Toymods » Tech & Conversions » T Series to F Series Diff?
ZZT231
melbourne.vic.au
icon5.gif  T Series to F Series Diff? Mon, 10 May 2004 05:40 Go to next message
Changing a T series diff to an F series diff...
The SA63 is fitted with a T series diff, And I am thinking of changing it over to an F series diff since the T series is stuffed.
Is it hard to change over or do I need to change the cradle and assembly?
Cheers.
Re: T Series to F Series Diff? Mon, 10 May 2004 06:01 Go to previous messageGo to next message
It is possible to swap just the diff, but the mounting holes are different (ie some are in a different location and some are just missing) so it's a bit dodgy. It's generally considered easier and better to swap the whole disc-to-disc assembly out of an MA61 (or RA65 if you don't mind staying with drums).
ZZT231
melbourne.vic.au
Re: T Series to F Series Diff? Mon, 10 May 2004 06:11 Go to previous messageGo to next message
Thanks Norbie
Mookie
Tassie
Re: T Series to F Series Diff? Tue, 08 March 2005 03:40 Go to previous messageGo to next message
can you just change the internals or are they totally different ?
ra23celica
Re: T Series to F Series Diff? Tue, 08 March 2005 05:31 Go to previous message
Just as Norbie said, you can swap just the diff but its a bit of a hassle.
I found it easier to get a sacrificial T series axle to rob all the brackets and whatnot of that, and then, using another complete T series axle as the measurement template, weld the bits onto the F series axle and then bolt that on board.
So, the diff centre, the axles and the flange plate are all different between the T and the F axle.
Previous Topic:Cleaning injectors
Next Topic:Toyota engine weights, anone know of or have URL with info?
Current Time: Thu Oct 29 03:10:57 UTC 2026
Total time taken to generate the page: 0.0055880546569824 seconds
