Toymods » Tech & Conversions » converting 2tg to multi coils
Syc02T
Lake Macquarie
converting 2tg to multi coils Thu, 06 May 2004 02:46 Go to next message
I am running an ems computer and want to convert to multible coils, i need an extra sync sensor to tell the comp when to fire the 1st coil.
What is the best way to do this,
can i use other dizzys say out of a 4agze etc and modify them to fit in, what have others done.
how about crank angle sensors on the pully
i am open to ideas
please help
earlyrolla
Re: converting 2tg to multi coils Thu, 06 May 2004 13:26 Go to previous messageGo to next message
How about using your original distributor and rotor button, then making a custom cap. The custom cap houses an optical sensor, positioned at the number one position (obviously no plug leads required). When the rotor passes through the optical sensor slit it produces the pulse required for the number one firing. Just have to make sure that optical sensor triggers before number one would fire and after number two fires.
You can still turn the distributor to get this bit right.
Take a bit of fiddling but is probably easier than modifying another distributor to fit.
EMP-2TG
Carlingford, Sydney
Re: converting 2tg to multi coils Fri, 07 May 2004 05:24 Go to previous messageGo to next message
id love to know some more about your motor
the pics look sweet
Syc02T
Lake Macquarie
Re: converting 2tg to multi coils Fri, 07 May 2004 06:53 Go to previous messageGo to next message
sorry. Not at the moment, i am really pissed off with it at the monent.
When it all goes well and stops leaking head gaskets, etc im sure you wont be able to stop me telling some one.
Cars Suck at the moment
Sorry had to get that out
EMP-2TG
Carlingford, Sydney
Re: converting 2tg to multi coils Fri, 07 May 2004 07:03 Go to previous messageGo to next message
np Smile i understand what u mean
well let us know when your happy with it Smile
Syc02T
Lake Macquarie
Re: converting 2tg to multi coils Thu, 13 May 2004 22:31 Go to previous messageGo to next message
Allright. I have had some success with my engine now.
Hopefully things will be on the up from now.
anyway to answer your question EMP-2TG.
My engine is a 2tgeu with forged pistons, o-ringed block, ported head, custom exhaust manifold (my first attempt at making one) ball bearing t3 turbo, s4 13b injectors, w58, Custom orange pearl paint, only in the engine bay at the moment with the original grandmar white outside (hence the sig of the wolf in sheeps clothing)
That is the most of it. im hopeing it will be on the road in the next 2 or so months.
sideshow
Re: converting 2tg to multi coils Thu, 13 May 2004 22:37 Go to previous messageGo to next message
u will also need an ems ignitor with 4 inputs/outputs
for the 4 coils
u cannot mount a sensor on the crank as it spins too fast
u need something that runs off the dizzy
and it needs one pulse every rotation of the dizzy
just send yr dizzy to an ems dealer
they should be able to sort something out
it will cost u about 150 maybe to sort the dizzy out
and the igntitors are 95 bucks i think
Grega
melbourne.victoria.austra...
Re: converting 2tg to multi coils Thu, 13 May 2004 23:08 Go to previous messageGo to next message
why not have a look at some of the m&w gear - they have ignitors which can be triggered from dizzys with either points (yuck) or hall sensors - http://www.mwignitions.com
Syc02T
Lake Macquarie
Re: converting 2tg to multi coils Sun, 06 June 2004 10:52 Go to previous messageGo to next message
Well ive given up on this for the short time, and ive gone back to a single coil.
After all the dramers ive had all ready i will get the rest of the engine sorted out b4 i go and create more headaches for myself.
Had a brief look at the M & W site, and they didnt realy have any sensors that i could see, i will have a better look l8r tho. Also one of the dramas i had was the car was hard to start which turned out to be the brand new M&W coils i had just purchased. So i will see how they go with explaining why i have a weak spark b4 i get any other sensors of them. they should be cool tho
jesseT18
Castle Hill, Sydney
Re: converting 2tg to multi coils Sun, 13 June 2004 10:47 Go to previous messageGo to next message
in case u didnt know ur signature actually says
The 'Sheep' in 'Sheeps' clothing
too much beer?
YelloRolla
On your mum!
Re: converting 2tg to multi coils Sun, 13 June 2004 10:57 Go to previous messageGo to next message
I run a trigger disc off the crank pulley and the sensor is mounted using a bracket and existing timing cover bolt holes.
Syc02T
Lake Macquarie
Re: converting 2tg to multi coils Mon, 14 June 2004 09:25 Go to previous messageGo to next message
YelloRolla:
If i mount a sensor to the crank pully to tell the computer when to fire coil #1, that wouldnt give me a correct reading would it? because the dizzy rotates at 1\2 the speed of the crank. Correct me if im missing something
jessetamsett:
Yes mate i know it says that, the 'sheep in sheeps clothing' came around because the car has been a bit of a sheep with a grandmar exteria and the matching 2t auto heart,
Why it also says slowly recieving a "slowley recieving a wolfs heart" is as you can see in the ativar is that it is a bit more wolf like with the new engine and the extra power now unde there. So its not too much beer, just my weird was of looking at things. Hope it clears that up.
thetoyman75
Club President
icon14.gif  Re: converting 2tg to multi coils Mon, 14 June 2004 12:03 Go to previous messageGo to next message
Every time I read something else about your car I wishI hadn't sold it, but anyway. Its looking good mate, really good.
For mine I run the triggers off the Flywheel and the inlet cam. I will be using the Autronic and Autroic CDI unit.
gearb0x
Re: converting 2tg to multi coils Tue, 15 June 2004 06:41 Go to previous messageGo to next message
heres a link showing how TA22_GT converted a 3tgte dizzy to house a 3s CAS
http://users.chariot.net.au/~stmezz/cas.htm
Could be an idea, i dont know what the possibility of adapting the CAS to a 2t dizzy would be though
[Updated on: Tue, 15 June 2004 06:41]
YelloRolla
On your mum!
Re: converting 2tg to multi coils Tue, 15 June 2004 08:50 Go to previous messageGo to next message
Syc02T wrote on Mon, 14 June 2004 19:25
YelloRolla:
The trigger disc that I use has 1 x trigger for #1 and another 180deg opposite, it also has a reference trigger - so 3 x trigger points in total.
GTS_215KW
Re: converting 2tg to multi coils Wed, 16 June 2004 04:02 Go to previous messageGo to next message
If your only using two coils then a crankshaft mounted trigger will be fine, but if you have four coils then you will need to run a trigger from the camshaft.
Smile
Syc02T
Lake Macquarie
Re: converting 2tg to multi coils Tue, 29 June 2004 11:02 Go to previous message
gearb0x
Ummm I like the work TA22_GT did on that, a job well done. Got some good ideas, Just need access to a lathe now, But for the time being i will have to put it on the back burner, as i said earlier i have gone back to single coils, because it seams that the m&w coils i have are not putting out enough spark, since pulling them of it could have just been a dodge earth, but i will worry about that l8r.
Rod,
How does a flywheel sensor mount, if you have any pics could you email them, would be interested to cee how that goes. Thanks for the compliment, it would to look good after the time i have put in it, i think i can see the light at the end of the tunnell, cant wait till i get in on the road properly.
Previous Topic:what causes toyota ecus to retard timming?
Next Topic:18rgeu oil filter and cold start wiring
Current Time: Thu Oct 29 15:21:10 UTC 2026
Total time taken to generate the page: 0.034198999404907 seconds
