Toymods » Tech & Conversions » 5S & 3S blocks
RWDboy
5S & 3S blocks Fri, 07 May 2004 00:40 Go to next message
I'm sorta entertaining the idea of maybe trying out a '5S-GE' or maybe a '5S-GTE' in my St162...(traction will be sorted later, or if it doesn't work out just get rid o the 162 body and find a 165)
Now there are a couple of problems that I haven't investigated yet so I thought I'd start by asking here.
a) Does a 3S-G(t)E head get anywhere near fitting a 5S block? I'm guessing that it must be pretty close although there will definitely be some fiddling (probably in regards to cam belts).
b) Does the 5S block even get close to being able to fit in an ST162 engine bay? Things like mounting points for steering pumps and alternators are different (i'm guessing) but there may be other stuff - if anyone has any pics of a 5S block stripped/semi stripped down it would be handy for a start.
I'm also hoping that it will use the same engine mounts (E-W and N-S) as a 3S block (it should being an 'S'?)
If anyone has ever had a look into this before any info would be handy.
vin91
Darwin
Re: 5S & 3S blocks Sat, 08 May 2004 00:15 Go to previous messageGo to next message
I Was Wondering much the same thing but with the 2S Block and 3S Head. Would it Fit? Personally I don't see why not as most other Toyota engines have Interchangable parts.
RWDboy
Re: 5S & 3S blocks Sat, 08 May 2004 02:43 Go to previous messageGo to next message
Looks like I'm going to be investigating this one myself at the moment Smile
I did a search a while back on these forums and came up with squat.
Usually toyota engines are fairly compatible ie 4T/3T/2T, the 7A & 4A, and the K engines etc so I imagine the 'S' engines should be fairly 'interchangeable' as well...I think the nasty part comes down to making sure everything fits well.
mick
toowoomba qld
Re: 5S & 3S blocks Sat, 08 May 2004 03:23 Go to previous messageGo to next message
FWDboy wrote on Sat, 08 May 2004 12:43
I'd like to know about this myself the natsy thing about it would be to make sure it all fits well as you said I'm not sure about it my self but it may be possible Smile don't you get a better compression ratio from doing things like that?
RWDboy
Re: 5S & 3S blocks Sat, 08 May 2004 03:38 Go to previous messageGo to next message
Possibly, the 5S block may be physically taller not sure Smile It has a longer stroke I know that (90mm) and has 87mm bore (1mm more than the 3S block).
I'm in the market for a 5S block (posted in the WTB section) so I'll let you guys know how the fitting is going once I have a wrecked and/or otherwise cheap block in my hands.
It is likely that the compression ratio will be different, for sure...I'll have to measure it somehow.
mick
toowoomba qld
Re: 5S & 3S blocks Sat, 08 May 2004 07:59 Go to previous messageGo to next message
it probabally is taller as the 5S is a bigger motor, 2l (3S) as to 2.2l(5S) longer stroke and bore but not much more compared to the 3S
CamryMan
Re: 5S & 3S blocks Sat, 08 May 2004 08:44 Go to previous messageGo to next message
You can't fit a GE head on an FE S Block. It's not the same as the A series engines.
To do what you want you have to stroke a 3S-GTE with a HKS kit.
Re: 5S & 3S blocks Sat, 08 May 2004 11:33 Go to previous messageGo to next message
I understand there WAS a so-called '5SGTE kit' made in Japan in the early 90s, I've heard of it once, and know nothing else about it though, sorry!
QIK 3SGTE
Re: 5S & 3S blocks Sat, 08 May 2004 11:42 Go to previous messageGo to next message
if you want to go with the 2.2L capacity, you need to use the 5S crank in the 3S block.It is not straight forward though.
However, as a good friend(JustenGT4)pointed out to me when I was considering a 2.2L 3SGTE using the 5S crank, why didnt TTE do the same thing with there cars.
Unless you have the money to buy a genuine stroker kit ($5,000), stick with the 2L 3SGTE. It doesnt cost that much to really get them moving and they are a super tuff engine when built properly.
