Toymods » General Car Talk » mesauring tools
Flem
cambo
mesauring tools Thu, 13 May 2004 11:37 Go to next message
inm need of some measuring tools must be quality with good accuracy (the only stuff i can find at the moment is accuracy of 0.01.) locations and brands anyone.... oh its for rebuilding a engine. anyone herd of yuassa ? where can i get the products from ?
Jayem
Finland
Re: mesauring tools Thu, 13 May 2004 21:19 Go to previous messageGo to next message
Mitutoyo is affordable quality IMHO.
Digital vernier caliper is handy and accurate enough in most cases.
EVOSTi
cambo
      no
Re: mesauring tools Sun, 16 May 2004 10:06 Go to previous messageGo to next message
what are you talking bout? telescopic guages, inside/outside micrometers?
clubagreenie
1st street on the right
Re: mesauring tools Sun, 16 May 2004 10:32 Go to previous messageGo to next message
Well for an engine you'd need internal and external micrometers, verniers, plastigauge, feeler gauges for starters.
Accuracy comes with price. Good tool stores will have a variety and should push more expensive products without valid explanation. Ask questions like why should I pay more.
And if the recommend a cheaper product over a more expensive, take note as they probably won't make as much but are recommending to your needs, value for money vs build quality/accuracy.
YelloRolla
On your mum!
Re: mesauring tools Sun, 16 May 2004 10:35 Go to previous messageGo to next message
Regardless of which measuring tool - quality will come from the following brands Mitutoyo, Starret, Moore & Wright, Mercer and Rabone Chesterman (to name a few).
kingmick
Banned by his request
moved to tamworth
Re: mesauring tools Wed, 19 May 2004 06:30 Go to previous messageGo to next message
you must be using all studs and billet caps, had the tunnel line bored, the bores done using a deck plate, crack tested the block. test fit about ten times, hand blended the pistons,linish the crank. Smile do the above before you need to get to mega accurate as you cant if its not done.
mick
ed_ma61
Lost in the K hole
Re: mesauring tools Wed, 19 May 2004 06:50 Go to previous messageGo to next message
kingmick wrote on Wed, 19 May 2004 16:30
and as the machine shop is going to be doing all this ^^^^^ work, you can pretty much leave measurement and blueprint tolernces in their hands.
plastigauge, verniers, and feeler gauges should get you through the rest of the build ok. (unless you start getting fancy, and doing your own deck height calcs, checking valve guides etc). it realy depends how much you expect to do yourself, and how much youre prepared to relinquish control to the machinist.
EVOSTi
cambo
      no
Re: mesauring tools Wed, 19 May 2004 11:13 Go to previous messageGo to next message
well hes a mech so... Smile if i were going a full engine rebuild on my own car i would def be checking the guides, bores and allignments just so you can tell the machinist what you want done rather than just give it to them and say fix whats needed.
Flem
cambo
Re: mesauring tools Sat, 22 May 2004 03:27 Go to previous messageGo to next message
im looking for tools with a better accuracy of 0.001in , ive managed to get half a machine shop at a mates uncles joint(backyard shop) Very Happy , hes a machinist !!!!!!!!!!!!!!!!!!!!!!1 mitouyo hasnt got a good enough accuracy . whats the best tempurature at measuring 22deg cel?
evo sti im nota mechanic im a service technition or a automotive parts fitter Rolling Eyes bloody dealership mecahics. Very Happy
EVOSTi
cambo
      no
Re: mesauring tools Sat, 22 May 2004 10:10 Go to previous messageGo to next message
bwarhaha i miss the days of beeing a dealership mechanic/bludger Laughing Laughing Laughing
YelloRolla
On your mum!
Re: mesauring tools Sat, 22 May 2004 10:44 Go to previous messageGo to next message
1 mitutoyo what doesn't do sub .001"? If you are trying to measure at less than 1 thou - then you will most likely need a micrometer. Measuring at less than .001" with a vernier is a little haphazard unless you do it all day and you have good eyesight. Micrometers are certainly available to .0001" (or 1/10th thou) from Mitutoyo.
Even a micrometer that doesn't measure in 10ths can still be use to very good effect because of the spacing of the graduations. Do the homework, shop at specialist machine tool measuring equipment shops and get educated face to face by people who know what they are talking about.
There were other names mentioned as well - Starrett or Moore & Wright. If you are after a dial indicator, I will recommend Mercer or Seiko, again all to .0001".
You still have not yet stated what tools that you are after - you have merely mentioned the required accuracy.
Flem
cambo
Re: mesauring tools Sun, 23 May 2004 01:10 Go to previous message
that is correct i did not state which tools i need, as im in need of the whole lot so yes i would be needing a mic i was more interested in brand but it seems theres only a few that know otheer brand names such as yourself which means i will be looking for the brands which u recommend thanking you all for for time and effort esp yellow rolla. Very Happy unfortunatly over at combo we dont have any machine shops that sell measuring tools that i konw off well not the ones that im looking for. oh i got i norbar torgue wrench Very Happy ( i got a digital verniers too.)
[Updated on: Sun, 23 May 2004 01:11]
Previous Topic:4WD with a difference
Next Topic:RTA Vehicle inspection...
Current Time: Thu Nov 19 19:25:29 UTC 2026
Total time taken to generate the page: 0.034304141998291 seconds
