble Sun, 02 May 2004 02:31 Go to previous message
Just crack it and wire it to something close, so it isn't pushed out.
Previous Topic:86kw + 100kw ... which ECU?
Next Topic:4AGE into AE86.
Current Time: Mon Oct 19 17:53:22 UTC 2026
Total time taken to generate the page: 0.02666187286377 seconds
