Toymods » Tech & Conversions » brake and or suspension upgrade for ta22?
w810sc
sydney - paramatta
brake and or suspension upgrade for ta22? Tue, 04 May 2004 04:37 Go to next message
duz anyone know where i can get a proper brake and or suspension up-grade for a ta22 as you know the brake system is about 28 years old!. i would also like to change from drum to disc at the rear wheels.
eg: vented disc, drilled disc, 4 piston callipers etc.
who?, where? what type? cost?
and also with suspension, id like to put wider tyres. (dont want it to rub against struts unit)
thanx!
Classique71
Colac, Victoria
Re: brake and or suspension upgrade for ta22? Tue, 04 May 2004 05:30 Go to previous messageGo to next message
behold! in the magic of the " search " button for it knows all about ta22 brakes and suspension , and gain from its vast , vast Knowelege .......
Vast!
torque
UK at moment
Re: brake and or suspension upgrade for ta22? Tue, 04 May 2004 07:26 Go to previous messageGo to next message
True true, search is your friend!
There are various front strut and brake or just front brake swaps, often from newer model celica/supra's ..
Don't know if you could convert from drum to disc at the back without swapping the diff - but this is a good idea anyways.. hilux and borg warner (out of a commodore) - you can go for lsd as well then..
alex_ta22
Newcastle, Hunter Valley
Re: brake and or suspension upgrade for ta22? Tue, 04 May 2004 07:44 Go to previous message
if you want discs at the rear you need the corona avante brake setup, to fit them you need to move the shock mounts 20mm inwards. i also have some for sale, minus the calipers
[Updated on: Tue, 04 May 2004 07:44]
Previous Topic:ST141 disc brake rear into AE71 20V turbo
Next Topic:'Hybrid' turbos
Current Time: Thu Nov 26 02:26:31 UTC 2026
Total time taken to generate the page: 0.011811971664429 seconds
