Toymods » Tech & Conversions » strengh of rzsupra autobox
robs
nz
strengh of rzsupra autobox Sun, 02 May 2004 09:28 Go to next message
after reading the recent zoom 2jz tuning guide id like to kwow wat the strengh of the rz a340 trans wat rwkw are they knwn to handle reliably ??? hopin round 280 rwkw
7M-Brisbane
Re: strengh of rzsupra autobox Sun, 02 May 2004 10:30 Go to previous messageGo to next message
Hi
I had one of these autos in my Supra and it was fantastic fun off the line. I converted it to manual, but now that I'm building a project car I'm using the 1JZ with the same auto box behind it.
You shouldn't experience any problems at this kind of power level. To my knowledge these are fundamentally the same A-series automatic gearbox Toyota has been making for 30 years and used across the majority of their model range (RWD ones, at least).
To support these kind of power levels I reliably would suggest that you should do the following:
* clean the filter (believe these are a metal one you wash rather than a consumable item)
* flush entire box & torque converter with new fluid
* have the valve body modified for firmer shifts (MV Autos in Adelaide do it for ~$400 exchange, unsure if you have anyone local)
* fit an upgraded fluid cooler
Many people would recommend a larger stall, however I assume with these power levels you will be retaining the standard turbos. In this situation it should get off the line quickly with a minimum of fuss!
If you go for a bigger turbo later, you can have the stall modified and the box itself built (again, MV can provide this service).
Hope this is of some use.
Leigh
[Updated on: Sun, 02 May 2004 10:33]
robs
nz
Re: strengh of rzsupra autobox Mon, 03 May 2004 09:19 Go to previous message
thanks sounds like it may do it ok the 6spd is so exspensive my car is 1jz mk3 but exstensively modified big single cams ect jst need sumin stng enough thanks 4 info
Previous Topic:technical distributor question
Next Topic:AE86 drivers door movement in hinge (rebuild kits?)
Current Time: Fri Oct 23 16:34:32 UTC 2026
Total time taken to generate the page: 0.0050508975982666 seconds
