Toymods » Tech & Conversions » Slipping Clutch :(
wilbo666
Slipping Clutch :( Sat, 01 May 2004 09:33 Go to next message
Hey guys, the good news, I now have a manual Cressida Smile
The bad news is that I have a slipping clutch... Sad
The clutch only slips at high rpm changes, ie 1st to 2nd at 5.5k. The clutch is behind a pretty well stock 5M-E so it really shouldn't be slipping!
It is a second hand clutch, but the flywheel was surfaced, and the clutch itself looks almost perfect (when sprayed with brake cleaner you can read some writing on it, couldn't make out the brand tho). Atm I'm leaning towards the pressure plate being sus...also it was very clean when I assembled it as well so I'm pretty sure it isn't contaminated.
A picture of the condition of the parts before assembly... (soz its a bit dodge...)
http://everest.fit.qut.edu.au/~n4150414/Auto-%3eManual/Dsc00165.jpg
Any other suggestions?
takai
Re: Slipping Clutch :( Sat, 01 May 2004 09:46 Go to previous messageGo to next message
Yeah, i would be gunning for the pressure plate.
Allan
Re: Slipping Clutch :( Sat, 01 May 2004 10:10 Go to previous messageGo to next message
You have a cat stuck in it Razz
wilbo666
Re: Slipping Clutch :( Sat, 01 May 2004 10:22 Go to previous messageGo to next message
hehe please note that it was installed without the car Laughing
(note: stupid cat, well at least its on the parts car Rolling Eyes)
ps donate me a 7m Cool
people100
Rocklea qld
Re: Slipping Clutch :( Sat, 01 May 2004 10:34 Go to previous messageGo to next message
have u tried adjusting the slave cylinder. It is a fluid clutch isnt it???
mick
toowoomba qld
Re: Slipping Clutch :( Sat, 01 May 2004 10:42 Go to previous messageGo to next message
yeah mate i'd say its your pressure plate because thats what it sounds like too me
clubagreenie
1st street on the right
Re: Slipping Clutch :( Sat, 01 May 2004 10:58 Go to previous messageGo to next message
The cat isn't stuck on it. It's a cat back clutch kit!
mick
toowoomba qld
Re: Slipping Clutch :( Sat, 01 May 2004 11:02 Go to previous messageGo to next message
yeah if you stick the cat on it it will purrrr like a kittin Very Happy
7M-Brisbane
Re: Slipping Clutch :( Sat, 01 May 2004 11:45 Go to previous messageGo to next message
This will be a problem with actuation or hydraulics.
Try adjusting the pedal. Try bleeding the fluid. Also confirm that your master and slave are matched correctly and that they suit the gearbox you are using.
V8_MA61
Re: Slipping Clutch :( Sat, 01 May 2004 11:50 Go to previous messageGo to next message
yeah its weird as they used to work PERFECT on my ma61 Confused
clubagreenie
Re: Slipping Clutch :( Sat, 01 May 2004 11:57 Go to previous messageGo to next message
It'll also have less emissions, always land feet down and require the occasional hairball to be removed from the a/c vents
7M-Brisbane
Re: Slipping Clutch :( Sat, 01 May 2004 12:11 Go to previous messageGo to next message
I still think it will be one of those things... if this complete combo worked on your supra and the adjustment etc have not been changed, then I'd suggest a bleeding will fix it. Also in the time that the cylinders were dry one of the seals may have given way...
Matt-AE86
Re: Slipping Clutch :( Sat, 01 May 2004 23:11 Go to previous messageGo to next message
Allan wrote on Sat, 01 May 2004 18:10
lol, i was about to state the same problem, "maybe the cat isnt helping it ?"
hehehe.
Fruitloop
Re: Slipping Clutch :( Sat, 01 May 2004 23:36 Go to previous messageGo to next message
The pressure plate looks "Suss" to me..(damaged,marked,missing a rivet) Get a new 1 and it may be purrrfect..
wilbo666
Re: Slipping Clutch :( Sun, 02 May 2004 00:39 Go to previous messageGo to next message
The slave and master are off a SA63 celica (I believe them to be identical to MA61 units tho, can anyone confirm?)
I have tried adjusting the pedal so that I am sure that it is keeping no residual pressure on the pressure plate when released.....on difference, might try bleeding again, can't hurt.
I'd rather explore every option first! (not a fan of taking out gearboxes)
Thanks guys.
btw where abouts do you live in brissy 7M-Brisbane?
Fattony
Re: Slipping Clutch :( Sun, 02 May 2004 02:52 Go to previous messageGo to next message
Meow!!!
wilbo666
Re: Slipping Clutch :( Sun, 02 May 2004 04:27 Go to previous messageGo to next message
Hmm fantastic, looks like the front gearbox seal is gone (actually went and looked at the bottom of the gearbox) Sad ( I suspect the gasket, I replaced the seal, and made a new gasket but looks like it didn't seal correctly, bugger Confused)
So hopefully I'll drop it all out, make a new gasket and clean everything and it will all be tops, can't wait, so excited......
thanks guys, you've been heaps of help!
ps meowwwww
wilbo666
Re: Slipping Clutch :( Wed, 05 May 2004 00:44 Go to previous messageGo to next message
hmm, FUCK. The front GB seal hadn't seated properly (looked like it had crimped over instead of sliding on a sealing properly).
So I replaced that again, after a short drive (to work, where I currently am Razz) it appears to not be leaking (no oil visible, and nothing can be felt/seen if the clutch for cover is removed)
The bad news is that it is still slipping (worse than before even...)! I cleaned everything VERY well, I washed everything with dawn and water, let it dry and then hit everything with brake cleaner, and then wiped off and hit again with brake cleaner.
GRRRRRRRRRRR so angry! If there is some oil contamination, is it possible it will just burn it off? Confused
RWDboy
Re: Slipping Clutch :( Wed, 05 May 2004 01:54 Go to previous messageGo to next message
Have you noticed any shudder/vibration through the pedal while you lift off the clutch?
Allan
Re: Slipping Clutch :( Wed, 05 May 2004 01:55 Go to previous messageGo to next message
Put an auto in Razz
hehehehehhe
Allan
Re: Slipping Clutch :( Wed, 05 May 2004 02:59 Go to previous messageGo to next message
Allan wrote on Wed, 05 May 2004 09:55
Put an auto in Razz
hehehehehhe
Allan
Why take such a retrograde step? Jeesus dude, a 5ME is bad enough, let alone behind an auto, let the boy have some fun!
wilbo666
Re: Slipping Clutch :( Wed, 05 May 2004 06:21 Go to previous message
Allan wrote on Wed, 05 May 2004 11:55
Put an auto in Razz
hehehehehhe
Allan
Lol, umm no! (the manual conversion has totally transformed the car!)
FWDboy: nope, no shudder etc, the clutch works fine, except for slipping some times, have to wait and see if it goes away Confused (does seem to be getting a little better, hard to tell tho, might be me convincing myself)
Previous Topic:4ag cold starting & poor spark
Next Topic:1UZ electrical issue
Current Time: Thu Nov 19 03:31:28 UTC 2026
Total time taken to generate the page: 0.0061979293823242 seconds
