Toymods » Tech & Conversions » trd 20v cam specs?
Flem
cambo
trd 20v cam specs? Tue, 11 May 2004 08:37 Go to next message
does any body know the 20v cam specs? stock or trd cams intake and exhaust. ? 0422948007 if yoiu want too txt me the info or if not pm me cheers. matt.
CelicaRA45
nth ringwood, Victoria
Re: trd 20v cam specs? Tue, 11 May 2004 08:51 Go to previous messageGo to next message
trd 1s are inlet 304 duration lift 10.8mm exhaust 312 dur and 10.8mm lift also 100 btdc cam set up and ex is 94 atdc
purple_people_eater_1
Hobart, Tasmania
Re: trd 20v cam specs? Tue, 11 May 2004 09:20 Go to previous messageGo to next message
would these specs be the same for Trd cams to suit a 100kw 4age?
would there be any benifit running the 20v trd spec cams in my 100kw? would it have more boogie?? lol Smile
Cheers Kieran
CelicaRA45
Re: trd 20v cam specs? Tue, 11 May 2004 09:22 Go to previous messageGo to next message
they list different cams for the 16v
Flogbag
Sydney (Campbelltown...!)
Re: trd 20v cam specs? Tue, 11 May 2004 09:34 Go to previous message
hey
i was looking at cams for my 20v too
has anyone played round with them on a 20v?
when u think about it all a 20v is is a 4age with a more open inlet (4 throttle bodies) plus extra intake valve, more compression, and vvti.... so all it would need is a wicked cam and ud be set
its already got underbucket shims so a set of trd h/d valve springs would be needed then just give it the hardcore cam its crying out for...
toda make cams (expensive)think bout $800 each new http://www.todaracing.com/products/toyota/camshaft s_4ag_specs.html
plus trd of course with there 304* with 10.8mm lift
would any work be needed to put say a 304* cam into a 20v except for the stiffer valve springs
what would be the limit of a profile for driveabiltie on the street would 304 be to big?
Previous Topic:what fuel pump can i use
Next Topic:How to strip paint from plastic car bits?
Current Time: Sat Oct 24 22:21:09 UTC 2026
Total time taken to generate the page: 0.0041470527648926 seconds
