Toymods » Tech & Conversions » 4age blowing smoke..now with video
thekemist
melbourne,australia
4age blowing smoke..now with video Sun, 09 May 2004 08:20 Go to next message
well my 100kw motor blows a hell of a lot of smoke when i rev it. its white smoke so i know thats no good. What should i do. how much will it cost.. i want to keep my car for maybe another 2years so is it really worth rebuilding the whole engine.. how much will it cost roughluy.. or should i throw in a second hand motor (import) .. how much would that cost
opinions on what i could do?
[Updated on: Mon, 17 May 2004 21:49]
SW20R
Re: 4age blowing smoke.. what to do?? Sun, 09 May 2004 09:10 Go to previous messageGo to next message
your valve stem seals are shot
not really a big job but around 150-250?
if it still goes hard and nothing else is wrong with it keep it.
thekemist
melbourne,australia
Re: 4age blowing smoke.. what to do?? Sun, 09 May 2004 09:20 Go to previous messageGo to next message
so if thats all it is why do i get told that it needs a rebuild etc. are u telling me that if i replace these seals that it will stop blowing smoke
V8_MA61
Re: 4age blowing smoke.. what to do?? Sun, 09 May 2004 09:24 Go to previous messageGo to next message
sorry to rain on the parade...but once you take the head off to fix them...you have to include the parts which also need to be replaced.
Note: you "can" change stem seals with the head on, if you think youre good enough.
I'd be doing a compression test amoungst others before juming to conclusions. it could be one of many things possibly wrong with it. IS there water in the oil/ vice versa? (sorry..had to ask..)
Count on $1500 to rebuild the motor if u do it all yourself.
[Updated on: Sun, 09 May 2004 09:29]
YelloRolla
On your mum!
Re: 4age blowing smoke.. what to do?? Sun, 09 May 2004 09:26 Go to previous messageGo to next message
That's a hasty diagnosis. It is hard to tell if it is just valve stem seals by the description, they tend to show after some idling or vacuum condition.
SW20R
becuase your opening up the engine.. you might aswell get it right and do all of it for reliability
get a compression test done see how the results are they would help you decide on what todo.
otherwise if it all seems good then its probably just the seals.
are you burning alot of oil?
IRA11Y
Club Member
Re: 4age blowing smoke.. what to do?? Sun, 09 May 2004 10:39 Go to previous messageGo to next message
Im with yellowrolla, frankly i doubt it to be valve stem seals, its more likely youve blown the head gasket with white smoke indicating water is mixing in the combustion chamber somehow.
IME worn stem seals will blow a little bluish smoke after idling for a while then drive off or if you floor it after coasting or as YR puts it ....
mick
toowoomba qld
Re: 4age blowing smoke.. what to do?? Sun, 09 May 2004 12:15 Go to previous messageGo to next message
yes i agree with yellowrolla and IRA11Y as well because when the valve steams seal are worn it will blow a bluish smoke like IRA11Y said especally when alowing the engine to idle for a few minutes and then opening the throttle if the seals are worn or damaged a disarge of bluish smoke can be seen from the exhaust but I have seen some cars under the hammer blow a blackish grey smoke whats that mean? followed this xd for a kilometer and evry time he gave it a bootful i notice this from his car and thought ok that can't be a good sign for that car
V8_MA61
Re: 4age blowing smoke.. what to do?? Sun, 09 May 2004 12:21 Go to previous messageGo to next message
if its stem seals blowing blue smoke will only be when you first start the car. As when they are stuffed, oil builds up at the base of the valve,and stays there...when the car is fired up again, it blows the smoke to signal burnt oil. It will NOT happen when the enging has been running and there is oil up circulating in the head.
takai
Re: 4age blowing smoke.. what to do?? Sun, 09 May 2004 12:22 Go to previous messageGo to next message
Thats just unburnt fuel from it running too rich. My 4A used to do that.
