Toymods » Tech & Conversions » have oppurtunity to get a cheap 5 speed from an n/a 2jz supra
soara7mgte
newcastle
have oppurtunity to get a cheap 5 speed from an n/a 2jz supra Mon, 03 May 2004 22:24 Go to next message
will this bolt in behind a 7MGTE in a soarer mz21 .. is it tough enough also .. im assuming it would be
soara7mgte
newcastle
Re: have oppurtunity to get a cheap 5 speed from an n/a 2jz supra Mon, 03 May 2004 22:41 Go to previous messageGo to next message
i looked it up and it looks like it can ... conformation??
lumpy
Adelaide, SA
Re: have oppurtunity to get a cheap 5 speed from an n/a 2jz supra Mon, 03 May 2004 22:46 Go to previous messageGo to next message
The box will work but it the bellhousing won't fit a 7m. The NA 2jz 5-speed you could always on-sell to someone here who is doing a 1jz conversion and wants a manual!
With the proceeds you could by a w58 or an R154 with the correct bellhousing for a 7m (these are plentiful).
Of course, if you do a search you'll find this topic has been covered often....
soara7mgte
newcastle
Re: have oppurtunity to get a cheap 5 speed from an n/a 2jz supra Mon, 03 May 2004 22:48 Go to previous messageGo to next message
ok so is it possible if i find a 7m bellhousing?
soara7mgte
newcastle
Re: have oppurtunity to get a cheap 5 speed from an n/a 2jz supra Mon, 03 May 2004 22:49 Go to previous messageGo to next message
ok so is it possible if i find a 7m bellhousing? wat do the 2jz 5 speeds go for??
soara7mgte
newcastle
Re: have oppurtunity to get a cheap 5 speed from an n/a 2jz supra Mon, 03 May 2004 22:53 Go to previous messageGo to next message
ok i still dont get wat your saying.. are you sayin that it just cant happen or that i have to find a 7m bellhousing.. id also have to find a manual ecu and other stuff too .. how much do the 2jz 5 speeds go for
Re: have oppurtunity to get a cheap 5 speed from an n/a 2jz supra Mon, 03 May 2004 23:00 Go to previous messageGo to next message
Yes you can use a 7M bellhousing on a 2JZ-GE 5-speed, and it will then bolt up to your Soarer. You're much better off getting an R154 though since that's what came behind 7M-GTE's originally; it's stronger than the W58 and you won't have to modify the shifter (the 2JZ-GE box has an external shifter which is too far back for your car).
soara7mgte
newcastle
Re: have oppurtunity to get a cheap 5 speed from an n/a 2jz supra Mon, 03 May 2004 23:15 Go to previous messageGo to next message
you use a w58 dont ya norbie? um.. ive been tryin to get an r154 but as soon as theres a cheap one its gone straight away and i could get an r154 but id have to pay close to 2000!! and thats not even with the rest of the gear that ill need for the conversion.. so i guess the main thing im asking is that is it easy /cheap to find a bellhousing, ecu,clutch assembly, modify the shifter .. (anything else i need)for this w58 to go in ..thanks for the help too i know yous probly hear the same questions over and over
Re: have oppurtunity to get a cheap 5 speed from an n/a 2jz supra Mon, 03 May 2004 23:33 Go to previous messageGo to next message
I have an M-W58 bellhousing. I will be happy to swap with the JZ-W58 bellhousing with you.
soara7mgte
newcastle
Re: have oppurtunity to get a cheap 5 speed from an n/a 2jz supra Mon, 03 May 2004 23:53 Go to previous message
cool .. that sounds good gianttomaco umm im not gonna count the old chickens before they hatch just yet because a mates doing a n/a to 2jgte swap in 2 weeks and im buyin the old box unless the workshop whos doing the conversion try and steal it hehe
Previous Topic:W series gearboxes
Next Topic:ta22 struts into ke20?
Current Time: Tue Oct 13 22:05:27 UTC 2026
Total time taken to generate the page: 0.11158895492554 seconds
