Toymods » Tech & Conversions » URGENT: DOES ANYBODY HAVE AE92 GZE DRIVESHAFTS THEY CAN MEASURE
[mikey]
URGENT: DOES ANYBODY HAVE AE92 GZE DRIVESHAFTS THEY CAN MEASURE Mon, 26 August 2002 00:03 Go to next message
Does anybody have a pair of AE92 GZE driveshafts lying around they could measure for me.
Need connecting shaft thickness, outer cv to hub splined end thickness, number of splines on outer cv joint to hub end.
Also, if possible, number of splines and distance between splines on connecting shaft to outer cv end that Outer CV joint splines onto.
If anybody has this or could measure it would be very helpful.
I have driveshaft dilemmas with fitting 97 MR2 Turbo shafts, the Outer CV to hub end is 3mm too large, splined end is 30mm, Corolla and Celica hubs only take 27mm end.
MR2 Turbo takes a 30mm end, and I believe the V6 Camry might be the same.
Michael
MaNGeW
Formerly TRD_RoLLa
Re: URGENT: DOES ANYBODY HAVE AE92 GZE DRIVESHAFTS THEY CAN MEASURE Mon, 26 August 2002 10:37 Go to previous messageGo to next message
Michael,
Talk to Jason Purcell from QLD.
He can be found on the QLD twincam16 forums.
He has some ae92 gze driveshafts he could measure up.
HTH Razz
jasonp1977
Re: URGENT: DOES ANYBODY HAVE AE92 GZE DRIVESHAFTS THEY CAN MEASURE Mon, 26 August 2002 21:49 Go to previous messageGo to next message
I've got some gze shafts I can measure, I'll pick up some measuring calipers today on the way home from work so I can post the info.
Jason
jasonp1977
Re: URGENT: DOES ANYBODY HAVE AE92 GZE DRIVESHAFTS THEY CAN MEASURE Tue, 27 August 2002 07:46 Go to previous messageGo to next message
didn't get a chance to pick up a set of calipers today so I'll do some rough measurments with a ruler to start...
CrAiGzEE
south of the big smoke
Re: URGENT: DOES ANYBODY HAVE AE92 GZE DRIVESHAFTS THEY CAN MEASURE Tue, 27 August 2002 11:14 Go to previous messageGo to next message
mangew i m prettysure jasons are 101`s and not 92s
CrAiGzEE
Re: URGENT: DOES ANYBODY HAVE AE92 GZE DRIVESHAFTS THEY CAN MEASURE Tue, 27 August 2002 11:15 Go to previous messageGo to next message
sorry i stand corrected
[mikey]
Re: URGENT: DOES ANYBODY HAVE AE92 GZE DRIVESHAFTS THEY CAN MEASURE Sat, 31 August 2002 08:03 Go to previous message
all sorted, thanks anyhow =]
Previous Topic:Moulded Carpet place - Vic/web
Next Topic:Location of Fuel Pump & Surge Tanks..
Current Time: Tue Oct 20 04:54:16 UTC 2026
Total time taken to generate the page: 0.0059850215911865 seconds
