Toymods » Tech & Conversions » RA23-28 or 22 Struts
GIN51E
Berowra-Sydney
RA23-28 or 22 Struts Tue, 27 August 2002 22:13 Go to next message
ok well as some of you may know i have a RA23 but it has 28 struts in the front and was wondering if someone could tell me the difference between the 23 and 28 struts for example are the 28 struts higher then the 23? as i want to know weather i should put 23 struts back in or not.
anyway whats better 23 or 28 struts in a 23?
[Updated on: Sat, 31 August 2002 06:52]
Re: RA23-28 Struts Tue, 27 August 2002 23:21 Go to previous messageGo to next message
They're both exactly the same.
GIN51E
Berowra-Sydney
Re: RA23-28 Struts Wed, 28 August 2002 00:49 Go to previous messageGo to next message
if they are both exactly the same then why doesn't RA23 shocks fit in?
Re: RA23-28 Struts Wed, 28 August 2002 01:54 Go to previous messageGo to next message
Can't think of a reason why they wouldn't fit. Are you sure they're RA23 shocks? TA22 struts are different to RA23/28.
GIN51E
Berowra-Sydney
Re: RA23-28 Struts Wed, 28 August 2002 02:00 Go to previous messageGo to next message
well when my brother got the car it had been lowered 2inches off the ground so we had to chuck springs in it to get it registered then when he went to change the shocks the front shocks wouldn't fit in, took it to a suspension place and apparantly it had different struts so the ra23 shocks didn't fit, maybe he is wrong as it was a fair few years ago so maybe its 22 and not 28's if it is 22's then whats the difference between them and 23? as i want to know if i should put 23's back in as i think the front might be a bit higher then the back.
is there a way i can check the struts to know what ones they are?
Shteeve
near chris and murray vic
Re: RA23-28 Struts Thu, 29 August 2002 01:49 Go to previous messageGo to next message
apparently the difference between 22-23 is an inch or two right up the top.....
GIN51E
Berowra-Sydney
Re: RA23-28 Struts Thu, 29 August 2002 02:08 Go to previous messageGo to next message
meaning the car would be higher with 22 struts then it would be if it had 23?
GIN51E
Berowra-Sydney
Re: RA23-28 Struts Sat, 31 August 2002 06:53 Go to previous messageGo to next message
Rolling Eyes
tanman
Re: RA23-28 Struts Sat, 31 August 2002 07:08 Go to previous messageGo to next message
I have owned 22's and 23's the 22 stuts are shorter and have smaller brakes.
GIN51E
Berowra-Sydney
Re: RA23-28 Struts Sat, 31 August 2002 07:31 Go to previous messageGo to next message
ok so if i put 23 struts back in that would raise the front, well i won't be doing that then thanks mate.
tanman
Re: RA23-28 Struts Sat, 31 August 2002 07:46 Go to previous messageGo to next message
Just get the oxy out and cut the springs!!!!!!!!!!!!!!!!!!
Re: RA23-28 or 22 Struts Sat, 31 August 2002 09:16 Go to previous messageGo to next message
You can put RA23 struts in a TA22, but you have to cut off the spring supports and re-weld them lower on the strut to match the TA22 strut. I think there's a web site somewhere which has details on this procedure, but I can't remember where it is... do a search and you might find it.
GIN51E
Berowra-Sydney
Re: RA23-28 or 22 Struts Sat, 31 August 2002 10:08 Go to previous messageGo to next message
no i have a RA23 but ra23 shocks don't fit in the front i therefore thought it had 28 struts in it but then found out they are the same as 23 struts so then worked out my car must have 22 struts in it, i wanted to know the difference between the two as if my car does have 22 struts in it if i then put 23 struts back into it then would the front then be a little lower but i have been told that 22 struts are shorter then 23 struts so i will therefor leave the 22 struts in it as i don't want the front any higher.
gee's that gets confusing Freak
Re: RA23-28 or 22 Struts Sat, 31 August 2002 13:23 Go to previous messageGo to next message
Uh... your car is an RA23, so RA23 struts will definitely fit! Where's the problem? I must have missed something here...
