Toymods » Tech & Conversions » What a HKS 7M Metal Head Gasket Looks Like (mhg)
ed_ma61
Lost in the K hole
What a HKS 7M Metal Head Gasket Looks Like (mhg) Sat, 01 May 2004 02:28 Go to next message
ive had a few PM's lately asking about metal head gaskets (mhg) for the 7MGTE 7MGE 7M-GTE 7M-GE (yes im including all this shit so people can find this thread with the search engine)
anyway, below is a (BIG) pic (no photoshop - again!) of a HKS gasket demonstrating its laminated construction. you DO NOT use o-rings with these kinds of gaskets.
However , copper head gaskets (another kind of mhg) require orings withou question - copper is soft and maleable, and requires the extra clamping pressure around the combustion chambers provided by the orings in order not to blow
http://www4.tpg.com.au/users/loats/images/Photo31.jpg
bbaacchhyy
Re: What a HKS 7M Metal Head Gasket Looks Like (mhg) Sun, 02 May 2004 13:50 Go to previous messageGo to next message
ed_ma61 wrote on Sat, 01 May 2004 12:28
(huge ass image edited out)
Doh !!! That is why my headgasket probably doen't work !!!! It doesn't look like a PISTON !!!!
Laughing
[Updated on: Sun, 02 May 2004 14:09] by Moderator
ed_ma61
Lost in the K hole
Re: What a HKS 7M Metal Head Gasket Looks Like (mhg) Sun, 02 May 2004 14:04 Go to previous messageGo to next message
press refresh you turkey Laughing
(damn server sometimes loads stuff "closest to" the address you were looking for... that pic is .Photo36.jpg and god knows how it got confused with .Photo31.jpg)
bbaacchhyy
Re: What a HKS 7M Metal Head Gasket Looks Like (mhg) Sun, 02 May 2004 14:23 Go to previous messageGo to next message
Gobble gobble
That is much better.
As I am not going to remove and completely disassemble the engine to deck my block (unless all else fails), tyhen I wont get to see one of these puppies in the flesh Sad
Thanks anyway, it look nice ....
PS On another note. I had to machine the discs slightly and take 7mm off the back of the MS65 hubs to get sufficient clearance around the LCA and ball joint. Crying or Very Sad It was just too close otherwise. Also, the RA60 upper spring perches (on the front struts) are a different dia to the MA61 units !!
Ooorooo
Michael B
Allan
Re: What a HKS 7M Metal Head Gasket Looks Like (mhg) Sun, 02 May 2004 14:26 Go to previous messageGo to next message
Stock Gasket and ARP studs works for me, just cleaned the block with a scotchbrite thing, got the head surfaced and put it back together correctly... surfacing the block is for pain junkies
Allan
ed_ma61
Lost in the K hole
Re: What a HKS 7M Metal Head Gasket Looks Like (mhg) Sun, 02 May 2004 14:33 Go to previous messageGo to next message
bbaacchhyy wrote on Mon, 03 May 2004 00:23
any issues with the spring perch dia? i never noticed myself!! to the springs still seat ok? it doesnt come anywhere near the tyre does it?
as for the discs - that sucks. i might just stick with using the 'disposable' wilwoods until im forced to consider another option.
you couldnt just notch the LCA a little for clearance?
bbaacchhyy
Re: What a HKS 7M Metal Head Gasket Looks Like (mhg) Sun, 02 May 2004 14:42 Go to previous messageGo to next message
Nah, just used the MA61 units. (mental note - these ate the ones at the top of the struts. The lower ones are fine)
Yes it is a shit re the discs, but oh well.... The willwoods will be fine for most work, and if need be, get the heavier duty (48 curved vane I think) Wilwoods. It is just on a hrd track like Mallala that the lightweight willwoods die a quick death.
I'll get you some more pics when I get the discs and hubs back from the old man
Michael B
Whoops, hijacked the thread ...
And yes Allan, I intend using the stock gasket, good prep and ARP studs, as well as a large dose of sensibility....
cswan
icon5.gif  Re: What a HKS 7M Metal Head Gasket Looks Like (mhg) Thu, 19 May 2005 03:01 Go to previous message
Do HKS metal head gaskets require a sealant such as hylomar? I understand they are rubber coated.
Also. Can they be reused? Mine has got water and oil between the sheets because the head bolts along the exhaust side came loose. Is there a way to clean and re-use them?
Previous Topic:7MGTE Cams
Next Topic:Best 4AGE for boost?
Current Time: Sun Oct 18 17:57:05 UTC 2026
Total time taken to generate the page: 0.0058269500732422 seconds
