Toymods » Tech & Conversions » oil pres sender on 4AC.
45aken
NSW.south coast.Drifting
icon14.gif  oil pres sender on 4AC. Thu, 06 May 2004 15:32 Go to next message
just bought an oil pressure gauge from ebay, i think its mechanical, not elec. where on the 4ac can i get a reading for the gauge? what do i have to buy?
(i've put in plenty gauges before, just never an oil pressure!)
any help appreciated
SW20R
Re: oil pres sender on 4AC. Fri, 07 May 2004 01:55 Go to previous messageGo to next message
hmm tap the oil light switch?
you can buy adaptors for it at your local autoshop
remove the oil warning light, add the adaptor, connect those hose and put back the oil light ontop?
FKN16V
NSW, East Coast
Re: oil pres sender on 4AC. Fri, 07 May 2004 02:38 Go to previous messageGo to next message
AE86 (i asume your talking about your ae86) 4ac runs a oil gauge not a oil light. Ive got no idea where to put it.
Steve
45aken
Re: oil pres sender on 4AC. Fri, 07 May 2004 08:36 Go to previous messageGo to next message
yeah its for an ae86. so no one has any idea? there must be a pick up point somewhere.
Maurice c
Re: oil pres sender on 4AC. Fri, 07 May 2004 08:52 Go to previous messageGo to next message
It must be the oil light pick up switch, an oil light is a cheap alternative for an oil gauge. It saved toyota a few yen as well as lumbering it with the 4ac engine.
Steve-AE86
Ademelaide, SA
Re: oil pres sender on 4AC. Fri, 07 May 2004 22:56 Go to previous messageGo to next message
the stock oil pressure switch is for a gauge, yes.
you will have to remove it, get the appropriate fitting kit for your gauge, and fit that there.
not exactly rocket science, but make sure you get the right fittings, and when you run the hose for the gauge, try not to kink it when going through the firewall.
steve
45aken
Re: oil pres sender on 4AC. Sun, 09 May 2004 21:55 Go to previous messageGo to next message
where abouts it this stock oil switch? is it near 3rd and 4th cylinder (in between)?
all i have is a big screw there, dosent looks too standard, maybe this is why the gauge incar wont work!
just need to know where in the engine bay to get signal from
FKN16V
NSW, East Coast
Re: oil pres sender on 4AC. Mon, 10 May 2004 03:41 Go to previous message
Its between number 1-2 cylinder i think, under the dizzy, about as round as a can of coke.
Previous Topic:7A-FE --> 7A-GZE
Next Topic:1UZ Project Planning
Current Time: Sat Oct 31 09:00:49 UTC 2026
Total time taken to generate the page: 0.0090470314025879 seconds
