Toymods » Tech & Conversions » urgent help for 1g motor
ymyars
urgent help for 1g motor Sun, 02 May 2004 11:05 Go to next message
ijust got my exhaust done and i have replace the twin turbo with a single turbo.
i want to drive it home but not sure how to connect the two hose that disconnect from the original twin turbo set up.
as i understand that the hose from the rocket i can just replace it with a filter (correct me if im wrong)
then i have another line which is connect that to the inlet manifold,
i believe that that line need to be connected between the inlet housing and the airflow meter.
but then my nephew said that i can leave it disconnected with just a filter on it,
is that correct?
any info would be great
thanx
ymyars
Re: urgent help for 1g motor Sun, 02 May 2004 12:55 Go to previous messageGo to next message
should i connect that line from the inlet housing to the air intake of the turbo or leave it out
any suggestion
gold28
Madrid - Spain
Re: urgent help for 1g motor Mon, 03 May 2004 00:16 Go to previous messageGo to next message
If you are still running the standard computer, then it won't run without the air flow meter. It needs to be connected to the centre part of the compressor side of the turbo.
I think thats what your asking anyway.
indian
south east - melbourne
Re: urgent help for 1g motor Mon, 03 May 2004 00:55 Go to previous message
whatever u do
the black hose after the afm and before the turbo that goes to the rocker cover has to be plugged in otherwise the car wont start / run Smile
Previous Topic:4a-ge into KE20
Next Topic:Moving Stripped Cars Around
Current Time: Fri Oct 23 12:45:41 UTC 2026
Total time taken to generate the page: 0.0044090747833252 seconds
