Toymods » General Car Talk » Going On Holiday
tuz76
Going On Holiday Mon, 26 August 2002 01:58 Go to next message
Guys quick question,
Have any of you guys gone away for an extended period of time, etc and didnt drive your car for 2-3 months?
Should I just keep the car in the garage for 2 months as per normal or should I arrange for someone to start it once a week etc?
I guess im referring to the oil, fluids etc. Whats theh general recommendation?
stradlater
Arthurs Creek, Victoria
Re: Going On Holiday Mon, 26 August 2002 02:12 Go to previous messageGo to next message
I've just come back from 2 months away and my car started fine, it was a touch low on water, but the rest was ok, and it wasn't even properly garaged, it was only covered by 3 walls, not 4
Toby AE82 Twin
Travelling overseas
Re: Going On Holiday Mon, 26 August 2002 02:18 Go to previous messageGo to next message
If its an old car and you want to be sure its going to start when you get back I would get someone to start it at least once a fortnight.
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: Going On Holiday Mon, 26 August 2002 04:28 Go to previous messageGo to next message
Yeah, if it can be arranged, get someone to start it at least once every two weeks.
HSV_gal
Re: Going On Holiday Mon, 26 August 2002 07:12 Go to previous messageGo to next message
did you guys realise that it should actually be driven not just started? (at least that is what I have been told) that way it keeps everything lubed and in working order.
feel free to let me know if I have been misinformed! Rolling
Toby AE82 Twin
Travelling overseas
Re: Going On Holiday Mon, 26 August 2002 08:43 Go to previous messageGo to next message
Obviously better if you drive so as to work all the moving parts but starting without driving is still better than nothing if you want it to start first go after a long lay-up.
GT4_Steve
Sutherland, Sydney
Re: Going On Holiday Mon, 26 August 2002 11:00 Go to previous messageGo to next message
Start it up and let it run for a while..at least operating temp.
It's good to keep the battery active and charged after the initial start.
Ultra long trips...roll those tyres!
raSkaS
Perth WA
Re: Going On Holiday Tue, 27 August 2002 00:40 Go to previous messageGo to next message
only trouble ive had was a car not used for 4 months and the rear brakes had seized up because the hand brake was on (drums) dont know if thats a problem with disk brake rear or not..but if you can leave the handbrake off
And the tyres loose pressure so bump them up to 45psi or so before you park it
if its not gonna be started unhook the battery... and dont leave it with too much gas in the tank
Cam
GIN51E
Berowra-Sydney
Re: Going On Holiday Tue, 27 August 2002 10:28 Go to previous messageGo to next message
actually i might be wrong here but if what goes with boats is the same with cars then you should leave the tank full as it prevents condensation and moisture forming in the tank
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Going On Holiday Tue, 27 August 2002 15:23 Go to previous messageGo to next message
That's a good point with the fuel tank, keeping it full, another plus is that a tank with a little fuel & alot of vapour is alot more volatile than a tank full of fuel with very little vapour.
Rolla Boy
Club Member
Sydney, NSW
Re: Going On Holiday Tue, 27 August 2002 15:41 Go to previous messageGo to next message
My motor is out of the car and I have around half the fuel tank... Does that mean it will start first time or will I have a few troubles... The fuel lines are blocked at the rail and the battery is disconnected... Also, it's been off the road for 3 months and probably will be for another 2...
raSkaS
Perth WA
Re: Going On Holiday Wed, 28 August 2002 00:14 Go to previous message
damn you guys must have good fuel here, in NZ i wouldnt leave a tank of gas for more than a month... it just goes off and causes major trouble
Cam
Previous Topic:Thrashing a TA22 WHAT A DISGRACE!
Next Topic:Funny Movie
Current Time: Thu Oct 29 15:56:20 UTC 2026
Total time taken to generate the page: 0.18893790245056 seconds
