Toymods » Tech & Conversions » TA22 - H4 time.
Grega
melbourne.victoria.austra...
TA22 - H4 time. Wed, 12 May 2004 06:34 Go to next message
OK, so the sealed beams did an *ok* kinda job. I figured time for something a bit better.
NARVA 72048 are your friend. $85 trade
OLD on the left, NEW on the right ;
http://www.vncommodore.com/images/celica/h4/DSC00182.JPG
what the back looks like with the dustcaps in place ;
http://www.vncommodore.com/images/celica/h4/DSC00185.JPG
and the finished product ;
http://www.vncommodore.com/images/celica/h4/DSC00187.JPG
the above lights are ADR approved when using 55/60 globes. they will run a 55/100 globe if you want, but, no ADR for you Smile
my TA22 originally runs parkers below the bumper, low beam on the far outside lights and hi beam in the middle/outer ; i'm going to change it to low beam on both and hi beam on both while i'm here - far better lighting setup.
FWIW this lense setup also has provision for a parker globe IN the headlight too.
i don't see the wiring as being quantum physics, with, one additional wire being required to go to the middle light ; presently there are only two...
the only modification was the slightest dremelling of the outside frame that holds the lense ; other than that the chrome surrounds screw down in place around the globe and its all good.
[Updated on: Wed, 12 May 2004 06:36]
BradW
Bottom of the hill, Sydney
Re: TA22 - H4 time. Wed, 12 May 2004 07:28 Go to previous messageGo to next message
Are your headlights running through relays?
If not it is advisable to fit them as there will be extra load on the headlight wiring/switching which will cause premature failure. The added bonus of relays when wired correctly is a better power supply to the headlights giving a brighter light.
Grega wrote on Wed, 12 May 2004 16:34
Is it legal to have 4 low beam headlights?
Classique71
Colac, Victoria
Re: TA22 - H4 time. Wed, 12 May 2004 08:38 Go to previous messageGo to next message
Pity i dont have my ta22 still greg - i could have shown you the ultimate ta22 l;ight setup
Outers 90/110 Semi sealed beams
Inners clear lense 150W rally spotlights
Was running relays - HAD AWESOME BUG MELTING POWER
totally illegal i think but you need uber-lights for the country
Gt4 will be copping a similar setup if i can find a good set of neat spotlights
Grega
Re: TA22 - H4 time. Wed, 12 May 2004 09:56 Go to previous messageGo to next message
like bradw has suggested, relays are MANDATORY
and i don't know if its illegal to be honest....good question will let you know when i find out.
Re: TA22 - H4 time. Wed, 12 May 2004 10:00 Go to previous messageGo to next message
Its not. I got pulled over for the exact thing. I never got fined though, but they said I couldnt drive the car away untill it was fixed Confused
Re: TA22 - H4 time. Wed, 12 May 2004 15:59 Go to previous messageGo to next message
90/120 for the outsides and 150 for the insides Very Happy
i had 90/120's in my poor little rolla... were nice and bright and i aimed them extra low so as not to piss off too many ppl.. can see every detail in the road Very Happy
mmmm low beam 2x 90 = 15amps
high beam 2x 120 + 2x 150 = 45 amps!!!!!!!!! holy moly!!!!
if you are using k-mart or other cheapy "horn relays", use one for each light and circuit as they may only like 10A continuous...
there are better relays around that can run 40A continuous, such as the P&B (Potter & Brumfield)
http://www.jameco.com/cgi-bin/ncommerce3/ExecMacro /jameco/searchResult.d2w/report?sort=BPA&searc h=171441
AUD$3.15 or so before postage....
i'm going to grab a few of these when i eventually have relays in my car Wink
Grega
Re: TA22 - H4 time. Wed, 12 May 2004 19:35 Go to previous messageGo to next message
i normally use narva relays, never had any issues with them to be honest.
that or the original ones from VNs (fit in pockets well from wreckers)
dcleyne
Re: TA22 - H4 time. Thu, 13 May 2004 06:38 Go to previous message
I love the look of what you're doing with this and it has gotten me thinking...
I want to improve the lighting of the car (it can't get any worse can it?) and the immediate thought is to reduce the load on the light wires by reducing them to switching current only and driving all the headlights from relays. So wiring the original wires to the relays and then wiring the relays to the headlights while keeping the original headlights (at this stage - I will move to better units when I can).
Firstly, is it appropriate to add one relay per pair or better to have one per light? I would have thought that it would be better to have one relay per light in case of failure (so you could at least get home on one light). While doing this, the fuses in the interior relevant to the headlights become less useful and so I'm thinking that there should be fuses installed with the relays as well?
My 22 has only about 3-4 relays in it now. Adding another 2-4 relays plus fuses will make that section of the engine bay fairly messy. What ideas are floating around for installing more relays and keeping the install neat? Does anyone know of an appropriate later model car that would have a fuse/relay box that would be appropriate for this conversion?
Sorry for the ramble...
Dan
Previous Topic:wheels AE86
Next Topic:Different PCD
Current Time: Fri Nov 20 10:04:54 UTC 2026
Total time taken to generate the page: 0.0093681812286377 seconds
