Toymods » Tech & Conversions » changing the interior colour
Youngy
Eskilstuna, Sweden
changing the interior colour Tue, 27 August 2002 14:27 Go to next message
Hello all,
I am currently in the process of taking my interior plastics from brown to black and am having some issues that I hope others have found a way round.
I am using Motospray vinyl dye and each plastic piece is first washed in sugar soap, aloud to dry and then wiped down with prepsol just before painting.
The only issue is, after it dries in some places it bubbles up and this is the start of being able to peel of whole sheets of dye/paint.
How do you get this stuff to stick, steel wool the plastic first?
Give up and get someone else to do it, are there any professional places that do this sort of thing well?
Cheers.
Pumpkin
Toymods Board Member
Re: changing the interior colour Tue, 27 August 2002 21:19 Go to previous messageGo to next message
That's wierd .. whenever I have used a vinyl spray.. I have never done all that.. Shocked I simply give it a good clean and spray it on... Mine hasn't chipped, faded or peeled.. Maybe it's the sugar soap???? Question
GIN51E
Berowra-Sydney
Re: changing the interior colour Tue, 27 August 2002 22:10 Go to previous messageGo to next message
don't use the vinyle spray on just plastic only use it on vinyle get another spray to use on the plain plastic parts,
i used vinyle spray on my car been perfect for 3 years no problems, i simply gave my door trims a good scrub down using auto1 wax & grease remover 4L tin is like $12 and did it in the sun so it dried quick i'm not sure what bran vinyle spray i got but it was from auto 1 and was good stuff i've had friends use stuff just up at the hardware and it just turns out dodgy.
rob_RA40
c'town, NSW
Re: changing the interior colour Tue, 27 August 2002 23:09 Go to previous messageGo to next message
so what paint do u use on the plastics then?
or can u just prime with flexi prime and paint it with anything?
GIN51E
Berowra-Sydney
Re: changing the interior colour Wed, 28 August 2002 00:51 Go to previous messageGo to next message
just any spray paint is fine on plastics but if u want good plastic paint then get it from a hobby shop and get the Tamiya spray paint but its expensive like $11.95 for a little spray can vinyle spray isn't any good on plain plastic as its got a strange chemical make up which is only good for vinyle and its paint that is made to flex so vinyle spray paint should only be used on vinyle but pretty much any plain acrylic paint will be fine for plastics just make sure you use wax and grease remover before you paint otherwise the paint wont stick.
http://www.planet.net.au/~gins/trimbefore.jpeg
http://www.planet.net.au/~gins/trimafter.jpeg
RA28
Re: changing the interior colour Wed, 28 August 2002 06:06 Go to previous messageGo to next message
I just bought a few meters of velour and some glue and now I have a black velour interior! Looks pretty good and feels much warmer than vinyl and plastic. the dash has to be painted though.
(although in my GF's torana we covered everything with 1/2" black shag, the dash, center console, doors, did the carpet in charcoal and the roof in black velour and it looked unreal and only cost about 150 bucks all up!)
Youngy
Eskilstuna, Sweden
Re: changing the interior colour Wed, 28 August 2002 13:17 Go to previous messageGo to next message
Thanks gents,
Havoc I would have to say that it is not the sugar soap (which is essentially just a very strong grease and grim remover) as this is a common method used of cleaning a surface before painting.
The Prepsol should get the surface almost spot on. The can does say that you can use it on plastic/vinyl etc whatever it sounds like. But I have thought about going down the Tamiya paint path with a few dozen cans of polycarbonate paint.
I have scrubbed everything with steel wool just to give it a slight edge that the paint will hopefully hold this time round.
Alainve
Newcastle NSW
Re: changing the interior colour Thu, 29 August 2002 09:53 Go to previous messageGo to next message
Acrylic paint is the best bet for any plastics but i do recomend using a plastic primer on the bare plastic before applying colour then use any automotive acrylic paint on it for a tuff and shiny finish give it a coat of clear.
My TA22 has a two-tone Magenta cow-fur (doors trims, rear seat, rear side trims and parcel tray) and black fur for the rest (roof, pillars and dash) also removed carpet with Gunmetal hammertone floor with magenta Holographic glitter sprinkled on.
it looks pretty awesome and ive got lots of good comments about it Razz
DAMO
MELBOURNE
Re: changing the interior colour Thu, 29 August 2002 10:59 Go to previous messageGo to next message
I have had a lot of experience in this area. If it is a polypropelene(think that's how you spell it) the vinyl spray will not stick. It will stick to ABS plastic. To tell the difference the parts are usually marked underneath. ABS is not very flexible and will crack if you bend it where the other is very flexible and goes all chalky when left in the sun. I've tried a plastic primer and acrylic paint and 2pac. 2pac was stronger but for high traffic areas like scuff plates etc. no good. You are better off getting some spray on contact adhesive and covering with black vinyl or stretchable carpet. I actually got my parts flocked which is a method of spraying contact adhesive and then a velour mix, which turned out magic. Hope that helped
Youngy
Eskilstuna, Sweden
Re: changing the interior colour Thu, 29 August 2002 12:39 Go to previous messageGo to next message
Flocked!! That sounds like some sort of Euro porn move....... Grin Where did you get that done? Is it something most auto trimmers are into?!
