Toymods » Tech & Conversions » Heaterbox info
Draza
Wahroonga
Heaterbox info Wed, 12 May 2004 05:07 Go to next message
Ok i don't know alot about heater boxes, but i'll tell u what i know/think and i want to know if i'm right or wrong and what i can do to fix it.
To start off the car is an ST162. The heater box is leaking coolant, i know that the coolant is used for heat in the heater box. To control the amount of heat being produced there is a regulator on the engine side of the fire wall that has a coolant filled hose hooked up to it.
My first theory is that the heater box has a hole in it, but to change or fix this i have to remove the entire dash and i'm hoping this isnt it.
My second theory is that when my mechanics last hooked up the heater box they put the pipes to the wrong places and the pressure inside the box is building up and thus pulling a sea apart and leaking coolant. I'm hoping that this is the case and all i have to do to fix it is switch the pipes on the engine side of the fire wall.
The quick fix that i have been doing to cope is just linking the 2 coolant pipes together, this is fine for summer but it is getting into winter and i need that heater to get the thin layer of ice off the windscreen. I can hardley see some mornings and the same some nights.
people100
Rocklea qld
Re: Heaterbox info Wed, 12 May 2004 09:59 Go to previous messageGo to next message
it would be leaking...heater cores are universal on the inside...only time you will have a problem is if the heater tap is faulty but if its leaking from the heater box it has to come out...no other way around...why risk it leaking again and most of the time dashes are easier to remove than they look.
Re: Heaterbox info Wed, 12 May 2004 13:03 Go to previous messageGo to next message
It'll be the heater core that's dead - if you like, just bypass (connect together) the heater hoses for the time being, and let the winter weather be the thing that convinces you to actually fix it Surprised
Draza
Wahroonga
Re: Heaterbox info Wed, 12 May 2004 13:51 Go to previous message
ok it will take a bit of time till i am able to remove the dash, next job on the list is the springs that should be ready in about 1-2 weeks.
Previous Topic:KE55 drums - bolt on to KE35 diff?
Next Topic:1GGTE Qs
Current Time: Fri Nov 20 04:27:07 UTC 2026
Total time taken to generate the page: 0.00624680519104 seconds
