Toymods » Tech & Conversions » AE82 and LSD for 20Valve
Kingos
Central Coast
AE82 and LSD for 20Valve Mon, 26 August 2002 09:58 Go to next message
I will be in Japan on Wednesday and im looking at
picking up a 4AGE 20 valve black top or Silver top.
Do either come standard with an LSD box ? If not.
Is there an LSD box available with the 4AGZE?
If so is it to possible to use GZE box on the 20 valve ?
Would the GZE box improve or reduce performance?
thanx.
Any suggestions.
MaNGeW
Formerly TRD_RoLLa
Re: AE82 and LSD for 20Valve Mon, 26 August 2002 10:31 Go to previous messageGo to next message
I believe that LSD is not a standard item but a factory option. You may find one with an aftermarket LSD. As for performance issues. Well the GZE and 20V boxes have slighty different gear ratios matched to their power band. Do a search for the ratios.
There are also 6 speed gearboxes too. Rolling Eyes
haggis
Re: AE82 and LSD for 20Valve Mon, 26 August 2002 10:45 Go to previous messageGo to next message
If you can find a 6 speed, grab it. they are like hens teeth! They come on the black top from what i know...
If you find two, i'd like one!
Craig.
Kingos
Central Coast
Re: AE82 and LSD for 20Valve Mon, 26 August 2002 14:48 Go to previous messageGo to next message
Could anybody tell me if the blacktop box is suitable for the silvertop... results for performance etc
Lucid
Toymods Club Secretary
Re: AE82 and LSD for 20Valve Mon, 26 August 2002 19:51 Go to previous messageGo to next message
AFAIK, it should fit straight up to the silvertop, but fitting it into the car might be a bit trickier. (have read that some modification is required to fit it into an AE92, so i'd assume that the same is true for an AE82).
Performance-wise it would be all good though. Nod
[mikey]
Re: AE82 and LSD for 20Valve Mon, 26 August 2002 21:25 Go to previous message
Blacktop is a longer box because of the sixth ratio. They will both fit. The E51 (GZE box) is not a straight fit and weighs around 22kg more than the 20V boxes....20V boxes have a shorter final drive of around 4.5:1, so thats what you want. You can tell its LSD by spinning both shafts , they should spin the same way in neutral. And you need the Driveshafts too, the Inner CV joint is different on the LSD box.
Michael.
Previous Topic:Crossflow head ??
Next Topic:2TG cams?
Current Time: Fri Nov 20 05:59:29 UTC 2026
Total time taken to generate the page: 0.0070569515228271 seconds
