Toymods » Tech & Conversions » S/chargers and capacity
clubagreenie
1st street on the right
S/chargers and capacity Fri, 07 May 2004 13:05 Go to next message
A SC14 is suitable for up to about 2 lt yes?
Would it be correct to say that you could use two to feed a 3.5 lt V8, one per bank feeding through two carbs or throttle bodies or inj setups?
just curious
ed_ma61
Lost in the K hole
Re: S/chargers and capacity Fri, 07 May 2004 14:12 Go to previous messageGo to next message
justin...
its a bloody v8! whack an eaton on it ffs!! thats what the 'V' was designed for Nod
Re: S/chargers and capacity Fri, 07 May 2004 14:36 Go to previous messageGo to next message
nahh, go all out with two Eaton M90's Very Happy heh heh
surely if you are going to that effort there'll be some charge cooling?
SC14 is suitable for 2L for stock boost, but how much more?
1.4 x 2 x SC drive ratio / 4 = boost.
Fruitloop
Re: S/chargers and capacity Fri, 07 May 2004 21:48 Go to previous messageGo to next message
Ya formula isn't quite correct.Ya forgot the basic principle of what the engine is "four stroke" (only draws half the capacity per Rev..)
Gotta agree with ed_ma61 comments regards going for a Eaton.MP90 as opposed to the MP62..not as much parasitic drag for the same volume and the availabilty of bigger boost (hp and torque)(if wanted)at lower Revs.
clubagreenie
Re: S/chargers and capacity Fri, 07 May 2004 23:44 Go to previous messageGo to next message
Eaton 62 or 90 $2800 plus extras
SC14 a few hundred each
Hmmmmmm
Just thinking for price difference, Would be used at just std boost. and would an eaton blow 4 or 8 throttle bodies?
Fruitloop
Re: S/chargers and capacity Sat, 08 May 2004 07:32 Go to previous messageGo to next message
If ya go to GMH the blower price is a lot,lot less..(blowers for 3.8's) Plus setting up for 2 blowers is a pain in the ....not to mention the amount that you will have to spend on manifolds,Belts etc,etc..BTW what 3.5 is it for ?? If its for a toyota 4v engine forget it ..the dizzy is in the way..
clubagreenie
Re: S/chargers and capacity Sat, 08 May 2004 07:40 Go to previous messageGo to next message
Ok it's for a rover V8, going into a Range rover. Just an idea at this stage but there's plenty of room for two.
Not withstanding the difficulties etc, is my assumption correct that two would keep up with the needs of 1/2 a 3.5lt?
Fruitloop
Re: S/chargers and capacity Sat, 08 May 2004 08:03 Go to previous messageGo to next message
clubagreenie
Yep your assumption is correct ....I'm sorry if I sound negative about doing it,but I tend to work to the K.I.S.S. principle
Keep It Simple Stupid.! One Blower for one motor..Tends to make things not as complicated or time comsuming,regards specialist (read 1 off is costly)tooling,brackets,etc.etc.and also not having to blue-print both blowers for clearances (no point in having 1 blowing out the other)
I think ed_ma61 summed it up as politely as possible by saying use 1 (a big 1 for future upgrades)
Re: S/chargers and capacity Sat, 08 May 2004 08:05 Go to previous messageGo to next message
Fruitloop wrote on Sat, 08 May 2004 07:48
LOL Laughing , my apologies Wink
a guy on ebay had a new M90 for about $600 a little while back...
and yes, two SC14's should be fine capacity wise...
ed_ma61
Lost in the K hole
Re: S/chargers and capacity Sat, 08 May 2004 09:52 Go to previous message
as above - have seen the odd m90 pop up for 600odd USdollaro's on ebay... worth looking out for.
then again, it IS going in the fourby, how much effort you want to put into the engine? do the heads on the engine, port it and put a decent carb and be done with it... thats my 2c
Previous Topic:ST202 engine into a ST162
Next Topic:W55 gearbox case halves - torque setting
Current Time: Thu Oct 15 11:04:20 UTC 2026
Total time taken to generate the page: 0.0064260959625244 seconds