RWDboy
Re: 5S & 3S blocks Sat, 08 May 2004 14:20 Go to previous messageGo to next message
What's the big difference between 5S-FE head and 3S-GE head?
Apart from the obvious! I mean as in bolting one head to the other...if it's head stud spacing then I guess the idea is shot Smile
[Updated on: Sat, 08 May 2004 14:33]
mick
toowoomba qld
Re: 5S & 3S blocks Sat, 08 May 2004 16:34 Go to previous messageGo to next message
well first of all if my reply doesn't m,aker scence I"ve just come home and I'm blind drunk! Very Happy the only difference is the size of the motor and the hhead a 5S-FE is bigger then any 3S motor i thought and another was that and the head design of the FE and the GE I know for fact the 5S is bigger thenj the 3S but isn't the GE head wider then the mighty FE head? (hey i love the FE head very ecconimical and has adiquet performsance) try typing when your drunk! Laughing so wouldn't the extra width help it fit and also I thought the 3S-FE and the 3S-GE heads used the same blo0ck? as they are the same size motor 2L if they have a displacement of 1998 then they are can anyone help me on this matter?
RWDboy
Re: 5S & 3S blocks Sun, 09 May 2004 01:11 Go to previous messageGo to next message
Yeah even though they may have the same 'name' (FE) the 3S-FE and 5S-FE heads could be well different (although I'm not sure exactly why, I am going to investigate still the 5S + GE head unless someone can give me conclusive statement as to why this won't work)
The 3S-GE head will fit onto a '3S-FE' block as they are both '3S' blocks. There must be some difference between the 5S and 3S block bolting pattern/cylinder spacing, but there is still the possibility that it could be overcome with minor modification depending what is stuffed. The fact that the 5S crank can make it into a 3S block is encouraging, although not conclusive.
I'm still open to being turned away from the idea if someone has more info on this.
RWDboy
Re: 5S & 3S blocks Sun, 09 May 2004 01:18 Go to previous messageGo to next message
In regards to the 3S-GE head being wider (than the 3S-FE), the FE is really only narrower at the top of the head as the angle between the intake and exhaust ports is much narrower (due to not needing two big-ass cam gears with a belt over them) although the bottom of the head is the same width. The 3S-GE head has a much 'flatter' intake/exhaust port layout meaning it is much wider (and possibly 'shorter' but I have no proof of that).
I'm just surprised I guess that this won't work given toyota's past history of good engineering (interchangeability). Almost all their engines can be mixed and matched within the same series (T, K, A and others).
[Updated on: Sun, 09 May 2004 01:21]
mick
toowoomba qld
Re: 5S & 3S blocks Sun, 09 May 2004 01:19 Go to previous messageGo to next message
sorry guys about my reply was pretty drunk at the time god i feel queezie tis mornin um yeah what i was trying to say was that the differences would more then likly be the head desigin as ones a F head (narrow angle twin cam head) to a G head(wider sportier twin cam head) but a question of interest would be would the 3S-G(T)E head fit on the 5S block with it being wider? and also i thought that the 3S-FE 3S-GE and the 3S-GTE used the same block (thought because of the 3S because isn't that the engines family?) and to my knowledge not sure but i have never seen a 5S-GE before I've only seen the 5S-FE in the wide body camrys and celicas so thats why i think that for sorry if you couldn't understand my reply before
mick
toowoomba qld
Re: 5S & 3S blocks Sun, 09 May 2004 01:20 Go to previous messageGo to next message
FWDboy wrote on Sun, 09 May 2004 11:18
In regards to the 3S-GE head being wider (than the 3S-FE), it is really only wider at the top of the head as the angle between the intake and exhaust ports is much narrower (due to not needing two big-ass cam gears with a belt over them) although the bottom of the head is the same width. The 3S-GE head has a much 'flatter' intake/exhaust port layout meaning it is much wider (and possibly 'shorter' but I have no proof of that).
yeah I'm starting to think it won't myself
RWDboy
Re: 5S & 3S blocks Sun, 09 May 2004 01:38 Go to previous messageGo to next message
I'm still befuddled though Smile
mick
toowoomba qld
Re: 5S & 3S blocks Sun, 09 May 2004 02:09 Go to previous messageGo to next message
some ones gotta know?
