Toymods » Tech & Conversions » what fuel pump can i use
lilcrash
ipswich queensland
what fuel pump can i use Mon, 10 May 2004 20:51 Go to next message
i currently have a vl intank fuel pump running into my 2tgeu and it doesnt seam to b getting enough fuel to rev properly(it only revs if i slowly push the pedal, if i hit it it just stalls)which is bad wen ur tryin to race against an ae90
the car is a ta22
any suggestions
Re: what fuel pump can i use Mon, 10 May 2004 21:17 Go to previous messageGo to next message
I know you said a 2TGEU, but is it fuel injected or running carbys?
lilcrash
ipswich queensland
Re: what fuel pump can i use Mon, 10 May 2004 21:46 Go to previous messageGo to next message
efi with haltech comp
people100
Rocklea qld
Re: what fuel pump can i use Mon, 10 May 2004 21:57 Go to previous messageGo to next message
Did you consider that it may be getting to much fuel...when its idling does it sound a bit rough or is it very smooth. Are they the correct injecters or has someone put bigger ones. Vl pump should supply plenty of fuel to power a 2tgeu engine.
Re: what fuel pump can i use Tue, 11 May 2004 00:37 Go to previous messageGo to next message
Infact the VL pump is over kill for a 2TGEU Rolling Eyes
Re: what fuel pump can i use Tue, 11 May 2004 00:56 Go to previous messageGo to next message
The intank pump in a VL is a low-pressure carby-style pump... VL's also had an external high-pressure EFI pump, and you need one of those!
celicaboy
Re: what fuel pump can i use Tue, 11 May 2004 09:43 Go to previous messageGo to next message
yes i agree with norbi.. low pressure pump is the intank one.. you need the high pressure one hooked up for efi
YelloRolla
On your mum!
Re: what fuel pump can i use Tue, 11 May 2004 09:56 Go to previous message
VL EFI pump is indeed external. In case there is some confusion, try a fuel pressure gauge, borrow one from a mechanic friend (if you have one). 35psi at idle with vac line hooked up.
Previous Topic:Spark plugs..who knows about them
Next Topic:trd 20v cam specs?
Current Time: Sat Oct 24 16:20:48 UTC 2026
Total time taken to generate the page: 0.14651322364807 seconds
