Classifieds » Miscellaneous » 18rg EFI injection setup
jweydling
18rg EFI injection setup Thu, 13 May 2004 03:10 Go to next message
I have an 18rg EFI setup that i will sell for $200 if anyone in interested. It has injectors and everything.
cthulhu
Re: 18rg EFI injection setup Thu, 13 May 2004 03:48 Go to previous messageGo to next message
i got a friend who might be interested ill talk to him bout it
RA40Celica
Hobart
  chris_rg@jabber.org
Re: 18rg EFI injection setup Thu, 13 May 2004 08:57 Go to previous messageGo to next message
does this include the efi thermostat housing????
got photos?
Chris
people100
Rocklea qld
Re: 18rg EFI injection setup Thu, 13 May 2004 10:00 Go to previous messageGo to next message
wiring ecu etc?????standard injecters??
munki
Gold Coast
Re: 18rg EFI injection setup Thu, 13 May 2004 12:30 Go to previous messageGo to next message
does this have ecu now?
where are my pictures? Smile
Daniel
swankiedude
Central Coast
Re: 18rg EFI injection setup Thu, 13 May 2004 12:34 Go to previous messageGo to next message
I have an 18RGU sitting in the garage. Does this just bolt straight on or do I need other components as well
Lambolica
Northwestern Sydney
Re: 18rg EFI injection setup Thu, 13 May 2004 23:03 Go to previous messageGo to next message
You will need the intake manifold, plenum, AFM + piping and brackets, wiring loom, ECU, igniter, electronic dizzy, lifter pump, hi-pressure pump, surge tank. (+ EFI fuel lines, clips, gaskets and all the other little thing that should be changed)
Other than that it all bolts up to the 18R-G and needs to be wired in to the car (which is fairly basic if you have a diagram and a complete loom)
swankiedude
Central Coast
Re: 18rg EFI injection setup Fri, 14 May 2004 09:54 Go to previous messageGo to next message
So would it be easier and better off buying this then finding all the other stuff to go with it or just get a 18RGEU with it already on???
people100
Rocklea qld
Re: 18rg EFI injection setup Fri, 14 May 2004 10:52 Go to previous message
Electronic dizzy and ignitor arent really nessecary are they as it is a fuel only computer...when i purchased my engine there was no elec dizzy and it was apparantly running. Also need a efi thermostat housing and either different exhaust manifold with a oxygen sensor or get one welded into your existing manifold
Previous Topic:20 valve gearbox ,clutch,flywheel,alternator
Next Topic:2tg's, t50, Seats, carby's etc
Current Time: Wed Oct 28 14:22:33 UTC 2026
Total time taken to generate the page: 0.064524173736572 seconds