I think the plastic in an AE86 is ABS. But I'll have to look into it. I will try out the plastic primer and see hoe it goes this weekend.
DAMO
MELBOURNE
Re: changing the interior colour Thu, 29 August 2002 20:45 Go to previous messageGo to next message
Most of the dash parts are ABS but the rest of the parts are poly. I have an AE86 and this is how I know. If you are in Melbourne I could find out who did it for me, it cost me about $250 for a lot of parts. I carpeted all my boot parts, scuff plates and kick panels. The dash I used vinyl dye, the rest I had flocked.
LadySX
Re: changing the interior colour Fri, 30 August 2002 03:22 Go to previous messageGo to next message
Silly question maybe, and just a tad off the original topic. I have an ae93 Corolla SX.
I want to change my interior from grey to black. I have tried spraying the door trims before, but as has been stated above, the paint peeled off almost straight away. I am not sure what material it is (maybe someone can assist here). In the parts that the pain did adhere to, it was really dull, and looked patchy. What do I use to get it looking the way it should? I also want to spray my dash red too, do I use the same stuff even though its a different material?
Excuse my ignorance, I have no clue when it comes to this stuff, but don't want to pay a trimmer an astronomical amount for a simple job.
Youngy
Eskilstuna, Sweden
Re: changing the interior colour Fri, 30 August 2002 13:12 Go to previous messageGo to next message
Hi Damo,
If you could send me some more info to youngy99@hotmail.com I sure would appreciate it.
I went to the hobby store today and this dude there told me about these 'epoxy paints' that should stick to anything, so I will have a look into those tomorrow.
Cheers all
[Updated on: Fri, 30 August 2002 13:13]
biggav
Re: changing the interior colour Fri, 30 August 2002 14:25 Go to previous messageGo to next message
what's the go with the vinyl dye..? any good?
my cressy has some slightly off colour marks i can't get rid of, inground mud methinks Sad thinking of dying a slightly darker grey to offset it - is it an easy application?
Youngy
Eskilstuna, Sweden
Re: changing the interior colour Sat, 31 August 2002 09:21 Go to previous messageGo to next message
Well Gav,
As I am finding out from info from the gents above as well as my own findings the vinyl dye paints are great on obviously vinyl, come out very well on ABS platics. But are shit for Polypropylene or Polycarbonate plastics.
For those plastics I will be using a flexible plastic primer followed by an automotive acrylic lacquer which I just scored today if that does not do the trick I'm looking to get flocked as Damian has suggested above.
Hope this helps you out.
biggav
Re: changing the interior colour Sat, 31 August 2002 11:55 Go to previous messageGo to next message
Embarassed DOH!! sorry, got my interior bits mixed up - i was referring to carpet and velour dye....
froodogs
Perth, WA
Re: changing the interior colour Thu, 14 November 2002 06:17 Go to previous messageGo to next message
i know this is something of an old thread but i thought i might rejuvenate it a bit... has anyone had any experience in replacing/overlaying/dyeing fabric in door trims? the fabric parts in my ae86's door trim are looking pretty saggy and dirty and just generally crap, and i thought maybe some dark velour or something similar might be able to be stuck over the top... what would be the best way to do this? big bastard staples? stitching? glue? most of the vinyl looks alright, so i'm in no huge hurry there, although the door-handles could use a respray...
hmmmm.... ideas?
Re: changing the interior colour Thu, 14 November 2002 06:34 Go to previous messageGo to next message
I'm pulling my panels off my door and alongside the back seats in my XX. If you take them off, then unclip the hooks, you can remove the fabric part. Then remove the staples and peel the material off. Some might stay because its stuck to the paneling, but just try.
I'm using red fabric to replace the old stripy stuff, just stretch it out over where it was originally and use a staple gun and glue new stuff in position. Looks a treat! Very Happy
CrAiGzEE
south of the big smoke
Re: changing the interior colour Thu, 14 November 2002 11:07 Go to previous messageGo to next message
ginsie that has coome up pretty good,
when ya paint dashs how do u protect them from sun light after? can ya still use armor all?
FLY PSI
Re: changing the interior colour Thu, 14 November 2002 12:17 Go to previous messageGo to next message
I also have an interior trimed in fur Smile. it is magenta and cookie monsta blue Cool it only cost about $100 to do including the glue. I done it with the help of Alainve, and vise versa.
Both cars look cool it just takes a little time.
munki
Gold Coast
Re: changing the interior colour Fri, 15 November 2002 08:17 Go to previous message
is the plastics in a 1976 celica vinyl dye friendly? cause i want to do the interior this holidays. along with everything else lol
daniel.
Previous Topic:4agze front cut OR engine and electrics
Next Topic:Motec M800
Current Time: Wed Nov 4 04:04:56 UTC 2026
Total time taken to generate the page: 0.095148801803589 seconds
