Toymods » Tech & Conversions » HELP - 1JZ is burning oil
jzz30
HELP - 1JZ is burning oil Thu, 13 May 2004 06:16 Go to next message
yes, 1JZ burning oil, NOT CT12's blowing oil..
i've changed the turbos twice, new seals, steel wheels, the lot.
the car is still blowing white smoke
new valve stem seals, car still blowing smoke...
spark plugs 5 and 6 are dirty with oil, clean them.. drive it.. burns oil and they go dirty again...
what's been checked:
Turbos (replaced),
MAP sensor (voltage checked),
fuel pressure (perfect),
vacuum hoses (not blocked),
PCV (functioning fine),
valve stem seals (replaced),
compression (equal on all 6 and completely normal)
stuffed rings would result in dropped compression
cracked piston would result in dropped compression and power
blown head gasket would result in engine heat rising up
WHAT THE HELL IS GOING ON WITH THIS PEICE OF CRAP!
lumpy
Adelaide, SA
Re: HELP - 1JZ is burning oil Thu, 13 May 2004 06:22 Go to previous messageGo to next message
Have you tried taking the PCV pipe off the intake mainfold (and leaving it off)? to make sure it's not some dicky PCV thing.
Although the continually oily plugs on 5th and 6th would still be a mystery??? Split headgasket at an oil gallery between 5th and 6th cyl?
Mr DOHC
Re: HELP - 1JZ is burning oil Thu, 13 May 2004 06:28 Go to previous messageGo to next message
dont some cars show good comp at cranking speeds {250 rpm} and then go to shit at full tilt {6000+rpm}
ChuckLandwehr
Re: HELP - 1JZ is burning oil Thu, 13 May 2004 07:09 Go to previous messageGo to next message
A compression test, will NOT tell you if your oil control rings are shagged!
regards Chuck.
dingaling
tas
Re: HELP - 1JZ is burning oil Thu, 13 May 2004 08:18 Go to previous messageGo to next message
oil smoke is blue, coolant is white.
jzz30
Re: HELP - 1JZ is burning oil Thu, 13 May 2004 10:23 Go to previous messageGo to next message
only 5th and 6th cylinders burn the oil..
head being taken off now...
jzz30
Re: HELP - 1JZ is burning oil Thu, 13 May 2004 10:25 Go to previous message
yeah i realise it could be bottom or middle ring that is cracked..
the fact that it is two cylinders makes me hope it's the head gasket inbetween the two cylinders oil gallery...
will find out soon!
thanks for help
Previous Topic:Engine oil cooling for turbo 7mge...
Next Topic:4AGZE LSD
Current Time: Sun Oct 25 08:16:26 UTC 2026
Total time taken to generate the page: 0.0092000961303711 seconds