V8_MA61
Re: 4age blowing smoke.. what to do?? Sun, 09 May 2004 12:23 Go to previous messageGo to next message
running to rich = black smoke generally
thekemist
melbourne,australia
Re: 4age blowing smoke.. what to do?? Mon, 10 May 2004 06:25 Go to previous messageGo to next message
for the case of a car running to rich
how do u stop it from running to rich,...; what does running rich mean exactly
FKN16V
NSW, East Coast
Re: 4age blowing smoke.. what to do?? Mon, 10 May 2004 07:05 Go to previous messageGo to next message
thekemist wrote on Sun, 09 May 2004 18:20
How's the colour of your water, does it seem to use a bit of water. Put a sniffer on to it. Any compident mechanic or radiator shop will have one or something similar.
Steve
V8_MA61
Re: 4age blowing smoke.. what to do?? Mon, 10 May 2004 07:44 Go to previous messageGo to next message
thekemist wrote on Mon, 10 May 2004 16:25
Rich = too much fuel in the air/ fuel mixture ratio. Unburnt fuel turns comes out as black smoke, not the most pleasant smelling. is your car carby or efi ?
thekemist
melbourne,australia
Re: 4age blowing smoke.. what to do?? Mon, 10 May 2004 12:06 Go to previous messageGo to next message
its efi
as for the other question no it doesnt really use that much water. radiator is always at capacity.
i just want to work out whether its a big major problem or something smaller which means that i dont need to take my whole engine part etc etc ive seen cars click over way more kms than mine without blowing smoke apart from that ive never had a prob with it
SPRINTAH!
Re: 4age blowing smoke.. what to do?? Mon, 10 May 2004 13:00 Go to previous messageGo to next message
just rebuild the whole engine.
gasket kit: $250 ish from memory
main bearings ~$30
big end bearings ~$30
piston rings ~ $60?
and your cheering.
you could get the block and head decked and chemical cleaned for like $250 ish or get it bored and honed slightly and get some new pistons.
all of this should cost less than another motor, this is assuming you assemble/disassemble yourself, not hard at all with a workshop manual. bang it all back together and it will last ages.
im guessing it will be a combination of both stem seals and rings, if its still running ok i doubt it is the head gasket.
V8_MA61
Re: 4age blowing smoke.. what to do?? Mon, 10 May 2004 13:09 Go to previous messageGo to next message
um rings are gonna be about $150
bearings more like about $70 rod
$90 main
Thats if you buy ACL stuff, which i strongly reccomend.
SPRINTAH!
Re: 4age blowing smoke.. what to do?? Mon, 10 May 2004 13:31 Go to previous messageGo to next message
well mine wern't
they were about $30
this is for a smallport 4ag
ACL as well
i didn't buy rings seperate coz they came with my pistons.
ACL, not forged or anything - $200
so $150 for rings is expensive in my book
thekemist
melbourne,australia
Re: 4age blowing smoke.. what to do?? Tue, 11 May 2004 01:58 Go to previous messageGo to next message
OK well i think i wouldnt mind rebuilding the car if its not going to cost that much.. this is what i would like you guys to do if possible. i have a friend whos dad is a manager at repco and he can give me a pretty generous discount if i order thru him. so if possible could anyone list me the parts i would need to rebuild the engine with how many etc if possible the model numbers etc and i will try get a quote from my mates dad and then see how much it will cost me.
its for the 100kw 4age motor out of 89 corolla sx
thekemist
melbourne,australia
Re: 4age blowing smoke.. what to do?? Sat, 15 May 2004 07:18 Go to previous messageGo to next message
i have movies of the smoke blowing to show u the extent of the problem they are about 1.3mb dont know how to post them up tho
dingaling
tas
Re: 4age blowing smoke.. what to do?? Sun, 16 May 2004 11:30 Go to previous messageGo to next message
if your not losing coolant, and the smoke is white, i'd quite bieng paranoid about it. It's most likely evaporating water in the tailpipe. Get them video's posted up somewhere and you will get a better opinion.
Does the car continue to smoke after a good drive?
thekemist
melbourne,australia
Re: 4age blowing smoke.. now with video Mon, 17 May 2004 12:27 Go to previous messageGo to next message
hosted the videos
could u guys download them instead of streaming the videos if u can help it. they are only 1.3mb so it shouldnt be a problem for most of u
appreciate it thanks
Movie 1
Movie 2
Arch
Re: 4age blowing smoke.. what to do?? Mon, 17 May 2004 12:45 Go to previous messageGo to next message
man thats alot of smoke Confused
my 4age is doing this too, but only a bit, and only at high revs
HighRolla
Re: 4age blowing smoke.. what to do?? Mon, 17 May 2004 12:52 Go to previous messageGo to next message
wow! Does it use a shit load of oil, or water?
