Toymods » General Car Talk » 1998 Toyota Supra RZ [844 rwhp / 1156 hp @ flywheel]
magicmitch
Sydney, Shire
1998 Toyota Supra RZ [844 rwhp / 1156 hp @ flywheel] Sun, 09 May 2004 14:38 Go to next message
http://www.ridejudge.com/RideDetails.asp?RideID=11 128&PicID=0
hey guys
i found this supra on ridejudge and i noticed he is a aussie...just wondering if any of ya's know of this weapon or have seen it and what not?
Stenno
Re: 1998 Toyota Supra RZ [844 rwhp / 1156 hp @ flywheel] Sun, 09 May 2004 21:12 Go to previous messageGo to next message
http://www.to4r.com/members/mikecarlin.html
Oooops Wink
Not an aussie, just a wannabe.
Caledwvech
Re: 1998 Toyota Supra RZ [844 rwhp / 1156 hp @ flywheel] Mon, 10 May 2004 00:44 Go to previous messageGo to next message
Yum. Nice power curve as well. Not some idiotic thing that is just for dynos.
ed_ma61
Lost in the K hole
Re: 1998 Toyota Supra RZ [844 rwhp / 1156 hp @ flywheel] Fri, 14 May 2004 03:38 Go to previous messageGo to next message
Caledwvech wrote on Mon, 10 May 2004 10:44
i dunno about that hey Confused
i mean, it could be a great graph, but there just isnt the info there on other engine parameters. the x axis is just 'test time' and if you look, it starts around 16 seconds. what rpm is this corresponding to? dunno... it could be the very top end of its rpm band, with a sustained run of 8000rpm being plotted, who knows.
still, hats off to anything that makes 1000hp - however it manages it
RobST162
Re: 1998 Toyota Supra RZ [844 rwhp / 1156 hp @ flywheel] Fri, 14 May 2004 03:43 Go to previous messageGo to next message
yeah ed, but compared to some other "dyno queens" out there such as that Blacka dn Purple 7MGTE MK3 two auto salons ago where the graph looks like an "L" on it's back, it's actually quite good. Smile
ed_ma61
Lost in the K hole
Re: 1998 Toyota Supra RZ [844 rwhp / 1156 hp @ flywheel] Fri, 14 May 2004 03:50 Go to previous messageGo to next message
i think youre missing my point
take that dyno queen 7mgte, get it up and running to 8000rpm, hold it there for a few secs at WOT, and let the 'test time' tick over. capture that part of the output graph, and low and behold youd get something would look like this:
http://www.to4r.com/members/media/mikecarlindyno980.jpg
all im saying is there simply isnt enough info provided on that graph to conclude what it is, in fact, representing.
not that what ive stated above is the 'only' explanation either, just a suggestion for the purpose of demonstration. either way, for a 3.OL turbo engine to make 1000hp @ around 35psi its output curve is going to 'have' to be skewed
[Updated on: Fri, 14 May 2004 03:52]
RobST162
Re: 1998 Toyota Supra RZ [844 rwhp / 1156 hp @ flywheel] Fri, 14 May 2004 03:57 Go to previous messageGo to next message
eek yeah
I didn't look at the graph by clicking on it.. all I did was glance at the thumbnail.
Time on the horizontal axis huh.. well that does make it 'different' than what I am used to seing Wink
Edit: so no one can really tell actually if it's a dyno queen with crazy late boost or something more reasonable..
[Updated on: Fri, 14 May 2004 03:58]
ed_ma61
Lost in the K hole
Re: 1998 Toyota Supra RZ [844 rwhp / 1156 hp @ flywheel] Fri, 14 May 2004 04:08 Go to previous messageGo to next message
taken from the description of the dyno run...
"Larry slowly brings the car up to the proper RPM to let it all ride. As he hit it... blah blah"
which supports my call that they got the engine up to the rpm band they wanted, and then just gassed it and held it. i mean, all they were looking for was to break 1000hp. its not a normal WOT power run dyno curve that you can compare to other curves youve probably seen.
Re: 1998 Toyota Supra RZ [844 rwhp / 1156 hp @ flywheel] Fri, 14 May 2004 05:46 Go to previous message
36psi on a 3L, with 95% VE = maximum of 1034Nm
he claimed 746 ftlbs = 1012 Nm..... possible, but would have to be bloody efficient to get there.
with 1012Nm, the 980hp (731kw) should be gotten at 6794rpm
oh wait, thats RWHP
hmm for the 1156 fw HP = 863kw = 8018 rpm....
it is 'just' theoretically possible to get this much power at the rpm he states...
wether he can achieve that efficiency at such high boost is another matter, but it certainly is possible...
so.. is that 16 seconds the amount of lag Wink
AND it was only there for a second at most... i guess you don't want to hold it there for too long or that video will happen Very Happy
Quote:
Larry was dumbfounded as to how the hell the car made so much power and, to satisfy his needs, he strapped another car on the dyno that was already dynoed at another shop, and that car put out the same numbers as at the other shop. So we knew the dyno was working just fine
Very Happy
Previous Topic:Well earned plugs
Next Topic:What can i compare these to???
Current Time: Thu Oct 29 21:41:05 UTC 2026
Total time taken to generate the page: 0.02319598197937 seconds
