Toymods » Tech & Conversions » air bypass valve question (4agze)
CrAiGzEE
south of the big smoke
air bypass valve question (4agze) Tue, 27 August 2002 11:56 Go to next message
Was just reading the hot 4s year book and have come across Daniel Rucci's car can someone explain something to me
it says he has replaced the air bypass valve with a turbo smart type 2 BOV... What is the pont of this
whats it do better than the T piece people use??
Ben Wilson
Re: air bypass valve question (4agze) Tue, 27 August 2002 22:00 Go to previous messageGo to next message
Some people have had problems with the standard ABV leaking under high boost levels.
Some people also have far too much money and feel a strange need to spend it on fairly pointless billet aluminium thingies...
TE72_Turbo
Re: air bypass valve question (4agze) Wed, 28 August 2002 01:52 Go to previous messageGo to next message
I cant imagine how an aftermarke blow off valve would work on a GZE anyway, as the supercharger is AFTER the throttle body, so there's nothing to build pressure against!
i'd say he's a victim of excess cash and a love for shiny "go fast bits"
feral4mr2
Bundaberg, Qld.
icon7.gif  Re: air bypass valve question (4agze) Wed, 28 August 2002 04:12 Go to previous message
Freak i will always say that replacing the ABV with a BOV is a useless activitiy........
it is always on the vacum side of the throttle body (unless you have relocated the throttle body)
if you are leaking boost through the ABV, take it off altogether, i have done this when i had the ze, (and a lot of ze owners in UK have done the same), the s/c has a clutch so it does not harm the performance/engine in any way, by not having the ABV. some of them have even taken the venting system off the top of the s/c, and just joined the three vent pipe together, as boost has been able to escape through them into the throttle body (well above it where the pipe goes in).......this does not harm the s/c.
Previous Topic:oil leak
Next Topic:cool commodork??
Current Time: Fri Nov 20 08:14:26 UTC 2026
Total time taken to generate the page: 0.024645805358887 seconds
