Toymods » Tech & Conversions » SC14spinning backwards?
VL_Commy
SC14spinning backwards? Sat, 08 May 2004 08:44 Go to next message
Ok guys, i have an SC14, that i want to put on my honda civic. Now the problem arises that honda engines spin in the wrong direction. will the SC14 still work spinning the opposite way to normal if i just change which side i use as inlet and outlet?
Re: SC14spinning backwards? Sat, 08 May 2004 08:49 Go to previous messageGo to next message
No.
V8_MA61
Re: SC14spinning backwards? Sat, 08 May 2004 13:17 Go to previous messageGo to next message
just put a turbo on it...i dont see why youd want to put a toyota blower on it...doesnt exactly work prefect in conjunction with their VTEC system.
[Updated on: Sat, 08 May 2004 13:27]
JDM hachi
was adelaide now newcastle
Re: SC14spinning backwards? Sat, 08 May 2004 23:20 Go to previous messageGo to next message
Quote:
No
(100 stars for largest quote of the year!!!)
anyhoo, why would this be?, i assume it would work but probably not to the best of its abilities.
what type/model of civic is it going on.....space may prove a bigger problem.
matty.
Necros
Re: SC14spinning backwards? Sat, 08 May 2004 23:48 Go to previous messageGo to next message
Just an idea, but if your going to all the trouble of fitting a supercharger to your car obviously your will need to fabricate brackets and possibly another pulley on the crank to goto the charger.
Why not run two extra pulleys, one above the charger one below so the belt runson the other side of the s/c pulley.
Talk to an engineer, im sure you could come up with a better idea than running the charger backwards.
TheGecko
Re: SC14spinning backwards? Sun, 09 May 2004 12:35 Go to previous messageGo to next message
SC12/SC14 are Rootes type superchargers. They are air pumps. If you run a pump backwards it pumps the other way. I don't know how easy it is to swap in and out on the Toyota SC's. The other problem may be the gearing that joins the two rotors - it probably won't like turning backwards (helical cut gears and reversed thrust angles = bad).
As others have suggested there may be solutions involving reversed drives etc but why torture yourself - just put a turbo on it.
Allan
Re: SC14spinning backwards? Sun, 09 May 2004 12:41 Go to previous messageGo to next message
better yet piss off the honda and get a toyota Smile
VL_Commy
Re: SC14spinning backwards? Thu, 27 May 2004 02:30 Go to previous messageGo to next message
ok well i finally found this thread again.
http://home.iprimus.com.au/terryallen/sc12open.jpg
this shows the gears of an sc12. If i switched the sides that the gear are on and ran the unit backwards, would it be fine then??
the car is a 1981 2nd gen civic. Theres enough room to mount the blower, but the damn engine spins the wrong way.
[Updated on: Thu, 27 May 2004 02:32]
SeptemberSquallIndustries
Re: SC14spinning backwards? Thu, 27 May 2004 10:30 Go to previous messageGo to next message
From CAA?
V8_MA61
Re: SC14spinning backwards? Thu, 27 May 2004 10:32 Go to previous messageGo to next message
why would u bother with a 1982 civic..no offense!
Cant your money be better spent?
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: SC14spinning backwards? Thu, 27 May 2004 10:47 Go to previous messageGo to next message
Swap the gears all you want, they drive the rotors which compress the air to give you boost. now these rotors are designed to spin ONE way and one way only.... So running them backwardas is fraught with danger.
S
VL_Commy wrote on Thu, 27 May 2004 12:30
EMP-2TG
Carlingford, Sydney
Re: SC14spinning backwards? Thu, 27 May 2004 11:17 Go to previous message
just do it and send us pic when u have Smile
1 way to try things....
Previous Topic:sc14 pics and info
Next Topic:targa top celica
Current Time: Mon Oct 19 17:05:02 UTC 2026
Total time taken to generate the page: 0.11867117881775 seconds
