Toymods » Tech & Conversions » 4agze conversion Help??
chrizer
4agze conversion Help?? Tue, 11 May 2004 12:13 Go to next message
Hey,
Well I'm up to doing the fuel for my conversion. 4agze into a KE70. Just wanted to know if I have to change the metal fuel lines that run down the tailshaft or is it just the rubber ones to and from the fuel pumps, engine, fuel tank.
[Updated on: Tue, 11 May 2004 12:29]
FKN16V
NSW, East Coast
Re: 4agze conversion Help?? Tue, 11 May 2004 13:24 Go to previous messageGo to next message
You definately need to change the rubber hoses to efi hose, as for the metal hoses, go for something around the 10-12mm mark, im not sure what size they are standard but its better to be safe then sorry, it doesnt cost much, plus if you go for serious power down the track youve got the lines ready for it.
Steve
Grega
melbourne.victoria.austra...
Re: 4agze conversion Help?? Tue, 11 May 2004 19:35 Go to previous messageGo to next message
what steve said.
annealed LPG line is cheap and flexible and tends to work very well and is MORE than big enough Smile
don't forget your surge tank and lift pump to that either.
chrizer
Re: 4agze conversion Help?? Tue, 11 May 2004 22:08 Go to previous messageGo to next message
Yeah, I've got my surge tank and lift pump to the high pressure efi pump. Just wanted to make sure if i had to or not. The LPG line you speak of, have you used it personally? and where could i source it from?
EVOSTi
cambo
      no
Re: 4agze conversion Help?? Wed, 12 May 2004 06:39 Go to previous messageGo to next message
maaaaaaate you dont need to upgrade the regular steel fuel lines, leave them be. upgrade the rubber hoses, but thats all. Rolling Eyes
Henn
Rosanna, Melb
Re: 4agze conversion Help?? Thu, 13 May 2004 15:03 Go to previous messageGo to next message
Don't bother changing the steel lines. I am putting out 110rwkw using the stock little lines. If you are shooting much bigger than this maybe, but if it aint broke don't fix it.
Hen
EVOSTi
cambo
      no
Re: 4agze conversion Help?? Fri, 14 May 2004 07:15 Go to previous message
there were/are sprinters getting around with 200+RWKW with stock lines.
Previous Topic:Gear shifter - K50/40 and early T50
Next Topic:TA22 Central Locking...
Current Time: Mon Nov 2 04:23:24 UTC 2026
Total time taken to generate the page: 0.0055248737335205 seconds
