Toymods » Tech & Conversions » How to fix your AE86 dash lights...
Henn
Rosanna, Melb
How to fix your AE86 dash lights... Mon, 03 May 2004 13:57 Go to next message
For all your guys out there driving without your speedo, and more importantly your tacho, at night.
Got mine working nicely a while ago, so good luck.
- Warm up soldering iron.
- Remove top part of dash. Don't forget the nuts on the wiper and lights switches.
- Take out lights switch.
- Pull apart the switch and pull out the little circuit board at the back.
- Re-solder all the connections on this board. Don't add wires or change the connections, just add a bit of new solder and make sure all the connections are good.
- Put back in and check it works, then blame me if it doesn't.
Hen
John K
Re: How to fix your AE86 dash lights... Mon, 03 May 2004 23:35 Go to previous messageGo to next message
Thanks for that.
Its realy starting to piss me off, flicking the light switch on and off 300 times before the dash light comes on. Mad It seems to be getting worse, so I'm willing to try anything.
Thanks for the detailed instructions too, I'm gonna try to fix it tonight.
ae86 Drifter
newcastle
Re: How to fix your AE86 dash lights... Tue, 04 May 2004 01:39 Go to previous messageGo to next message
i just bought another switch from a wreckers,yes mine is fixed Very Happy
Ko Ko
Re: How to fix your AE86 dash lights... Tue, 04 May 2004 06:22 Go to previous messageGo to next message
Had the same prob s you John K. The quot electric person said it was the switch. Problem solved
Skaney
Re: How to fix your AE86 dash lights... Tue, 04 May 2004 09:18 Go to previous messageGo to next message
I tried resoldering a few times and it while it worked the first time after that it still kept getting less reliable over time. The problem in mine was with the dimmer though.
I fitted a switch from a jap spec front cut, and it didnt have the dimmer at all. Works perfect, and im glad its got no dimmer, less chance of it shitting it again.
Vixen 86
Re: How to fix your AE86 dash lights... Tue, 04 May 2004 14:13 Go to previous messageGo to next message
damn so its not just me!!!!!
my lights just come on and off whenever they like whenever they go off i just tap the light switch and it goes on. It pisses me off so much, ill try what your sugesting.
BTW any of you guys have problems with your digital clock, mine just shit itself the other day for some reason.
4AGE
Re: How to fix your AE86 dash lights... Tue, 04 May 2004 14:28 Go to previous messageGo to next message
There are 2 small crosshead screws that screws the pcb into teh plastic section. Give them a 1/4 or 1/2 turn counter clockwise. Should add a little more pressure on the contacts on rotation.
Matt-AE86
Re: How to fix your AE86 dash lights... Sat, 15 May 2004 12:15 Go to previous message
Ok, this is how i got to the switch, and is the most explanatory way.
1. Take of the Wiper and Light Switch knobs.
2. Undo the nut on the Wiper and Light Switch's.
3. Under neath the dash, where the instruments are there are 3 screws.. undo these.
4. To the Bottom left of the steering column there will be 2 screws, one for the instrument
black dash and another for abit of interior, undo both of these.
5. To the Bottom right of the steering column there will be another 2 screws, one for the
speaker cover and another for the instrument black dash.
6. Undo the Speaker cover first to get to the 2nd screw, you will then have to put your
head under and you will see the screw hidden away, remove this.
7. Undo the wheel lock, drop the wheel.
8. Remove the Instrument Dash Black Cover, move it as far back as possible.
9. Unplug the cable to the demystify on the back hatch window.
10. Proceed to remove the switch, once remove, unplug that as well.
Soldering, propping time.
11. Take apart the bottom white plastic bit, there will be 2 clips either side, unclip them
with a small flat head screw driver.
12. You will now see the contact piece, clean it till it looks like new. A clean rag will
do fine.
13. By now you should be seeing the other side of the circuit board. Add solder or re heat
the old ones. There may be some points that have no solder (there was in my case). Get the
soldering iron and solder and put enough so it covers the whole point and gives contact.
Mix in new solder with old. You may also have to prop the circuit board up with a piece of
cardboard if it is getting contact.
14. Put the circuit board back, and clip the white plastic box back together.
Once you have done this, take the switch to the car, plug it in, and test if the dash
lights go on and off. do it as many times as you wish. the light switch should now be fixed.
15. Now reverse the steps, but before this, makes sure you put the switch in the right way.
If you find after woods its in the wrong way, you can easily remove the black dash piece
again, or leave as is for whenever your going to fix it.
I hope this helps, and gives some people a better idea of what to do.
Matt.
[Updated on: Sun, 16 May 2004 01:01]
Previous Topic:AE95 offset and stud pattern?
Next Topic:ae86 conversion info needed...
Current Time: Fri Nov 20 11:57:58 UTC 2026
Total time taken to generate the page: 0.0060720443725586 seconds
