Toymods » Tech & Conversions » smoking if hold revs at 3k
haydennz
smoking if hold revs at 3k Thu, 13 May 2004 08:08 Go to next message
Ok, i tried a few tests trying to solve this smoking problem on my 3tgte.
If i rev the engine and hold it at 3000-4000rpm while stationary, i will see no smoke untill its been revving at 3000-4000rpm for atleast 10secs
compressions are fine ~145psi x4, it also smokes under hard acceleration
valve stem seals? however its a turbo car and does the pressure while on boost stop the valve stem seals from leaking?
celicaboy
Re: smoking if hold revs at 3k Thu, 13 May 2004 09:49 Go to previous messageGo to next message
it can be a few things....
could be turbo... when it boosts it will blow oil past the seals.... if it was your valve seat seals you wouldnt have much comrpession if it was bad it would only puff out a likl when you first rev it then nuffin .... it could be ya rings are warn out or ont heyre way or blowby .. symptons of blowby is warn out rings or blocked pcv valve can be one of those
HighRolla
Re: smoking if hold revs at 3k Thu, 13 May 2004 10:08 Go to previous messageGo to next message
If your valve stem seals are worn your compression is usually ok isn't it? So could still be valve stem seals, but thats usually after coasting or idling then hitting accelerator.
Sounds strange Shocked
[Updated on: Thu, 13 May 2004 10:10]
CLG
Perth, Western Australia
Re: smoking if hold revs at 3k Thu, 13 May 2004 10:10 Go to previous messageGo to next message
Oil past the turbo seals usually shows itself up on liftoff, with smoke then, I'd say it will be engine related, but hard to diagnose not having seen or tested the car.
RWDboy
Re: smoking if hold revs at 3k Thu, 13 May 2004 10:45 Go to previous message
Could be blown oil rings...compression rings don't have to be gone and you can still get good compression and blow oil at the same time.
Previous Topic:4AGE Complete Seal/Gaskit Kit Toyota vs Repco
Next Topic:Engine oil cooling for turbo 7mge...
Current Time: Mon Oct 26 14:21:08 UTC 2026
Total time taken to generate the page: 0.017838954925537 seconds
