Toymods » Tech & Conversions » 4age cams?
carsanactra
melbourne
4age cams? Tue, 11 May 2004 09:53 Go to next message
G'day guys.
im just wondering how to go about how to find some good Cams for my 4age bigport engine? i will be doing cams when i get my 2.25 inch exhaust and 4-2-1 extractors done, and will have a cold air intake, and run 98 octane fuel all the time.
so what kind of cams should i be looking at, and where abouts do i buy them?
any opinois are welcom, thanks guys.
nb86
melbourne
    sadff
Re: 4age cams? Tue, 11 May 2004 10:20 Go to previous messageGo to next message
keep below 8mm lift and 264 degree duration and the stock ecu should just run it, any more and you're treading on thin ice with out programmable injection.
fatmr2
Re: 4age cams? Tue, 11 May 2004 10:47 Go to previous messageGo to next message
WADE CAMS. Do a search. i asked the same question. $440 for hks billet copies. I think mine are the 264's. They look sexy az Very Happy
They take visa too so its easy.
hope that helps you out.
FKN16V
NSW, East Coast
Re: 4age cams? Tue, 11 May 2004 11:28 Go to previous messageGo to next message
carsanactra wrote on Tue, 11 May 2004 19:53
G'day guys.
Check here (http://www.billzilla.org/ ) for what size is recommended and the power you can expect, then buy them here ( http://www.wadecams.com/ )
Steve
carsanactra
melbourne
Re: 4age cams? Tue, 11 May 2004 12:45 Go to previous messageGo to next message
ok, sorry guys, youll ahve to explain it to me as a retard!!!
all i could find was the stockc am profiles on bills site?
http://www.billzilla.org/4agstock.htm
and with wade cams, do i have to send them the camprofile or do they have a catalogue cam that is already made up? i couldnt find one in their online catalogue?
FKN16V
NSW, East Coast
Re: 4age cams? Tue, 11 May 2004 13:18 Go to previous messageGo to next message
http://www.billzilla.org/4agmods.htm
I have trouble finding it sometimes.
Steve
carsanactra
melbourne
Re: 4age cams? Tue, 11 May 2004 13:43 Go to previous messageGo to next message
according to bill, i can use either 256 deg cams or 264 deg.(but no higher).
i guess my next question is, if i told wadecams that i need a set of 256deg cams for my 4age bigport. would that be all i have to say in order for them to get to work?
isnt there a difference between the intake and exhaust cams?
Grega
melbourne.victoria.austra...
Re: 4age cams? Tue, 11 May 2004 19:33 Go to previous messageGo to next message
want a cam profile?
http://www.club4ag.com/faq%20and%20tech_pages/4A-G E%20camshaft_story.htm
makes for good read. also gives specs - which wade would need on customs.
ps: wade rock.
carsanactra
melbourne
Re: 4age cams? Wed, 12 May 2004 02:20 Go to previous messageGo to next message
okm so say that i have decided on cams 256degree cams, with 7,8ml lift (like the TRD spec cams). how do i know what timing i should use?
eg. intake: 50deg btdc - exhaust:60deg bbdc
carsanactra
melbourne
Re: 4age cams? Wed, 12 May 2004 02:21 Go to previous messageGo to next message
*bump*
Grega
Re: 4age cams? Wed, 12 May 2004 02:30 Go to previous messageGo to next message
100/110
http://www.billzilla.org/4agmods2.htm
RWDboy
Re: 4age cams? Wed, 12 May 2004 02:36 Go to previous messageGo to next message
Depends Razz You would have to ask a specialist. And depends where max lift occurs on the camshaft.
I imagine figures around about 25 degrees BTDC on intake opening, and about 45 degrees BBDC on exhaust? (close to 55 degrees overlap)...
Note : once you start getting bigger cams with more overlap you will more than likely screw your cars' emissions unless you grab a progammable ECU or a remapped ECU.
(edit : typo)
[Updated on: Wed, 12 May 2004 02:40]
carsanactra
melbourne
Re: 4age cams? Wed, 12 May 2004 03:42 Go to previous messageGo to next message
ok,
someone says 100/110 degrees?
someone says 25/45 degrees?
whats a boy to do?
RWDboy
Re: 4age cams? Wed, 12 May 2004 03:52 Go to previous messageGo to next message
100/110 means that the intake is at full lift 100 degrees after TDC, and the exhaust is at full lift 110 before TDC.
(right?)
The 100/110 would give a fair bit of overlap and would be slightly dopey down low...would give best *power* though.
RWDboy
Re: 4age cams? Wed, 12 May 2004 03:54 Go to previous message
I retract my earlier statement -> personally I would set it to 100/100 (intake opens 28 degrees BTDC, exhaust opens (edit)48(/edit) degrees BBDC) and then use an adjustable cam sprocket to get the fine details sorted out.
[Updated on: Wed, 12 May 2004 03:56]
Previous Topic:F Seires IRS-to-Live Swap
Next Topic:Supercharged 2T-G
Current Time: Sat Nov 21 07:40:50 UTC 2026
Total time taken to generate the page: 0.0084719657897949 seconds
