Toymods » Tech & Conversions » 4agze fuel??
rolla kid
Brisbane (AUS)
4agze fuel?? Thu, 13 May 2004 07:32 Go to next message
Hi guys just a quick question where is the fuel pump on a 4agze?? i am currently doin the conversion into my AE82 corolla (carby) and i dont understand all this fuel stuff plz help.
feral4mr2
Bundaberg, Qld.
Re: 4agze fuel?? Thu, 13 May 2004 08:32 Go to previous messageGo to next message
have you looked at your fuel tank? i'm not sure with your model car, but the aw11's fuel pump is a intank one.
DiZ_
The Eastwood MASSIVE !
Re: 4agze fuel?? Thu, 13 May 2004 11:03 Go to previous messageGo to next message
You will need to buy a EFI fuel tank and pump , and also EFI fuel lines.
Alainve
Newcastle NSW
Re: 4agze fuel?? Thu, 13 May 2004 13:52 Go to previous messageGo to next message
the fuel tanks are the same (mine was same as donor twinky tank but with less rust so i used it) u just need to put a efi pump in and asociated lines plus the twinky has a larger fuel line in to the front so its a good idea to swap that in aswell
SprinterBoy
Re: 4agze fuel?? Fri, 14 May 2004 07:04 Go to previous messageGo to next message
I had to fit new lines to the sprinter and get a fuel pump for it, i used a VL turbo one, 1.5L surge tank and 3/8copper hose/piping for the line. It's all mounted just out side the tank under the car, cams rules states that no fuel should be inside the car, as tehe car is a liftback this is what i had to to, plus it doesn't take up any boot space either.
Johnny
Sydney, OZ
Re: 4agze fuel?? Fri, 14 May 2004 10:37 Go to previous messageGo to next message
ah not.. it states that any single volume cars must have a liquid/fire proof bulkhead, ie perspect between you...
sideshow
Re: 4agze fuel?? Fri, 14 May 2004 22:32 Go to previous messageGo to next message
goto the wreckers
and get a fuel tank out of same model car as yrs but with an efi 4age
make sure u also get the main feed line that goes to the engine
i think u can buy these lines from toyota brand new pretty cheap
the line is slightly bigger than old feed line so if u want to fit it in original spot the clamps have to be filed out abit
due to old line being 6mm and this one 8mm
bit of a pain but can be done
cri_ag
northern beaches
Re: 4agze fuel?? Fri, 14 May 2004 23:44 Go to previous messageGo to next message
sprinter boy, you wouldent happen to have a pic of your surge tank setup would you? ive been looking at the avaiable space under there and was wondering how you had done yours.
SprinterBoy
Re: 4agze fuel?? Sat, 15 May 2004 06:34 Go to previous message
cri_ag
I don't have a pic of it yet, i'll take a few on monday and i'll e-mail it to you.
Johnny
Well, insted of having a perspect box around the tank taking up even more room, i have had it mounted under the car. I was told buy a mechanic, who rallies a old skool galant that i would have no problems with this time of setup, and that the inside cabin one was not cams approved. so in a way i was right, but thankyou for clearing it all up, as i didn't know about the bulkhead bit
Previous Topic:AE86 crossmember
Next Topic:sensible spring rates for "boy racer" street driven AE86
Current Time: Fri Nov 20 15:51:30 UTC 2026
Total time taken to generate the page: 0.01260781288147 seconds
