Toymods » Tech & Conversions » New Injectors Are they worth it ????
tsbb1
North Qld
New Injectors Are they worth it ???? Wed, 12 May 2004 23:11 Go to next message
Guys l run a 20 valve with Big Cams is it worth getting larger Injectors as well.. will there be any performance gain Or should l go some other way ??? Any advice would be appreciated...
RWDboy
Re: New Injectors Are they worth it ???? Wed, 12 May 2004 23:19 Go to previous messageGo to next message
No huge performance gain...you only need bigger injectors if you are flowing *alot* more air (like if you upped boost on a forced induction engine for example) and the factory injectors should suit fine if it is being left N/A.
Re: New Injectors Are they worth it ???? Thu, 13 May 2004 00:18 Go to previous messageGo to next message
the 20V injectors are fairly large already aren't they?
you only need bigger ones if your duty cycle goes above 80-85%.
is this with stock ECU?
other way? turbo Razz heh heh
CelicaRA45
nth ringwood, Victoria
Re: New Injectors Are they worth it ???? Thu, 13 May 2004 09:00 Go to previous message
i have a set of black top 1s if that will help but as stewart said my motor is running up to 82%duty cycle at 100 % throttle and in the future will be going up to 450cc injectors but that a 3sge motor
Previous Topic:LSD's
Next Topic:Power Steering Bracket
Current Time: Fri Oct 23 17:32:02 UTC 2026
Total time taken to generate the page: 0.0049760341644287 seconds
