Toymods » Tech & Conversions » Twin intercoolers???
Helmann
Ipswich
Twin intercoolers??? Mon, 26 August 2002 05:29 Go to next message
Instead of running one larger intercooler is it possible to run 2 smaller ones linked together???
Would this be feasable? More efficent/less efficient?
Any ideas?
SUPRAGTE
North Sydney
Re: Twin intercoolers??? Mon, 26 August 2002 06:21 Go to previous messageGo to next message
Yep thats what i've got one mine. Or had on mine until they made love to the tree and telegraph pole yesterday.
They "were" two MX626 intercoolers joined together at the tanks. Worked fine for 300RWHP at 14psi. Didn't even get warm. Its a good, cheap alternative.
Helmann
Ipswich
Re: Twin intercoolers??? Mon, 26 August 2002 06:33 Go to previous messageGo to next message
that is the same as what i got i got 2 mx6 intercoolers and will modify them and use them together. do u know how efficent they are? do u know what air temp differences are like using them together as opposed to individually?
How far apart did you mount them? I heard that the longer your piping from turbo to inlet maifold the greater the lag. That sound true?
Re: Twin intercoolers??? Mon, 26 August 2002 12:02 Go to previous messageGo to next message
Twin intercoolers can work well, but it depends how you join them. The easiest way is to join them in series, ie the outlet from intercooler #1 joins the inlet of intercooler #2. The downside of this is you will double the pressure drop and make the inlet tract longer, which is bad news.
The better way to do it is to join them in parallel, so you have a Y-piece splitting the air from the turbo between the coolers. This method will halve the pressure drop and shouldn't make the inlet any longer than it would be with a single cooler.
This is more or less what I did with my 2JZ-GTE install, except I had custom end tanks fabricated to join the cores together instead of using pipes. Check out my web site to see what it looks like. Smile
SUPRAGTE
North Sydney
Re: Twin intercoolers??? Tue, 27 August 2002 04:09 Go to previous messageGo to next message
Yeah but with the MX626 cores joined together at the tanks the entire cooler is only as long as a Supra one anyway so the pressure drop wont be too bad.
Best to run them together not separatley, as in i mean dont have a pipe running in between the two cores, thats just silly. Paralell or series is good, paralell a bit hard cause then you end up with a 5-6 inche core thats hard to fit in the front of a car and the rear core doesn't get much airflow.
Beleive it of not but my intercooler appears to be fine follow the tree and telegraph pole incident. The impact bar is bent but the whole intercooler moved with it in behind.
By the way guys there will be plenty of parts to sell off my car over the next few months. There is still 10K loan on the car which also adds to the heart renching sorrow. Well its something that Scott has to pay for,it was his mistake.
Re: Twin intercoolers??? Tue, 27 August 2002 04:24 Go to previous messageGo to next message
So you're parting out your car? I may be interested in a few bits...
SUPRAGTE
North Sydney
Re: Twin intercoolers??? Tue, 27 August 2002 09:32 Go to previous messageGo to next message
Yeah i have to see over the next week what (if any) the new donor car has, but there are bits that i dont need either way i go. What are you after mate?
I have 7mgte afm, many other parts in two different garages can't list em all now.
Re: Twin intercoolers??? Tue, 27 August 2002 23:25 Go to previous messageGo to next message
I need a steering rack that doesn't leak... do you have one?
SUPRAGTE
North Sydney
Re: Twin intercoolers??? Wed, 28 August 2002 12:12 Go to previous message
Nah sorry mine leaks, probably use it as a basketball ring now anyways.
Previous Topic:1jz-gte stutters when cold.
Next Topic:Noisy Diff RA23 - what else fits
Current Time: Fri Nov 20 12:37:34 UTC 2026
Total time taken to generate the page: 0.0054910182952881 seconds