RWDboy
Re: 5S & 3S blocks Sun, 09 May 2004 02:13 Go to previous messageGo to next message
If anyone has (or can get) a big-ass picture of a 5S-FE head gasket that'd be handy, cause I'm pretty sure I've got a HG for a 3S-GE lying around and I might be able to get some idea comparing them visually (although again, that won't be conclusive).
DunkyMonkey
Brissy QLD
Re: 5S & 3S blocks Sun, 09 May 2004 02:21 Go to previous messageGo to next message
hi everyone here, note the blocks on these engines are the same i think you'll find that the 5SGE is a stroked version of the 3S, and the heads are the same, its the crank shaft and pistons you need change, as for taking the pistons from the 5SFE i would say you are probably insane if you are goin to tune it i have this engine in my 184 its not as revy and does ~as much as i dislike it~ have a few missing screws, they cut back on engine internals for it. if you want a 5SGTE you can fine a stroker kit, they do exist and it will work, as long and you start with the 3SG(T)E which you obviously are as thats the engine in the 162, you may fine tho that the power gained is minimal in between the 3 to the 5 however with this being said you'll also find that the torque will increase noticably, this in the front wheel drive 162 may not have the affect that is wanted by you, its best suited the RWD cars ~IE MR2's~ how ever i stand by the idea that i will work in the GT4, the gearbox may need the looked at b4 anyplans are made!!!
hope this helps
RWDboy
Re: 5S & 3S blocks Sun, 09 May 2004 03:43 Go to previous messageGo to next message
I'm currently just looking at doing a 5S-'GE' combining the head from the 3S-GE and the 5S-FE block. But I have been told by camryman that the GE head won't fit on the 5S-F block. I only have a NA 3S-GE in my car at the moment and am looking at the possibility of a few extra cubes to help it out in a straight line. The idea of using just the crankshaft from the 5S may be dicey as it would be hard to find a piston/rod combo that won't punch through the head and provide 20:1 compression or 6:1 compression (okay I don't have exact figures, but I'm fairly sure it won't be straightforward).
Anyway, here's a pic of a 3S-GE HG so it should be comparable to the 5S-FE HG
http://members.austarmetro.com.au/~pwade/hg_small.jpg
(it's a link so click on it for a bigger picture - aren't I modem friendly Smile )
Classique71
Colac, Victoria
Re: 5S & 3S blocks Sun, 09 May 2004 04:00 Go to previous messageGo to next message
to be honest for another 200CC's is it really worth it ?
The 3sgte motor is plenty tough enough and grunty enough in its original form , though IMHO - money trying to stroke it would be better put into the likes of a decent set of forgies , st205 rods , decent bearings , head gasket , and an aftemarket ecu or turbo Highflow ..
Torguwe is good , but 200CC's wont really make a huge difference over a toughened 3sgte with greater boost potential
RWDboy
Re: 5S & 3S blocks Sun, 09 May 2004 04:17 Go to previous messageGo to next message
Well, good question Smile
Top end power wise, it will make next to dick all difference. Torque wise? It will help out a little bit. The fact is, I may be able to get a more deirable compression ratio with minimal modification and may even be able to keep the non-interference nature as well - depending on a few things.
200cc is 200cc, there may be weight differences between the engines that won't favour the 5S block, but I'm just interested to see where this can go and no one else seems to have much info on it other than "it can't be done" or "it can be done".
I don't really want a turbo engine in a fwd car just yet, but I would like to try this out to see how it ends up on a dyno (if it is at all possible!)
RWDboy
Re: 5S & 3S blocks Sun, 09 May 2004 04:20 Go to previous messageGo to next message
note : I am just looking at NA at the moment!!!! Not turbo...turbo would be a completely different story and I would agree that the 3S-GTE is a better option than a 5S-'GTE' hybrid.
