Toymods » Tech & Conversions » how to cut a 3mm deep 1.5mm wide channel in rubber?
how to cut a 3mm deep 1.5mm wide channel in rubber? Mon, 03 May 2004 04:13 Go to next message
to finish my radiator, I need to cut a channel of the above dimensions in some 6mm thick rubber.
Ideally I'd use a router I guess, but I dont have one. I'm considering tracing the channel with a knife, then following the line with a drill - but as it's so narrow and the rubber is fairly firm, I'm worried about breaking the drill bit (and I've broken a few drill bits in my time attempting to use them as router pieces)
any other ideas?
Jason
Re: how to cut a 3mm deep 1.5mm wide channel in rubber? Mon, 03 May 2004 04:18 Go to previous messageGo to next message
What about a die-grinder with a really agressive bit in it and use that as a sort of router?
munki
Gold Coast
Re: how to cut a 3mm deep 1.5mm wide channel in rubber? Mon, 03 May 2004 04:49 Go to previous messageGo to next message
hire a router? how about a angle grinder with a cutting disc?
Ben Wilson
Re: how to cut a 3mm deep 1.5mm wide channel in rubber? Mon, 03 May 2004 05:19 Go to previous messageGo to next message
You might be able to get a dremel bit about the right size and use that in your drill.
Re: how to cut a 3mm deep 1.5mm wide channel in rubber? Mon, 03 May 2004 06:58 Go to previous messageGo to next message
hmmm - will try the angle grinder for the long straight bits.
thanks for the ideas guys Smile
YelloRolla
On your mum!
Re: how to cut a 3mm deep 1.5mm wide channel in rubber? Mon, 03 May 2004 07:02 Go to previous messageGo to next message
A small wad puch in the drill and then "stitch" drill the holes works well.(P.S this is best done in a drill press)
Re: how to cut a 3mm deep 1.5mm wide channel in rubber? Mon, 03 May 2004 07:48 Go to previous messageGo to next message
if I had a drill press... Razz
YelloRolla
On your mum!
Re: how to cut a 3mm deep 1.5mm wide channel in rubber? Mon, 03 May 2004 07:50 Go to previous messageGo to next message
get one dammit! OR use somebody elses.
ChuckLandwehr
Re: how to cut a 3mm deep 1.5mm wide channel in rubber? Mon, 03 May 2004 10:14 Go to previous messageGo to next message
Draven, in the late 50's early 60's I watched a guy re-groove the tyres on Dad's Hillman Minx! Picture this, a heavy duty soldering iron, with a steel hoop attached at the hot end. Get the iron hot, and push this tool into the rubber, follow the original tread pattern. I haven't seen one of these in years!, but some of the circuit race teams use this tool to turn slicks into intermediates! Perhaps an enterprising lad such as yourself, might be able to construct a suitable tip for a large soldering iron.
Regards Chuck.
Re: how to cut a 3mm deep 1.5mm wide channel in rubber? Mon, 03 May 2004 10:22 Go to previous messageGo to next message
mmmmm.....
tempting
but I only have 2 soldering irons... a good one, and a better one Razz
kaos
South West Sydney
Re: how to cut a 3mm deep 1.5mm wide channel in rubber? Mon, 03 May 2004 11:36 Go to previous message
You could try a motorsport tyre supplier to use a tyre groover to do it. The use them to cut slicks and adjust rally tyres.
Tim
Previous Topic:Toyota 1200 ute engine conversion
Next Topic:reverse in a TA22
Current Time: Sun Oct 18 17:53:06 UTC 2026
Total time taken to generate the page: 0.061846017837524 seconds
