Toymods » Tech & Conversions » Where to mount EGO sensor?
Where to mount EGO sensor? Sat, 08 May 2004 23:45 Go to next message
On the factory ST205 dump pipe the EGO sensor is about 25mm away from the turbine of the turbo.
On my new dump pipe should I mount it in the same position or am I able to mount it down the dump pipe a little?
Any ideas? Thanks
YelloRolla
On your mum!
Re: Where to mount EGO sensor? Sat, 08 May 2004 23:47 Go to previous messageGo to next message
Before the turbo is the best (IMO). I think that you can mount it behind the turbine tho.
Re: Where to mount EGO sensor? Sat, 08 May 2004 23:50 Go to previous messageGo to next message
Before the turbo? I've never seen this done.
YelloRolla
On your mum!
Re: Where to mount EGO sensor? Sun, 09 May 2004 01:54 Go to previous messageGo to next message
Sorry Cool 1 - EGT sensor is usually before the turbine. Confused
Should have thought more before engaging the typing fingers.
Re: Where to mount EGO sensor? Sun, 09 May 2004 03:14 Go to previous messageGo to next message
if it's single wire O2 sensor then close to the turbo - otherwise may gases my vary too much in temo. but if it' a heated unit (3 or 4 wire) then further on is OK.
i was going to put a 4 wire at the bottom of the headers on the 5ME. with suitable 12V source, proximity to engine (for heat) not as much of an issue.
on the 1G, the O2 sensor is just at the join of the two turbo dumps - maybe 4-6 inches from the exh turbines.
Re: Where to mount EGO sensor? Sun, 09 May 2004 08:15 Go to previous messageGo to next message
Thanks chuck. The sensor I have is a 4 wire heated item.
Cressida Chick
central coast, NSW
Re: Where to mount EGO sensor? Sun, 09 May 2004 08:19 Go to previous messageGo to next message
Shane, don't mount the EGO sensor too close to the SENSITIVITY sensor or the CARE-O meter or the EGO may get bruised Razz
Re: Where to mount EGO sensor? Sun, 09 May 2004 08:22 Go to previous messageGo to next message
Umm ok, thanks for that.
Rolling Eyes
Cressida Chick
central coast, NSW
Re: Where to mount EGO sensor? Sun, 09 May 2004 08:28 Go to previous messageGo to next message
Cool1 wrote on Sun, 09 May 2004 18:22
cool Cool was wondering if you had any pictures of your frogs doing the wild thing??? Rolling Eyes
Rolling Eyes
Cressida Chick
central coast, NSW
Re: Where to mount EGO sensor? Sun, 09 May 2004 08:29 Go to previous messageGo to next message
[quote title=missrolla wrote on Sun, 09 May 2004 18:28][quote title=Cool1 wrote on Sun, 09 May 2004 18:22]Umm ok, thanks for that.quote]
Rolling Eyes
Re: Where to mount EGO sensor? Sun, 09 May 2004 09:50 Go to previous messageGo to next message
For the sake of the frogs privacy, I have to keep the pictures under lock and key.
[Updated on: Sun, 09 May 2004 09:50]
Re: Where to mount EGO sensor? Sun, 09 May 2004 12:24 Go to previous messageGo to next message
since it is heated, you can put it a fair way from the turbo.... a few feet would be fine..
theoretically the heater provides enough heat to keep it hot at idle on an NA car, so i would be confident putting it further away fromt he turbo.
Re: Where to mount EGO sensor? Sun, 09 May 2004 12:31 Go to previous messageGo to next message
Great, I might do that. I only wanted to move it about 8 inches down the pipe anyway.
Darkstar
Ebbw Vale, Qld
Re: Where to mount EGO sensor? Tue, 10 May 2005 22:40 Go to previous messageGo to next message
I'm making a custom manifold and was wondering if i could mount the sensor before the turbos, on the manifold?? Don't see why not, but please tell me if this won't work
Darkstar
Ebbw Vale, Qld
Re: Where to mount EGO sensor? Wed, 11 May 2005 08:33 Go to previous messageGo to next message
Anyone got any suggestions??
Re: Where to mount EGO sensor? Wed, 11 May 2005 09:55 Go to previous messageGo to next message
Darkstar wrote on Wed, 11 May 2005 08:40
it will most likely get too hot and die a quick death. put it after the turbo.
Darkstar
Ebbw Vale, Qld
Re: Where to mount EGO sensor? Thu, 12 May 2005 23:31 Go to previous message
OK thanks for that advice. Will do
Previous Topic:compatability question
Next Topic:Overboosting ST185
Current Time: Sat Oct 17 10:52:43 UTC 2026
Total time taken to generate the page: 0.17581582069397 seconds
