Toymods » Tech & Conversions » W series gearboxes
Bugman
W series gearboxes Sat, 01 May 2004 16:21 Go to next message
Just a quick question
out of the w series gearboxs. only the w50 has the slave cylinder on the drivers side right?
Fruitloop
Re: W series gearboxes Sat, 01 May 2004 21:31 Go to previous messageGo to next message
My 65 has it on the drivers side (W55)
STR8 2.8
Re: W series gearboxes Sat, 01 May 2004 22:58 Go to previous messageGo to next message
both w57 & w58's have it on the pass. side
so mayb its just those two then
YelloRolla
On your mum!
Re: W series gearboxes Sat, 01 May 2004 23:50 Go to previous messageGo to next message
I have a W58 with the slave cylinder on the drivers side. It is the original unit from the 3T GTE, and I think that I seen another like it at SSS yesterday. The other 2 x 58s that I have both have them on the passenger side.
wilbo666
Re: W series gearboxes Sun, 02 May 2004 00:23 Go to previous messageGo to next message
The bellhousing is the deciding factor.
Depends what motor you want to put the W5X behind as whether there is a bellhousing to suit....
Some info I know,
MA61 (5M-E -> W58) passenger side
SA63 (2S-C -> W55) passenger side
GA70 (1G-GTE -> W58) passenger side
Bugman
Re: W series gearboxes Sun, 02 May 2004 02:19 Go to previous messageGo to next message
just pulled the gearbox out of rt142 to find it's on the drivers side.. I'll guess I'll just see if my 1g to w58 bellhousing fits.
ra23celica
Re: W series gearboxes Mon, 03 May 2004 01:20 Go to previous messageGo to next message
There is no real rule of thumb here, it is bellhousing dependent.
And, I would not worry about it too much, as you can alway bend your clutch line over to the other side to reach it.
Mitch.
Bugman
Re: W series gearboxes Mon, 03 May 2004 04:25 Go to previous messageGo to next message
oh what am i thinking.. ofcourse its part of the bellhousing.. god im a dick.
ok. anyone know the way to tell the w series gboxs apart?
wilbo666
Re: W series gearboxes Mon, 03 May 2004 04:29 Go to previous messageGo to next message
W58's (for the most part, some did come with alloy sandwich plates!) can be differentiated by the steel sandwich plate (do a search, a few pics to be found).
Otherwise, count turns of the inputs shaft / turns of the output shaft turns in the gears to work out the ratios... Confused
ra23celica
Re: W series gearboxes Mon, 03 May 2004 05:57 Go to previous messageGo to next message
Do a search / check the stickys, this questions has been asked and answered a *few* times before.
Mitch.
Bugman
Re: W series gearboxes Mon, 03 May 2004 07:51 Go to previous messageGo to next message
I did but the problem remains of differentiating between a w55 and 57.
Re: W series gearboxes Mon, 03 May 2004 10:08 Go to previous messageGo to next message
Turning the shafts is about the only way I can think of being able to find it out.
Jonny2TG
Tasmania
Re: W series gearboxes Mon, 03 May 2004 10:57 Go to previous messageGo to next message
As a side note, a think the G series gearboxs are the same as the W also. eg, G52 etc in Hilux's and HiAce, early Tarago. You use the same repair manual for the G as the W series gearboxs. I have not found the difference yet. Some new HiLux's have a W56, others a G55 etc.
Re: W series gearboxes Mon, 03 May 2004 11:12 Go to previous messageGo to next message
Don't the G series boxes have different linkages though, ie for column shift?
Jonny2TG
Tasmania
Re: W series gearboxes Mon, 03 May 2004 13:15 Go to previous messageGo to next message
Some do some don't. HiLux always have the stick coming out the top of the box, Hiace and Tarago have linkages from the side of the box. I have not worked out the corelation yet.
Steve_Reynolds
Gold Coast
Re: W series gearboxes Tue, 04 May 2004 00:24 Go to previous messageGo to next message
My Hilux 5 speed floor shift has the G52 box. Does anyone know what the individual gear ratio's inside the G52 are???
[Updated on: Tue, 04 May 2004 00:25]
Re: W series gearboxes Tue, 04 May 2004 00:29 Go to previous message
Steve, if you believe Matti and Helene's website, here they are:
G52 R 4.743: First 3.928: Second 2.333: Third 1.451: Fourth 1: Fifth 0.851.
PS got money! Cheers.
Previous Topic:need help with a pod filter on a 4age
Next Topic:have oppurtunity to get a cheap 5 speed from an n/a 2jz supra
Current Time: Wed Nov 25 02:00:34 UTC 2026
Total time taken to generate the page: 0.097988128662109 seconds
