Toymods » Tech & Conversions » 18RC & Turbo ?
BlackieWolfie
Melbourne,Victoria
18RC & Turbo ? Wed, 12 May 2004 17:21 Go to next message
Hi people,
I have Toyota Corona,Auto,Rt104,2000 Model(1977,I think).
Is it possible to install a turbo to this engine?
I am unsure if it has single or twin carbies.
All replies/info appreciated.
Re: 18RC & Turbo ? Wed, 12 May 2004 22:46 Go to previous messageGo to next message
It is possible to put a turbo on any engine. Hell, you can turbocharge your lawnmower if you want to.
The question to ask is, is it worth the time and cost involved? The answer in this case is no IMO. Turbos and carbies generally aren't happy together.
Re: 18RC & Turbo ? Thu, 13 May 2004 02:11 Go to previous messageGo to next message
been there.. done that...
i would advise against it.
having all that heat and fuel on one side of he engine is a PITA
find an 18RGU(e) Wink
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: 18RC & Turbo ? Thu, 13 May 2004 02:20 Go to previous messageGo to next message
and get a manual 5spd gearbox! W50 bolts up i think ?
Allan
Re: 18RC & Turbo ? Thu, 13 May 2004 02:21 Go to previous messageGo to next message
thechuckster wrote on Thu, 13 May 2004 12:11
Yeah but you used a carby thats just being a pain junky hehhehe
BlackieWolfie
Melbourne,Victoria
Re: 18RC & Turbo ? Thu, 13 May 2004 07:08 Go to previous messageGo to next message
Ok,
So can I turbo the engine?
If so,how do I go about doing this ?
M.W.P.
Rocky Mountains, Canada
Re: 18RC & Turbo ? Thu, 13 May 2004 07:23 Go to previous messageGo to next message
Norbie wrote on Thu, 13 May 2004 08:16
You pay someone lots of money... thechuckster can give you a $$ figure.
At a quick guess itll be easily over $1500.
lumpy
Adelaide, SA
Re: 18RC & Turbo ? Thu, 13 May 2004 07:42 Go to previous messageGo to next message
BlackieWolfie wrote on Thu, 13 May 2004 16:38
Ok,
If this is the current extent of your knowledge with regards turbocharging and general mechanics, I'd suggest you go to the library, use the internet and read as much as you on this topic can so you are more familiar with what's involved with turbocharging an engine. Then you will know why it's a bad idea to muck around doing trying it to an 18R-C.
If you want a turbo engine, buy one that is already equipped with one from the factory.It'll cheaper and much less painful -
Profit from thechuckster's experience and don't bother!
Re: 18RC & Turbo ? Thu, 13 May 2004 08:29 Go to previous messageGo to next message
how much?
<http://members.optushome.com.au/mkhala/red_celica/ budget.html>
and add up the sections on:
-TURBO INSTALL & SETUP
-RECO ENGINE, CLUTCH & TAILSHAFT
-ENGINE/EXH/MECHANICAL PARTS
but in a nutshell, you have to:
reduce the compression down to under 7.5:1 - safest way is for an engineer to machine out the head - a spacer plate between block & head might help but you'll be restricted to boost of say 5-7psi to avoid blowing gaskets and be more prone to pinging and detonation
make custom manifolds for exhaust and intake
decide how to fuel it (and after my last effort to drive in it, i'd strongly advise EFI - which involves even more custom stuff like injector ports, plenum, throttle body, etc)
decide what engine management is needed (ingition and fuel)
upgrade the cooling
upgrade the clutch and probably rebuild/refresh the gearbox
consider upgrading your brakes
OR.... get an already turbo/efi engine (18RGUE? 3T-GTE? 4AGTE? ...) and transplant it.
If you're not comfortable about DIY stuff, then take the easy road...
people100
Rocklea qld
Re: 18RC & Turbo ? Thu, 13 May 2004 09:55 Go to previous messageGo to next message
Yes id advise not going the 18rc turbo or even 18r-e unless you have already had alot of stuff done as chuckster has...Ive done some reasearch and the price is just outrageous and it would be better spent on a 18rgeu at least..
Allan
Re: 18RC & Turbo ? Thu, 13 May 2004 12:52 Go to previous message
I would say if your going EFI leave the compression at the stock 8.5:1 - spacer plates often cause more grief then good when the mixtures are ok
Allan
Previous Topic:Strut Rods - Bent??? AW11
Next Topic:Cold Start - 4agze in Sprinter
Current Time: Tue Oct 27 00:45:51 UTC 2026
Total time taken to generate the page: 0.083563089370728 seconds
