Toymods » Tech & Conversions » White smoke
celicaboy_2000
Lismore, NSW
White smoke Thu, 13 May 2004 10:44 Go to next message
When the car is hot and been idling for a few minutes white smoke starts blowing out the exhaust what could the cause of this be? Im thinking turbo oil seal?
Danners
Central Coast, NSW
Re: White smoke Thu, 13 May 2004 22:08 Go to previous messageGo to next message
White smoke = steam/water
Blue smoke = oil
Have you blown a head gasket yet? Confused
Dan
SoarerFury
Re: White smoke Fri, 14 May 2004 07:20 Go to previous messageGo to next message
...its stuffed.. Very Happy
i got a blown HG, its great! Sad
dingaling
tas
Re: White smoke Fri, 14 May 2004 07:29 Go to previous messageGo to next message
If it's anything like my supra it will just be water in the tailpipe.
Where i live it gets pretty cold and damp during the night, and after a few days there is literally a litre or more of water sitting in the tailpipe, it all seems to catch in the cat converter.
I'll start the car, a puff of blue smoke will come out (just the valve seals, nothing major) then after abit of warming up the white smoke/steam will come pluming out, becuase the exuast heat is evaporating the water that's in there. A good 30min drive gets rid of it all and there is no visible smoke after that.
Usually takes a couple cold nights for it to happen again. I'm thinking off plugging the exuast up during these cold nights.
mick
toowoomba qld
Re: White smoke Fri, 14 May 2004 07:39 Go to previous messageGo to next message
yeah my camry does the same thing every now and again on a very cold morning as it is usally parked out side but after driving if for a while the white steam/smoke goes away
celicaboy_2000
Lismore, NSW
Re: White smoke Fri, 14 May 2004 13:15 Go to previous messageGo to next message
Maybe its a blueish sort of smoke. Im not loosing any water so I dont think its a blown HG "Better not be only done 200km on the existing HG". What could cause the blueish smoke? Motor has just been rebuilt.
mick
toowoomba qld
Re: White smoke Fri, 14 May 2004 13:28 Go to previous messageGo to next message
If its blowing a blueish smoke Its usually worn or damage valve stem oil seals you can check to see if this is it by letting the car idle for a few minutes and then open the throttle if oil is getting past the valve steams a heavy discharge of blue smoke will be seen at the tailpipe but can't understand why this would be the case if its just been rebuilt? Confused
SillyCar88
Elwood, Melb
Re: White smoke Fri, 14 May 2004 14:20 Go to previous messageGo to next message
Recently my cars been puffing out white smoke, because lately its been pretty cold in melb. at night.
But a good way to differentiate between these two is:
White smoke evaporates quite quickly into the air,as it is water vapour.
where as
Blue smoke tends to hang around a while, is quite condensed and smells like shit.
Hope that helps Smile
Re: White smoke Fri, 14 May 2004 14:25 Go to previous message
easy way to tell is smell the smoke.. sure it's not bad if you do it all day, but you can quickly tell if it's water or oil smoke...
if it smells like a KB laser, it's oil Razz
Previous Topic:Header clearance 4age ae86
Next Topic:wheels
Current Time: Fri Nov 20 10:29:08 UTC 2026
Total time taken to generate the page: 0.0067939758300781 seconds
