Toymods » Tech & Conversions » 2tg, cam chain tensioner leak,
ta2272
2tg, cam chain tensioner leak, Thu, 13 May 2004 07:54 Go to next message
it leaks and just wondering if anyone has had a problem similiar to this i have played around iwth it and couldnt seem to stop it from leaking,
thanks in advance.
jason
CelicaRA45
nth ringwood, Victoria
Re: 2tg, cam chain tensioner leak, Thu, 13 May 2004 08:49 Go to previous messageGo to next message
you have to replace a o ring where the bolt treads up the main body ,complete pull down im afraid
ta2272
Re: 2tg, cam chain tensioner leak, Thu, 13 May 2004 08:57 Go to previous messageGo to next message
u mean a pull down of only the tensioner, and wah t sid is the o ring on the siede were it goes into the head or the other side.
jason
CelicaRA45
Re: 2tg, cam chain tensioner leak, Thu, 13 May 2004 09:11 Go to previous messageGo to next message
when you unscrew the tensioner from the head the plunger that adjusts the chain will have a circlip you have to take that out and pull the guts out and completly disassemble it keep parts in order as it will go back the same way
ta2272
Re: 2tg, cam chain tensioner leak, Thu, 13 May 2004 09:16 Go to previous messageGo to next message
but the laek doesnt seem to be coming form the bolt closest to the head its coming out right at the end and in the center, is this still the ineer o ring,
were cna i get this o ring from before i pull it appart or do i have to get it measured up, it is an older style 2tg.
thanks for the help
jason
CelicaRA45
Re: 2tg, cam chain tensioner leak, Thu, 13 May 2004 09:53 Go to previous message
you have to pull apart as the o ring is at the end where it is leaking where the 2 nuts bolt up 2
Previous Topic:4AGZE LSD
Next Topic:Hilux Diff Center Photos Required
Current Time: Sat Oct 24 16:18:12 UTC 2026
Total time taken to generate the page: 0.0049471855163574 seconds