Looks like you'll have to pull the head off (minimum) and have a look around. Probably drop the sump also so you can undo and pop pistons out the top. Has this smoke just started or has it gradually got worse?
thekemist
melbourne,australia
Re: 4age blowing smoke.. what to do?? Mon, 17 May 2004 14:07 Go to previous messageGo to next message
it uses a fair amount of oil.
but water ive never had a prob with
it has just over time got worse
roadrunner
Hornsby, Sydney
Re: 4age blowing smoke..now with video Tue, 18 May 2004 09:17 Go to previous messageGo to next message
take it to a mech. it looks like either excessive oil smoke, ie. a popped piston or cracked head, or really excessive over fuelling. how does it run? have you driven it with this issue? how does it drive (power under load) has it lost power? does it make any noises? is it hard to start?
thekemist
melbourne,australia
Re: 4age blowing smoke..now with video Tue, 18 May 2004 09:59 Go to previous messageGo to next message
yeh ive driven it while it smokes kinda glad i havnt been stopped by any cops yet
i havnt driven it in two months cos i have a broken arm but when i was driving the engine didnt seem to be struggling when i do rev it it still feels smooth im sure it has lost power tho because it feels that for the amount of revs its doing it just doesnt have the pull that u think u would get(is that what u mean by power underload).... ill have to check it out once im able to start driving in a few weeks but im just trying to get a few ideas of what to do in the mean time
twincam_ke20
Castlemaine Vic
Re: 4age blowing smoke..now with video Tue, 18 May 2004 12:12 Go to previous messageGo to next message
my SX is doing the same bloody thing, on start up its like yours in the videos, let it warm up for 5-10mins and its fine, then when ya give it a boot full it smokes more, but not as much as on start up.
mine doesnt use oil or water. Can ya do the valve stem seals with out removing the motor? and does anyone have a part number etc for them?
HighRolla
Re: 4age blowing smoke..now with video Tue, 18 May 2004 12:27 Go to previous messageGo to next message
ACL seals:
PA 425 - 48 (I think the 48 may refer to quantity - so you only need 16)
Go to the ACl website and look for preferred stockists. Dont pay more than about 30 bucks for the seals.
Can do them with engine still in car. I'm even going to attempt it with the head still on someday Razz . Guys on the forum have done it. If you take the head of it would be a piece of cake..but its the other stuff im worried about.
you would think it would be using oil though. Leaky or malfunctioning injector?
ed_ma61
Lost in the K hole
Re: 4age blowing smoke..now with video Tue, 18 May 2004 13:49 Go to previous messageGo to next message
doesnt look like oil to me (and youd have to be burning a fuckload to produce that cloud)
a rich mixture is back
water?
SW20R
Re: 4age blowing smoke..now with video Tue, 18 May 2004 15:15 Go to previous messageGo to next message
do you leave your car parked outside?
the grass seems icey..
cars with large tips usually do this at start up or when its cold
oh yeah get rid of the cannon man its soo ricey Laughing
get the traditional mufflers with the growls not the fart
thekemist
melbourne,australia
Re: 4age blowing smoke..now with video Wed, 19 May 2004 02:02 Go to previous messageGo to next message
large tip????? ... its the stock exhaust/muffler the one with the twin tips so im not sure where u got your cannon muffler idea from. i do leave my car outside but i dont think its because of the cold air
SW20R
Re: 4age blowing smoke..now with video Wed, 19 May 2004 02:21 Go to previous messageGo to next message
ahh it looked like a big cannon from the side sorry
have you checked your spark plugs? this happened to my brothers car before.. not sure exactly what the remedy was
monkeymajik
Re: 4age blowing smoke..now with video Wed, 19 May 2004 03:00 Go to previous message
That's alotta smoke
Previous Topic:AE86 Dash Removal
Next Topic:ke20 engine mounts help!!!
Current Time: Sun Nov 1 11:15:26 UTC 2026
Total time taken to generate the page: 0.021960020065308 seconds