Classique71
Colac, Victoria
Re: RA23-28 or 22 Struts Sat, 31 August 2002 13:38 Go to previous messageGo to next message
dude, tske a DEEEEEP breath - and explain it SLOWLY to the nice norbie!!!
Rolling
GIN51E
Berowra-Sydney
Re: RA23-28 or 22 Struts Sat, 31 August 2002 15:46 Go to previous messageGo to next message
ok, hmm lets see if i can get it right this time.
my car is a RA23, when we first bought the car it was lowered to the point where it only had two inches ground clearance, we then chucked standard springs back in to get registered, then one day my brother went and bought 4 new shocks for the RA23, but couldn't get the front shocks in, so took it to a mechanic and they discovered that it doesn't have RA23 struts in the front, so they then put in the correct shocks.
my brother thought the guy said it had RA28 struts instead of RA23 struts, but as i have found out in this forum the 28's and 23's have the same struts, so therefore they must ben 22's struts in the front, and what i wanted to know was what the difference was between the 22 and 23 struts is. as i feel the front of the car is a little higher then it should be so i was wondering if its the 22 struts that are making it higher then i should go and get some RA23 struts and put them back in to lower the front down a little bit. but then i've been told that 23 struts are higher then 22 struts so if thats the case then i wont bother puting 23 struts back onto it.
in a nutshell..... will the front of my car be lower or higher if i put RA23 struts back onto it instead of the 22 struts that are on it now, keep in mind my car IS a RA23.
make anymore sense? i'm starting to confuse myself
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: RA23-28 or 22 Struts Sat, 31 August 2002 16:02 Go to previous messageGo to next message
The ride height all comes down to what spring you use. The RA-23 struts will fit fine with the correct springs (and shocks) and one difference between the TA-22 and T/RA-23/8 is the TA-22s stub axles are smaller, so they wouldn't be as strong.
Which, I just realised, also means you must be running TA-22 discs & calipers (if the struts are TA-22s) because a '23 hub won't fit on a '22 stub axle, and I doubt the calipers would bolt up either.
I say get those RA-23 struts back in, there is absolutely no good reason to be using TA-22 struts in an RA-23. If the car sits higher, get some new springs.
GIN51E
Berowra-Sydney
Re: RA23-28 or 22 Struts Sat, 31 August 2002 16:58 Go to previous messageGo to next message
but i have changed the brake pads and asked for RA23 pads and they fit in spot on.
i have no idea whats going on, what has been changed and so forth all i know for sure is RA23 shocks don't fit in the front. due to different struts
if someone can tell me of things to meassure and check and so forth i'll jack the car up and take a look then maybe work out whats actually in there
[Updated on: Sat, 31 August 2002 17:01]
BigWorm
Turramurra, Sydney.
Re: RA23-28 or 22 Struts Sun, 01 September 2002 00:12 Go to previous messageGo to next message
Are you 100% sure they were definitely RA-23 shocks?
GIN51E
Berowra-Sydney
Re: RA23-28 or 22 Struts Sun, 01 September 2002 00:18 Go to previous messageGo to next message
yeah well thats what we bought and couldn't get them to fit then a mechanic put different shocks in, we still have the two new front shocks thats why i wouldn't mind swaping the struts over as i already have new shocks to put in.
RA23_Sean
Western Sydney
Re: RA23-28 or 22 Struts Sun, 01 September 2002 00:43 Go to previous messageGo to next message
They wouldn't be Corona struts would they? Aren't they supposed to be higher than Celica struts?
BigWorm
Turramurra, Sydney.
Re: RA23-28 or 22 Struts Sun, 01 September 2002 00:52 Go to previous messageGo to next message
Coronas are the same as '23 celicas, only different caliper brackets.
How do the '23 shocks not fit, are they too long or too wide?
And just because the guy in the shop says they are '23 shocks, doesn't mean they are, people do make mistakes.
GIN51E
Berowra-Sydney
Re: RA23-28 or 22 Struts Sun, 01 September 2002 01:16 Go to previous messageGo to next message
i have no idea all this happened 5 years ago when my brother had the car and did the suspension. and he can't really remember a thing,
ok when shock is fully compressed its 44cm long
when shock is fully out its 65cm long
shock body has a diamiter of 4.5cm
that is meant to be a RA23 shock for the front which did not fit into the car.
now someone can tell me if that is the size of a ra23 shock
tanman
Re: RA23-28 or 22 Struts Sun, 01 September 2002 02:52 Go to previous messageGo to next message
You say that it uses 23 brakes. Measure the rotors and make sure. Its sounds to me like it is just the replacement shocks which are wrong. Measure the length of the strut body as well.