Classique71
Colac, Victoria
Re: 5S & 3S blocks Sun, 09 May 2004 04:45 Go to previous messageGo to next message
Ahh ok ..
i know a 5sgte has been done before in the states with good results , havent seen a 5sge though ..
Still - have a look at the options you have in stroking - or maybe looking at better cam profiles too to liberate some grunt ..
Start small - work up Smile
RWDboy
Re: 5S & 3S blocks Sun, 09 May 2004 04:52 Go to previous messageGo to next message
I'm sorta going one step at a time, I don't want to get too far ahead of myself -> I'm hoping to start with the 5S-GE and work up from there (cams etc) Smile
I am starting to think, though, that it won't be possible as *no one* on these forums has one, and that's a pretty bad sign Confused
RWDboy
Re: 5S & 3S blocks Sun, 09 May 2004 10:03 Go to previous messageGo to next message
Well, tomorrow I'm going to go to a wreckers to see what's available in the way of stuffed/cheap 5S-FE block/engines. Maybe pick one up and see what happens...won't spend more than a couple of hundred or so, so that I don't lose too much if it doesn't work.
mick
toowoomba qld
Re: 5S & 3S blocks Sun, 09 May 2004 10:10 Go to previous messageGo to next message
I hope it does work I'm very interested in seing if it does Smile
Re: 5S & 3S blocks Sun, 09 May 2004 14:00 Go to previous messageGo to next message
for the K motors, there are different strokes and bores.
increasing stroke comes with a taller deck height. bore spacing is the same for all. the bigger motors have wider skirts to fit the crank in.
fwiw, between 3K (1200cc) and 4K (1300cc) the difference is 10mm deck height.
grab a 3S and 5S gasket from wherever, line em up. make sure oil and head bolt holes line up.
then find pics of the front of the motors (or better yet, tak your own pics) and make sure timing covers/gears/belts ans shit will swap over nicely.
what you wanna know is if the bore spacing is the same (likely), if the stroke/deck height is the same, if the front bits can bolt on.
if crank is bigger, but deck height is same, then you can swap easily, if not you need shorter rods or pistons with lower pin height.
you also want to check if the pistons are dished/dome and what volumes they are, and also the combustion chamber volumes etc..
in the K series, the 4K has a flat top and dished piston version, and 5K/7K are dished.. which makes direct swaps more interesting..
anyhoo, don't get put off just cos no-one else knows Wink
take a 3S gasket to a wrecker (u-pull-it type) and rip the head off a 5S Very Happy , measure deck heights etc...
RWDboy
Re: 5S & 3S blocks Sun, 09 May 2004 14:34 Go to previous messageGo to next message
The cylinder spacing would be the same as 5S cranks have gone into 3S blocks before so that shouldn't be an issue, however, bolt holes and water/oilways are the trick.
The timing belts will be slightly different as the 5S-FE has a narrow head that only has one cam gear running off of the crank, whereas the 3S-GE has the two gears driven by the crank.
Pistons in 3S-GE have 'dome' type layout (sorta cut-outs for the valves). The 3S-GE pistons are probably the go as the angle between the valves on the 5S-FE head are different and hence the cut-outs for the valves will not match the head if I use 5S-FE pistons.
(yes - I've thought quite a bit about this)
Basically I'm going to go grab a 5S-FE HG tomorrow and match that up maybe, or take my 3S-GE HG around to the wreckers and check it all out on the 5S-FE head.
Still wouldn't mind someone posting up a pic of a 5S-FE head gasket though Smile
Cheers for the advice - I do need to check out the combustion height and volume, but unfortunately I haven't had the time to take my 3S-GE head off.
TerryOBeirne
Redbank Plains,near Ipswi...
