Toymods » Tech & Conversions » 18R-GEU injectors not firing
Simmo T
Kellyville
18R-GEU injectors not firing Mon, 26 August 2002 04:20
G'day,
I can't believe i've owned celicas for 5 years and never found your site.
my problem:- I'm currently fitting an 18rgeu into an RA-28 celica however after wiring in I've found the injectors aren't firing. Assuming that the car is wired correctly I'm assuming that there is a problem with the IG signal from the igniter to the ECU can anyone give me any ideas on a fix. I'm using the original coil from the old setup with an MX-62 cressida igniter.
does the coil itself need to be from the cressida as well?
Any body else running an 18rgeu with standard computer tell me what coil/igniter they are using? Part No's on igniter?
Previous Topic:1ggte in an ra23
Next Topic:1G-GTE
Current Time: Tue Oct 20 23:54:03 UTC 2026
Total time taken to generate the page: 0.018495082855225 seconds
