Toymods » Tech & Conversions » ae86 short stroke rear shocks
PerformanceCars
ae86 short stroke rear shocks Wed, 05 May 2004 23:44 Go to next message
Hi - I picked up a set of kyb rear shocks for the 86.
I currently have kings low springs in the back, and when i installed the shocks - they are almost af full extension when the car is sitting level - so if i bounce the car the shocks bang as they extend to their limit.
What springs can i get for the 86 that will suit these short stroke shocks - as far as i know kings dont make super lows for the 86.
4a-c
Sutherland Shire
Re: ae86 short stroke rear shocks Thu, 06 May 2004 09:54 Go to previous messageGo to next message
K-mac make custom height springs
ae86drift
sydney.au
Re: ae86 short stroke rear shocks Thu, 06 May 2004 10:08 Go to previous messageGo to next message
step 1
take shocks out. put old ones on for meantime.
step 2
take out springs + measure the freeheight (uncompressed height) of the springs. do front AND back. now decide how much you want to lower the car and take of that mm value from your current height. make sure front and back are equal freeheights
step 3
call KMAC.
> K-Mac Suspension
> 366 Princes Hwy Rockdale 2216 Sydney NSW
> Ph (02) 9556 1799
> Fax (02) 9556 1507
step 4
ask for 5.0 kg/mm AE86 rear springs in your preferred height
ask for 7.5 kg/mm AE86 front springs in your preferred height
step 5
install and enjoy your new solid springs
(warning. ride will be solid and possibly unconfortable with these rates. if your a pussy then lessen the kg/mm rate. i run an 8.5kg/mm front and a 6.5kg/mm rear, solid but not impossibly hard. 7.5 and 5 is just good.)
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: ae86 short stroke rear shocks Thu, 06 May 2004 11:57 Go to previous messageGo to next message
dont be weak with the spring rates Razz
mumblezzz
Gold Coast
Re: ae86 short stroke rear shocks Fri, 07 May 2004 01:20 Go to previous messageGo to next message
Pull Springs out
Cut 3 coils off
Cruise round looking fulsik with all your mates
Laughing
3sglevin
Re: ae86 short stroke rear shocks Fri, 07 May 2004 04:56 Go to previous messageGo to next message
If the car is the height you want it? then you have a couple of option, either get another shock (with a longer stroke) or measure the length of the body of the shock itself, then measure the open length of the piston (shock shaft) if they are about the same the shock is too short, but if they are different then they may have stroke limiters in them, this is done to stop the spring from becoming unloaded over bumps and falling out, or another option is take the shocks back to where you got them and see if they can help you!
But there is another option too, you can get springs reseated so send your springs back and they can reset the ride height to what you want. I am pretty sure Kings can do this for you!
[Updated on: Fri, 07 May 2004 06:43]
monkeymajik
Re: ae86 short stroke rear shocks Fri, 07 May 2004 09:22 Go to previous message
Is there a mob that will do this in brisbane? I need to get rid of the "modified" springs in my car.
Previous Topic:sc14
Next Topic:86kw cams on a 100kw motor?
Current Time: Sun Oct 25 13:50:50 UTC 2026
Total time taken to generate the page: 0.020376920700073 seconds
