Toymods » Tech & Conversions » Heater hose and mechanism - 4agze sprinter
Les
Heater hose and mechanism - 4agze sprinter Mon, 10 May 2004 10:55 Go to next message
ok, my car has no heater cuz when the conversion was done, it was left out or sumthing ...
can someone gimme some pointers as to how to hook up the heater ? I have already purchased heater hose ... but I have a feeling that I need something else to get it all working ... like the heater "thing" (sorry i just donno how to describe it... brain dead)
am i right ?
[Updated on: Mon, 10 May 2004 11:34]
Les
Re: Heater hose and mechanism - 4agze sprinter Tue, 11 May 2004 10:11 Go to previous messageGo to next message
no one know how to fix this ??
Re: Heater hose and mechanism - 4agze sprinter Tue, 11 May 2004 14:21 Go to previous messageGo to next message
You need the heater box/controls, the tap, hoses and to know where to connect it to on the engine - not really that hard, just go look at another sprinter Shocked
Les
Re: Heater hose and mechanism - 4agze sprinter Tue, 11 May 2004 14:25 Go to previous messageGo to next message
yes attention 4agze owners ... some help please ...
if u would be so kind to take a digital photo of the "heater/box controls" i would be forever grateful ... Very Happy
praetor
Re: Heater hose and mechanism - 4agze sprinter Wed, 12 May 2004 08:13 Go to previous messageGo to next message
did they take anything out from under the dash? if not the heater is prob still there just not connected. have a look for any hoses that have been clamped off on the firewall. Usually 2 of the next to each other. If you've got all that just find somewhere to plug it into the engine - cant help you there though.
Les
Re: Heater hose and mechanism - 4agze sprinter Wed, 12 May 2004 09:07 Go to previous messageGo to next message
hoses are not there - so i bought some ... umm the mechanism is what I am interested in .. can anyone help ??
the cold / hot setting is just a cable that hooks on to the mechanism that goes through the firewall. I can see that cable, but it is not hooked up to anything ... (the heater mechanism should be there i think)
what else would be missing ??
Les
Re: Heater hose and mechanism - 4agze sprinter Thu, 13 May 2004 12:34 Go to previous messageGo to next message
Fock - can someone send me a pic of the mechanism or not ?? far out !!!
Henn
Rosanna, Melb
Re: Heater hose and mechanism - 4agze sprinter Thu, 13 May 2004 14:43 Go to previous messageGo to next message
If you still have the heater box in the car (ie no massive gaping hole behind the console) then this is easy.
You should have two copper/brass pipes sticking out through the firewall into the engine bay directly behind the head. You need to get hot water into one of these for your heater to work (and guess what, it comes back out the other pipe). Run some hose off the water outlet on the back of the head (it sticks out and turns 90degrees with the 2 temp sensors in it), run it into one of the heater pipes.
Then run some hose from the other heater pipe to the shotcock (thing in the engine bay that the heater cable goes to). And from the shotcock into somewhere that's connected to the bottom of your radiator.
Voila, hot air at the flick of a switch.
If there is no heater box in the car start crying, they are a bitch to get at and so installing one would suck. But once you have one just do the above.
Hen
Les
Re: Heater hose and mechanism - 4agze sprinter Thu, 13 May 2004 14:52 Go to previous message
THANKS... lemme try it
Ps: is SHOTCOCK the technical term for that part ?? hahha all i got on google was this .. the shotcock for the sprinter, is it similar to the raxx celicas ?? if they are ... then I will just use the one off my celica
http://www.google.com.au/search?q=shotcock&hl= en&btnG=Google+Search&meta=
Previous Topic:What's this sh*t?
Next Topic:Suppressing radio interference
Current Time: Sat Oct 31 13:34:37 UTC 2026
Total time taken to generate the page: 0.0050320625305176 seconds
