Classifieds » Parts Wanted » Please someone help me out, can't register my MA70 without these parts.
dingaling
tas
icon9.gif  Please someone help me out, can't register my MA70 without these parts. Mon, 03 May 2004 14:10 Go to next message
Finally finished fixing up my supra, and took it over the pits today, what a bad day i had, they found a few problems wich are nothing major, but the killer problem that made it a bad day for me was that the inspector guy could't find the compliance plate for my imported supra. And so failed the car. I thought i was right becuase the car was over 15 years old and didn't need a compliance plate!?
As for the parts i need:
A center bearing for the driveshaft, it's in the middle of the driveshaft, Mine has heaps of play it's not funny :(-
A rear engine mount or i think it's more accuratly called a gearbox mount (i have an auto A340 transmission). If i put a screwdriver under that mount i can lift the gearbox up a good 3 inches, so that probably means it's worn to buggery?
Id rather not have to take the 3 hour drive in an unregistered supra to get the rip off toyota dealer prices for these parts, can anybody help me out?
indian
south east - melbourne
Re: Please someone help me out, can't register my MA70 without these parts. Mon, 03 May 2004 23:18 Go to previous messageGo to next message
dude i dun think u need a compliance plate for a 15 year old import is this the green plate thingy in the engine bay , i got mine registered witthout it , when they asked i told the guy that 15 year old imports dont need it
as for the drive ahft bearing , is this the black rubber thing on the drive shaft in the middle of the car on the drive shaft
mines got play as well , the rubber in mine is one soft and the damn thing has a bit of play in it ,my car vibrates during the first to second gear change asked my mechanic , and he said it was due to the rubber seal/bearing and showed it to me , im also after one
good luck with all the other stuff dude
ma70 soarer suspension parts areinterchangable with the gz20 , mz20 soarer as well hope it helps mate
dingaling
tas
Re: Please someone help me out, can't register my MA70 without these parts. Tue, 04 May 2004 03:53 Go to previous messageGo to next message
Indian i wish it was that easy for me, just tell them it doesn't need a complaince plate becuase it's under the 15 year rule. These ppl don't believe there is such a thing as the 15 year rule, it's the first time they've heard of it i think. They need to see someething official before they will pass my car for rego :(-
Anyway yes your description of the center bearing sounds the same as mine, and my car vibrates between 1500-2500rpm, i'd say it's from the worn out center bearing, I heard they are F#$kn expensive, to the tune of around $400 from toyota.
If you find a place to get one that isn't $400 let me know can ya man? ill do the same.
Thanx for the advice.
ed_ma61
Lost in the K hole
Re: Please someone help me out, can't register my MA70 without these parts. Tue, 04 May 2004 04:09 Go to previous messageGo to next message
centre bearings are about 110 from repco
indian
Re: Please someone help me out, can't register my MA70 without these parts. Tue, 04 May 2004 04:26 Go to previous messageGo to next message
thanks bro
do u / anyone hereknow how hard it is to fit the damn bearing and how much will i be riped off if taken to the mechanic
as i dun know how to fit all this sorta shit
thanks all
ed_ma61
Lost in the K hole
Re: Please someone help me out, can't register my MA70 without these parts. Tue, 04 May 2004 04:54 Go to previous messageGo to next message
replacing the bearing is actually pretty easy. just follow the manual - its all pretty simple (need to drop the shaft and fiddle with the bearing retainer in a vice)
shop... hmmm, expect to pay around 350inc parts id say
indian
Re: Please someone help me out, can't register my MA70 without these parts. Tue, 04 May 2004 04:57 Go to previous messageGo to next message
WHAT MANUAL ?????????
dingaling
tas
Re: Please someone help me out, can't register my MA70 without these parts. Tue, 04 May 2004 05:07 Go to previous messageGo to next message
Indian, this manual
http://www.cygnusx1.net/supra/library/TSRM/in/IN_0 1.html
should help you out.
Good stuff ed, i did not know repco sold center bearings suitable for our cars. I wouldn't expect the quality to be the same as toyota's tho, but better then a worn out center bearing.
Also ed, what about a gearbox mount/rear engine mount? i remember you helped me out in the past with toyota parts, don't suppose you can help me again with the gerabox mount?
indian
Re: Please someone help me out, can't register my MA70 without these parts. Tue, 04 May 2004 05:09 Go to previous messageGo to next message
THANKS MATE
DID U CHEK OUT THOSE THINGS I POSTED IN REGARD TO THE COMPLIANCEPLATES
CHEERS
indian
Re: Please someone help me out, can't register my MA70 without these parts. Tue, 04 May 2004 05:11 Go to previous messageGo to next message
DAMN THATS FOR A 7MGTE I GOT AN 1G-GTE MOTOR ,
WILL THE DRIVE SHAFT BE THE SAME FOR BOTH
dingaling
tas
Re: Please someone help me out, can't register my MA70 without these parts. Tue, 04 May 2004 06:29 Go to previous messageGo to next message
There probably the same, but don't count me on it. Maybe Ed can fill us in.
Man i thought you had a 7M motor and that manual is for 7m engines, sorry about that.
turbokid
Re: Please someone help me out, can't register my MA70 without these parts. Fri, 07 May 2004 03:01 Go to previous messageGo to next message
you don't need a compliance plate but you do need a mod plate. have you done all of the required modifications to get a mod plate? sounds like you need to do more research.
by the way does anyone have a proper working indicator stalk for an ma70?
dingaling
tas
Re: Please someone help me out, can't register my MA70 without these parts. Fri, 07 May 2004 12:27 Go to previous messageGo to next message
"you do need a mod plate."
Are you talking about mods like changing mirrors to flat instead if convex, seatbelts, side intruion bars etc? from my research i don't need to do it.
by the way i do have a spare indicator stalk, but it's abit busted, could be good for parts to fix your one.
[Updated on: Fri, 07 May 2004 14:41]
SUPRA MAN
Re: Please someone help me out, can't register my MA70 without these parts. Sun, 09 May 2004 02:57 Go to previous messageGo to next message
mod plate ???? wtf ??
When was your car imported.
Did you import it.
Current Rules state that an engineers certificate is needed to pass a car. If you need more help with this situation, call me as I can put you onto the right people who will pass and register your car, as I import and register cars every month from Japan.
What state are you in ?
Kristian
Owner/Manager
Japanese Import Parts
0403218108
Kristian@JapaneseImportParts.com
dingaling
tas
Re: Please someone help me out, can't register my MA70 without these parts. Sun, 09 May 2004 05:34 Go to previous message
Kristian, Buaght the car off a guy who already imported it and registered it, It would of been under the 15 year rule as it is an 87-88. Also beecuase it has no compliance plate and was registered in VIC. So it simply comes down to bieng in Tas, the vechicle inspectors don't know shit, but i will go back to them with some facts printed off the internet, aswell as the phone number to vic roads where they have record of my car bieng imported and all legal.
Now i just need a few parts to pass the rego inspecetion, the compliance plate thing should be sorted.
Thanx for your help.
Previous Topic:2tg/3tc pistons
Next Topic:early Ta22 rear fuel flap
Current Time: Mon Oct 26 13:29:19 UTC 2026
Total time taken to generate the page: 0.028681993484497 seconds
