Toymods » Tech & Conversions » 1jz Cressida auto problems
bowlsclubboy
N/E Vic
1jz Cressida auto problems Thu, 06 May 2004 12:40 Go to next message
Okay guys, ive posted about this before but never got a straight answer =\
Ive got a 1jz cressie automatic, self conversion using EVERYTHING from chaser half cut. Auto had problems from day one, never shifted into overdrive until you backed off at around 160km/h. Has shift problems (have to 'ease' it into 2nd and 3rd) Unless you have the MANU button on in which case 1st-2nd is beautifully smooth, but 3rd wont happen until you back off at about 80km/h. Had auto serviced with type 4 and the 'auto specialists' had the car for 3 weeks before coming to the conclusion that the problem is ECU related (Fried?) I also have a Greddy speed cut controller which came with the cut (could this be the same problem as with the V8 soarers with this unit?).
A few weeks back, the timing belt tensioner decided to detach itself which meant i had to remove the rad/trans cooler to access the timing belt, upon replacement i had NFI how much trans fluid i had lost so i added about 1l. Now occasionally if i get up to highway speed, the car will shift into overdrive by itself, all gears will shift at correct spots and i wont need to backoff to get into 2nd/3rd/overdrive. As soon as i stop for a traffic light however, it will go back to shifting like shit again Sad
Sorry for the long post but one more thing. If i nail the throttle in first, manually shift second with the manu button on, about .05sec after the shift, the car will lurch as if it is starving for fuel, and then instantly return to pulling...any ideas on what it could be, ive got a walbro 500hp pump so its not starving there...fuel filter maybe?, its not much but i know its not normal and it could mean that extra bit on the local 1/8th mile Smile
Thanks heaps in advance guys,
Troy
Allan
Re: 1jz Cressida auto problems Thu, 06 May 2004 13:29 Go to previous messageGo to next message
Firstly you check the auto oil level while runing warmed up in N or P
next remove the speed cut see if it shifts correctly or not
if its still not working do the auto trans diagnostics as listed in the TSRM if not available for the front cut use the MA70/JZA80 TSRM it should be a similer process
Allan
Chris Davey
sunny coast, qld
Re: 1jz Cressida auto problems Fri, 07 May 2004 01:55 Go to previous messageGo to next message
I have a similar problem with the sort of stalling at the top of 1st gear. I was told I actually hit the rev limited before the auto could change which is understandable with a 4.6:1 diff Smile
I have also seen many 1jz soarers that seem to pop and fart at the top of first gear for a second and then start pulling again. I read that it was a safety mechanism for the auto. I don't know if that is what mine is doing though?
P.S I have EVERYTHING from a jzx90 chaser in my corona Smile Did you swap the dash?
bowlsclubboy
N/E Vic
Re: 1jz Cressida auto problems Sat, 08 May 2004 09:59 Go to previous messageGo to next message
lol yeah i did...nightrider style baby Very Happy it fits straight into an mx83 from jzx-81, no corona hacking required Very Happy
ChuckLandwehr
Re: 1jz Cressida auto problems Sat, 08 May 2004 10:39 Go to previous messageGo to next message
Auto problems with Cressida 1J, and the same problems in a 1UZ Soarer, were both fixed by replacing the internal solenoids. Auto trans places in both cases were unsure as to what was going on, so when all else fails, blame the ECU (not my problem take it away!) Soarer solenoids from another Soarer box, and Cressida solenoids came from the Cressie box which was behind the original 7M.
Just think, why was the car turned into a half cut in Japan? maybe the box was sus, labour to fix in Japan way too much!
Hope this helps, regards Chuck.
sideshow
Re: 1jz Cressida auto problems Sat, 08 May 2004 12:38 Go to previous messageGo to next message
the reason they bring half cuts is to bring a full car is a waste of space
have u ever seen importers bring a shitload of rear cuts
except more like mr2 cuts
alot of people have probs with autos when doin transplants
i have done afew 1jzs and no probs what so ever except for abs related probs
its hardly ever the ecu
Milhouse
Re: 1jz Cressida auto problems Sun, 09 May 2004 02:28 Go to previous messageGo to next message
Yeah but why do the japanese stop driving their cars all of a sudden and turn them into a wrecking yard?
Why would anyone just cut a perfectly good & operating JZX90 Chaser in half? Mechanical repairs are very expensive in Japan so often if they have a weird probably thy will get rid of them.
Off course it is cheaper to just bring in the most valuable part of the car ie the front cut.