Re: 5S & 3S blocks Mon, 10 May 2004 01:20 Go to previous messageGo to next message
all S blocks I have seen have the same deck pattern which means the GE head should physically fit. the big differences are the water galleries on the F head are totally different so you have to use the correct gasket for the HEAD . The compression will be higher and you will have to carve out the chamber to get it right-this is not easy as there is not a lot of spare metal to work with
RWDboy
Re: 5S & 3S blocks Mon, 10 May 2004 06:55 Go to previous messageGo to next message
Yeah, so far my investigations haven't lead to anything conclusive. I can say though, that I'm sure the 3S-GE/FE heads will fit onto a 2S block...however, the 3S-GE pistons must be used (again, to suit the valves as the 2S pistons are 'dish' type) this means the 2S block should be bored. Also the correct gasket must be used.
If the 2S is in a RWD car though, you may struggle, as the intake manifold and dizzy/water junction will all probably foul on the firewall or brake booster stuff!
As for the 5S-FE/3S-GE combo, it may be possible. I have found an ST184 in a u-pull-it wreckers and the car is absolutely burnt to the ground yet the engine still looks like it may be useful for test fitting stuff.
The only question mark so far is that in a catalogue for the head gaskets, the 5S-FE head gasket seemed to be the upside down diagram of the 3S-GE gasket (slight water gallery differences, but they are head related I think, not block related), so who knows whether that means anything or not I guess I'll find out soon enough as....
....I'm pretty confident this will work, on Thursday I'm going to spend a few hours at this wreckers trying to convince the engine to come with me then I will once and for all know whether this is possible.
At this stage, I'm saying 'yes' it is.
As for the compression issues? I'm hoping that maybe a 1.5mm copper head gasket can help, plus maybe machining some of the piston? (can this be done with pistons with the valve cut-outs?)
Will give more info on this on thursday!
RWDboy
Re: 5S & 3S blocks Mon, 10 May 2004 13:19 Go to previous messageGo to next message
I've read that this has been done with earlier 5S-FE (as in pre 1992) but not the later model 5S-FE as they changed the oilways/water galleries. As in, get a 5S-FE off of a 1990-1992 camry or something?
I'm getting alot of conflicting info Smile
RWDboy
Re: 5S & 3S blocks Mon, 10 May 2004 13:34 Go to previous messageGo to next message
I read that they added a pair of balance shafts in the oil pan driven by the crank as well in the '93 onwards? Has anyone got any good links to the history of the 5S-FE? I've searched for a while but no real luck.
(edit)
Okey dokey, rather than post whore I thought I'd ammend this post, after an hour of searching thru www.alldata.com I've discovered that in May 1995 (or thereabouts) there was a technical bulletin about changing the engine cylinder head/block...
So anything from a 1990-1994 Celica may be the go! (again, I will confirm this Thursday!)
(/edit)
[Updated on: Mon, 10 May 2004 14:09]
DunkyMonkey
Brissy QLD
Re: 5S & 3S blocks Mon, 10 May 2004 21:14 Go to previous messageGo to next message
the head on the 5S-FE is shit yes, but it also was cut back on other engine internals, it just about impossible to get a 5s-FE to a 5s-GE, if you want a 5S-GE, you have to storke a 3S-GE engine, and i would surgest doin this with proper stroking kit, how ever it has been done by inserting the crankshaft and pistons from the 5S-FE engine, this is highly not recommended tho.
RWDboy
Re: 5S & 3S blocks Tue, 11 May 2004 02:30 Go to previous messageGo to next message
Okay - first of all, the head on the 5S-FE is not exactly shit - it was designed in a certain way to get fuel economy out of it.
Secondly - using the 5S-FE pistons is a bad idea, as the crown on the 5S-FE pistons is *completely* different to the crown on the 3S-GE pistons and given the different angle of the valves in the head, it would be a bit of a pain to use the 5S-FE pistons.
Thirdly, the crankshaft on the 5S-FE is reputedly stronger than the crankshaft from the 3S-GE - I have nothing to back that statement up though, however you have to recognise that it was developed a couple of years after the 3S-GE so it is likely that it is better constructed.
