Toymods » Tech & Conversions » engine mounts gone
OnAHigh
engine mounts gone Tue, 11 May 2004 14:49 Go to next message
I recently forked out a bit to replace my front engine mount only to realise the back one was completly fuc*** (literally). So me and a mate replaced the back one with a second hand one which was in good con. Now on the third day after replacing the back one , I am starting to get the same symptoms i used to get before i had changed the mounts but no where near as bad as it was.
(A clonking noise everytime i downgear or accelerate or when there is pressure put on the gearbox)
Does anybody have any ideas if there anything else i should be looking at? maybe the left and right mount? should i take the rear one out again and check it? i doubt it would stuff up after only 3days
andy ideas?
Dave
ra23celica
Re: engine mounts gone Tue, 11 May 2004 23:53 Go to previous messageGo to next message
Dave,
Have you retorqued your engine mounts after installing them ?
Have you looked at any of the metal braces that run between the back of the engine and the front of the gearbox ?
Mitch.
Allan
Re: engine mounts gone Wed, 12 May 2004 00:12 Go to previous messageGo to next message
could be diff backlash!
Adsport
Perth WA
Re: engine mounts gone Wed, 12 May 2004 01:30 Go to previous messageGo to next message
i get it sometimes changing out of first gear when depressing clutch, loud thud noise , feels like gearbox or diff... i have an aw11gze with (some kind of ) tight lsd ex JP
OnAHigh
Re: engine mounts gone Thu, 13 May 2004 04:17 Go to previous messageGo to next message
Mitch,
no i havent retorqued the mount, what tool do i need for this?
Iam taking it back to the mechanic on sat mornin to look at the one he installed and the one i installed,
he says engine mounts can stuff up after two days of use, i find that unlikely unless something is causing it to break.
ill also make sure he looks at the metal braces
David
SeptemberSquallIndustries
Re: engine mounts gone Fri, 14 May 2004 08:09 Go to previous messageGo to next message
Try a torque wrench.
Captain_Jonno
Re: engine mounts gone Mon, 19 July 2004 10:48 Go to previous messageGo to next message
Did your problem get resolved?
HighRolla
Re: engine mounts gone Mon, 19 July 2004 10:53 Go to previous messageGo to next message
Some of the guys here have used a product called sikaflex to make a semi solid mount (a polyurethane based or similar product). Sounds like there might be something else causing them to break or give you the symptoms though
OnAHigh
Re: engine mounts gone Mon, 19 July 2004 16:08 Go to previous messageGo to next message
hey guys
yes i finally did fix this problem, the engine mounts were partially, the problem but the second problem was a bolt on the drivers side , im not sure the name of what it bolts onto ill look in the manual. It was loose and was knocking against the bushes etc, thats why i would always hear the clonking sound, i tightned this bolt when i first changed the engine mount ( i happened to notice it was loose) but it came loose again thats y i thought the engine mount was the problem, so a bit of locktight fixed the problem Smile so far so good
thanks for asking
dave
Captain_Jonno
Re: engine mounts gone Mon, 19 July 2004 22:50 Go to previous message
how about a pic of this bolt! cos im having the same problemo with my car Sad
That would be very swell
Previous Topic:4A-GZE cold start issues
Next Topic:crank angle sensor (4age)
Current Time: Wed Nov 18 20:11:21 UTC 2026
Total time taken to generate the page: 0.024291038513184 seconds
