Toymods » Tech & Conversions » 1G-GTE Engine Wiring Diagram (English)
4WD~ET
Canberra, ACT
1G-GTE Engine Wiring Diagram (English) Mon, 03 May 2004 22:40 Go to next message
Hey there,
After an Engine Wiring Diagram for a 09/88 1G-GTE, which came out of a GA70 Supra. Obviously in english would be fantastic.
CrAiGzEE
south of the big smoke
Re: 1G-GTE Engine Wiring Diagram (English) Mon, 03 May 2004 23:11 Go to previous messageGo to next message
check out the gallery!
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: 1G-GTE Engine Wiring Diagram (English) Mon, 03 May 2004 23:44 Go to previous messageGo to next message
Actually, it's been moved to here:
http://toymods.org.au/Repository/
4WD~ET
Canberra, ACT
Re: 1G-GTE Engine Wiring Diagram (English) Mon, 03 May 2004 23:58 Go to previous messageGo to next message
Thanks guys. You're all champions.
4WD~ET
Canberra, ACT
Re: 1G-GTE Engine Wiring Diagram (English) Tue, 04 May 2004 00:48 Go to previous messageGo to next message
Could someone answer me this: On the wiring diagram, there is a connection from the ECU which runs to the TurboIndicator light....How does the ECU know when the car is on boost?
What tells the ECU (ie. Which connection) that the car is on boost?
[Updated on: Tue, 04 May 2004 00:49]
takai
Re: 1G-GTE Engine Wiring Diagram (English) Tue, 04 May 2004 01:54 Go to previous messageGo to next message
Positive pressure on the intake manifold.
4WD~ET
Canberra, ACT
Re: 1G-GTE Engine Wiring Diagram (English) Tue, 04 May 2004 02:07 Go to previous messageGo to next message
So you're saying that the positive pressure on the intake manifold gets sent to the ECU...How? See this:
http://forums.toymods.org.au/index.php?t=msg&t h=34652&start=0&rid=5571&S=81e8be465c1 2565983c37482126e66be
ddeane
PNG
Re: 1G-GTE Engine Wiring Diagram (English) Tue, 04 May 2004 02:22 Go to previous message
Gidday
As far as I know there is no sensor for positive pressure on the inlet manifold. From what I can work out the computer determines whether the other inputs to the computer indicate that there is boost and activates the light. i.e. airflow, rpm, fuel etc. I also believe that the boost cut works in the same manner. (by the way I have connected the boost light in my conversion)
Craig
Previous Topic:3sgte what year
Next Topic:Turbo Indicator Light
Current Time: Mon Nov 23 05:12:52 UTC 2026
Total time taken to generate the page: 0.0079832077026367 seconds