But, if you have attempted and/or done this 'conversion', I'd love to hear of any actual figures/problems that you may have encountered Smile
(edit)w00t! just hit forums junkie(/edit)
[Updated on: Tue, 11 May 2004 02:33]
DunkyMonkey
Brissy QLD
Re: 5S & 3S blocks Tue, 11 May 2004 02:46 Go to previous messageGo to next message
sadly and scary it has been done i found this out when i was looking up engines for for my ST184, ~i desided that it best to keep this one NA and i shall have fun with twin turbo supra later on in life.~ most of the information you'll find of use on this will be on a MR2 site that i seem to have misplaced, there is also another strand on in this section that i posted alittle while back
http://forums.toymods.org.au/index.php?t=msg&t h=32871&rid=5178&S=b2f859b03d1534230e9e406 62ab9c1fe&pl_view=&start=0#msg_288516
another thing i would be worried about is putting the rather large amounts of torque and power that can be gain from this engine thru a FWD.
good luck with what ever you deside on
RWDboy
Re: 5S & 3S blocks Tue, 11 May 2004 03:03 Go to previous messageGo to next message
Cheers for that actually!
I can understand if the 5S crank may not be as good as the crank from a 3S-GTE. It seems like the biggest pain in the arse is the whole compression ratio.
I'm not really worried about the torque, seeing as I'm just doing NA at the moment, even if the compression ratio ends up being better than 9.0:1 (like 9.5:1 or 10:1) and I end up with 190-200Nm of torque, it's not earth shattering.
How can you 'test' the strength of a crank? I imagine the crank wouldn't survive any strength testing procedure Smile
DunkyMonkey
Brissy QLD
Re: 5S & 3S blocks Tue, 11 May 2004 03:14 Go to previous messageGo to next message
well the a stock 5S-FE will put out 196Nm, but i wasn't aware that you were keeping it NA, in that case i would be worried that much about it, but if you read the other strand they basically said don't be a lazy prick and do it properly with a stroking kit, there is also a link on the other strand which says where you can get a stroking kit from.
best of luck FWDboy
RWDboy
Re: 5S & 3S blocks Tue, 11 May 2004 03:47 Go to previous messageGo to next message
Does anyone want to place bets on the chances of me getting the block/sump/one piston and conrod out of a near burnt to the ground ST184 within 3 hours Smile
I'll give 3-1 odds (j/k).
Yeah - the stock 5S-FE puts out 196Nm of torque, but I'm sort of accounting for the fact that the 3S-GE isn't tuned amazingly well and probably will only just get around about those figures - I'm also predicting that I won't get a huge power increase either - as the real power generally comes from the cylinder head and with only 1-2mm larger bore I'd be surprised if I get much more than 3-5kW if the compression ratio stays the same (I'm hoping to 'adjust' the compression ratio in favour of more power/torque at the expense of having to run 98 octane)
DunkyMonkey
Brissy QLD
Re: 5S & 3S blocks Tue, 11 May 2004 04:10 Go to previous messageGo to next message
ummmm i dunno how to say this but you'd be lucky to get any real gain in power with out tuneing it properly, you will get more torque then you think tho, extra displacement will usually give you more torque, i wouldn't be supprised if it decreases your rev-ability as the redline in the 5S-FE is like 6.2, but then again the 3S-GE has a much beta set of cams on it.
i would love to see what comes out of the new engine if you choose to go ahead with it.
RWDboy
Re: 5S & 3S blocks Tue, 11 May 2004 04:34 Go to previous message
Well, I imagine the redline on the 5S-FE is partly to do with the head...but I'm hoping to keep reciprocating mass to a minimum (ie keep it as close as possible to the 3S-GEs reciprocating mass so the redline is ~ equal).
As for tuning it properly, the 1st gen 3S-GE has a fairly hard-wired ecu (not EPROM or flash etc) so it would be best to get a replacement ECU. I don't quite have the funds to stretch that far, but that may happen later.
I'll probably post any more updates on my cars' thread in the members rides section.
Previous Topic:King Springs
Next Topic:18r into an sa63, yes/no?
Current Time: Mon Oct 26 18:34:19 UTC 2026
Total time taken to generate the page: 0.062868118286133 seconds