While it is more expensive in japan to register an older car the japanese are still driving older cars and these are the same cars as the front cuts we are getting now.
sideshow
Re: 1jz Cressida auto problems Sun, 09 May 2004 03:05 Go to previous messageGo to next message
sometimes there is problems with themn
they dont really service their cars there
they just throw em away and buy a new one
just because its a chaser doesnt mean its worth alot in japan
speak to an importer and u wil get the right answer
i know of importers cuttin up perfect series 6 rx7's
like u see a 180 sx here afew yrs ago there wasnt many of them
well in japan theyre like a commodore theyre everywhere
this is the main problem with doin conversions
how do u know what u r gettin is perfect
and how do u know the work done is correct
so many problems are hard to explain on a forum
and there a similar amount hard to solve
do some diagnostics first even see if someone has a diagnostic scanner to plug into it
chase up worskshop manuals and see what they say
the first thing u have to determine is
is it mechanical or electrical problem
in the workshop manual they will tell u how to determine this
bowlsclubboy
N/E Vic
Re: 1jz Cressida auto problems Sun, 09 May 2004 08:23 Go to previous messageGo to next message
Thanks for the info guys...ill check to see if toyota has a diagnostics machine first. I honestly think that if i goto toyota and say "can i please order a Chaser JZX-81 workshop manual in english" theyll laugh at me wont they?
Allan
Re: 1jz Cressida auto problems Sun, 09 May 2004 08:39 Go to previous messageGo to next message
theres no mechine for diagnostics it will flash the o/d light when put in diagnostics mode..
http://www.cygnusx1.net/supra/library/TSRM/at/AT_0 13.html
bowlsclubboy
N/E Vic
Re: 1jz Cressida auto problems Sun, 09 May 2004 11:15 Go to previous messageGo to next message
OMG...i got so excited when you posted that link, i went straight out and shoved a pair of stainless tweezers into E1 and Tt connectors to act as a patch cable...it looks as though the chaser doesnt have a connector in the Tt hole...its covered in dieelectric grease but im pretty certain theres just plastic mounting lugs inside...so i went to the other diag' connector under the dash, which has all the plugs. Following the TSRM's instructions exactly...it did nothing Sad Is this cars fate destined to never have an auto that works properly? With optimax sitting at $1.14 a litre this morning and me driving car with no overdrive on apprentice wages with a heavy right foot....a manual conversion is looking better by the day sadly.
grande91
Re: 1jz Cressida auto problems Mon, 10 May 2004 10:19 Go to previous messageGo to next message
you're not the only one with out the Tt connector mine hasn't got it either,...mine has no problems at all(thanks to Jim from sideshow) but lately the O/D light started flashing on and off, and when i tried to check the codes ....surprise surprise,...no Tt connector,...now what?, how is anyone supposed to check the bloody codes,.... i guess you don't.....
sideshow
Re: 1jz Cressida auto problems Mon, 10 May 2004 10:58 Go to previous messageGo to next message
hey leon
the tt terminal is on the 1j ecu
ill get a pic for u and email it for u
with my 1uz all i do is bridge out te1 and e1 which puts the engine ecu into diagnostics
then i earth out tt to get codes for the auto
i dont know y i dont get codes just by earthing out tt
but thats the way my 1uz is
bowlsclubboy
N/E Vic
Re: 1jz Cressida auto problems Mon, 10 May 2004 11:23 Go to previous messageGo to next message
Would you be so kind as to post it on here sideshow? Dont think im trying to steal your business or anything man, i know you do great work, but i decided to do it myself as there isnt an autoelec within 260km who would even touch my car...i live in wangaratta vic :/
sideshow
Re: 1jz Cressida auto problems Mon, 10 May 2004 11:34 Go to previous messageGo to next message
lookin at the ecu
this is the ecu with 4 plugs
each plug has 4 rows of pins in it
like a jzz30 ecu
well lookin at the ecu
with the clips which hold the plugs in at the top
the pin that is at the top right hand side of the ecu is the tt pin
the bottom right pin should be black with red trace
the plug at the right i think has 29 pins
Shotgun
Auckland, New Zealand
Re: 1jz Cressida auto problems Wed, 12 May 2004 17:32 Go to previous messageGo to next message
If it's any help the a340e transmission service/rebuild manual is in pdf format on www.turbosupras.com. It has a trouble shooting section in it.
bowlsclubboy
N/E Vic
Re: 1jz Cressida auto problems Fri, 19 August 2005 09:55 Go to previous messageGo to next message
*brings back from the dead....*
I forgot to get everyone updated on this.
It took me about 10 seconds to fix this problem lol...all i did was, open cressida boot, locate cover over ABS computer, detach plugs from said computer, drive car with a perfectly working auto! Stupid thing was trying to use the wheel sensors todetect speed and therefore change gears, even though they arent hooked up...jeez lol
-Troy
petespipes
logan river brisbane
July 2005
Re: 1jz Cressida auto problems Fri, 19 August 2005 15:17 Go to previous messageGo to next message
following your post Troy and looking who is offering advice,the good guys!Awesome you have it sorted yeah? Smile
terra
July 2005
Re: 1jz Cressida auto problems Sat, 20 August 2005 02:18 Go to previous messageGo to next message
Milhouse wrote on Sun, 09 May 2004 11:58
lets revive this again
thats because they gotta run a big emmisions type test on their cars eveyr 2 years and its almost cheaper to sell and buy a new one, which is why we alwasy get low km cuts, they see at most 2 years of service b4 getting chopped
i had this problem with my auto... changed fluid Very Happy
Ribfeast
Newcastle, Australia
March 2005
Re: 1jz Cressida auto problems Wed, 24 August 2005 06:29 Go to previous messageGo to next message
Mine pops and farts when changing through the low gears too, better that than kill the box I guess Smile Good that yours was a simple fix!
Southo
Re: 1jz Cressida auto problems Wed, 24 August 2005 12:00 Go to previous messageGo to next message
Check your TPS is working properly and calibrated correctly.
This was the reason my Auto was shifting weirdly when we first got it running - discovered the TPS was rooted. Replaced it with a new one and bingo - perfect shifts
1JZ.747
Osama's hideout
Re: 1jz Cressida auto problems Thu, 25 August 2005 00:12 Go to previous messageGo to next message
99% of 1js op and fart on gear changes. the ecu retards timing i believe which makes it shift softer making the box last longer and also making shifts more comfortable for the passengers.
this was what i was told by MV prior to having my gearbox rebuilt.
Ribfeast
March 2005
Re: 1jz Cressida auto problems Thu, 25 August 2005 00:40 Go to previous messageGo to next message
Hmm maybe it is the TPS, like last night I took a guy for a spin in my car out at Raymond Tce, floored it, it dropped back a gear and pulled reasonably hard, then a few secs later it dropped back another gear and really caned along like it should.
Same thing if I want to do as 0-100 run, sometimes it takes off like a rocket, other times it won't (relatively speaking). Reckon this is TPS? Just seems like the tranny isn't always kicking down, or at least not down as many gears as it should.
Where is a cheap place to source a TPS? I need to get a JZA70 throttle body anyway, as I have the JZX81 one with the traction control butterfly (unwanted air restriction). Would this come with the TPS?
Thanks Smile
terra
July 2005
Re: 1jz Cressida auto problems Thu, 25 August 2005 05:41 Go to previous messageGo to next message
do you have a cable operated kick down? (cable run from transmission to throttle body)
tighten that to make it shift hard everytime, all the time
youll save your torque converter (its doing less) but youll wear ya engine mounts down faster (theyre doing more)
Skip
Re: 1jz Cressida auto problems Thu, 25 August 2005 07:10 Go to previous messageGo to next message
I have a spare non TRC throttlebody with TPS, offers there Smile
sideshow
Re: 1jz Cressida auto problems Thu, 25 August 2005 07:58 Go to previous messageGo to next message
are the speed sensors correct
by adjustin my speed signals to the gbox i can control when to change gears
who wired up yr car
maybe its not done 100%
bowlsclubboy
N/E Vic
Re: 1jz Cressida auto problems Thu, 25 August 2005 10:50 Go to previous messageGo to next message
Guys guys, i only bought this topic back from the dead to tell you how i solved the problem! (read back a few posts) It was a matter of simply disconnecting the ABS computer....stupid me lol
Shane - The popping and farting you talked about i encounter and understand. The first problem i noted must have been totally different and speed sensor related, as the car actually lost a lot of power and revs and kind of 'bucked' before pulling hard again. The shifting is fine now and that has dissapeared.
Sideshow - I used a jzx-81 cut and utilised EVERYTHING forward of the front seats, i would have gotten you to do it if you werent 600+kms away! The only things that dont work are the power aerial, ABS (as expected), cruise (i dont want the ugly cruise box in there anyway lol) and TRC...I prefer Lack of Traction Control (LTRC).
I dont know about the aerial, i recon ive plugged in a connector wrong somewhere along the line and fried it.
Thanks for all your help guys, i'd be screwed without a lot of you lol.
Troy
[Updated on: Thu, 25 August 2005 10:56]
Ribfeast
March 2005
Re: 1jz Cressida auto problems Fri, 26 August 2005 01:40 Go to previous messageGo to next message
Well the O/D light flashes on the dash (common problem with 1JZ conversions), but I think this is unrelated.
First thing to try will be tightening the kickdown cable on the left. The problem is intermittent, seems more common when I am moving at low speed rather than just sitting still, but I haven't tried troubleshooting it to that extent yet (fuel costs too much Wink )
This is my setup:
http://ribfeast.no-ip.com/cressida_throttle_cable.jpg
Wilbo sent me a rubber thing for the accelerator cable to go through, but I will need to fabricate a strong metal bracket for it to go onto, as the cable will not fit in the normal position (it is too long, Cressida throttle cable instead of proper 1JZ/Chaser one)
How much do you want for that TPS/Throttle body combo? $100? I know a bloke in newcastle selling one for similar $, but it that falls through I'll take it off your hands.
I don't have ABS (GLX model) so that isn't a problem.
No idea who did the wiring, Scrote might know as he did the conversion.
Skip
Re: 1jz Cressida auto problems Fri, 26 August 2005 02:18 Go to previous message
Yeah that price is okay. Give me a PM if you want it.
Previous Topic:Detonation on 4agze turbo
Next Topic:SERIES Twincharging... (no longer taking the piss :P )
Current Time: Sat Nov 21 08:21:28 UTC 2026
Total time taken to generate the page: 0.018944025039673 seconds