GIN51E
Berowra-Sydney
Re: RA23-28 or 22 Struts Mon, 02 September 2002 07:52 Go to previous messageGo to next message
ok well the disks are 280mm strut diameter is 51mm when i measure the length of the strut from what point do i measure?
from the very base of it where it bolts on? to the highest point or to where it gets to the spring support? also would i be correct in saying that the strut is the part which the shock slides down into?
also away off the point but on the inside of the disk there is a metal plate that covers the disk, is this easy to remove and could i drive around without it? as i was thinking if i took that off then it would get much better cooling.
tanman
Re: RA23-28 or 22 Struts Mon, 02 September 2002 08:01 Go to previous messageGo to next message
280mm rotors? no australian celica or corona has ever run front rotors of that size.
GIN51E
Berowra-Sydney
Re: RA23-28 or 22 Struts Mon, 02 September 2002 08:19 Go to previous messageGo to next message
diamiter 280mm plus or minus a little as its hard getting an exact measurment. how big are they meant to be?
tanman
Re: RA23-28 or 22 Struts Mon, 02 September 2002 08:39 Go to previous messageGo to next message
RA23/28/40 254x12.7 soild
73-83 corona have 266x12.7
are you rotors soild or vented?
BigWorm
Turramurra, Sydney.
Re: RA23-28 or 22 Struts Mon, 02 September 2002 09:22 Go to previous messageGo to next message
Can you take a photo of your brakes for us?
GIN51E
Berowra-Sydney
Re: RA23-28 or 22 Struts Mon, 02 September 2002 09:35 Go to previous messageGo to next message
ummm i might be able to find someone with a digital camera. i'm pretty sure they were 280mm i couldn't of made that big a stuff up but when i get a photo i'll remeassure them again.
did the GT models ever come out with larger discs?
but i will check them again to make sure they are 280mm hope i didn't make an all time stuff up,
they are solid
[Updated on: Mon, 02 September 2002 09:49]
GIN51E
Berowra-Sydney
Re: RA23-28 or 22 Struts Mon, 02 September 2002 10:00 Go to previous messageGo to next message
is there anything else you guys want me to meassure while i've got the wheels off tomorrow? should have a pic up tomorrow night
rob_RA40
c'town, NSW
Re: RA23-28 or 22 Struts Mon, 02 September 2002 11:22 Go to previous messageGo to next message
see if they are solid or vented while your at it.
Re: RA23-28 or 22 Struts Mon, 02 September 2002 12:20 Go to previous messageGo to next message
GT Celicas didn't have bigger brakes. If they really are 280mm you'd need at least a 15" rim to clear them. My Supra has 258mm brakes and they only just fit inside the 14's!
GIN51E
Berowra-Sydney
Re: RA23-28 or 22 Struts Tue, 03 September 2002 02:27 Go to previous messageGo to next message
i've got 13's on mine Razz
i'll re check it but i think it was 280 unless i have to learn how to use a tape measure again Embarassed
but i'll check.
GIN51E
Berowra-Sydney
Re: RA23-28 or 22 Struts Tue, 03 September 2002 08:43 Go to previous messageGo to next message
ok well does anyone know of a place that teaches you how to use a tape meassure? its hard trying to measure them because of the bearing cap and everything in the way i couldn't line it up very well but friend did it and claims its near 254mm around that so i think my eye's are farked, but the measurment of the disc thickness is 12mm no where near 12.7mm and i used verniers for that, but maybe they have been machined in there life sometime. also couldn't get a photo as the camera wasn't at his house but don't think you need a pic anymore
[Updated on: Tue, 03 September 2002 08:45]
rob_RA40
c'town, NSW
Re: RA23-28 or 22 Struts Tue, 03 September 2002 09:28 Go to previous messageGo to next message
RA23/28/40 disc is 254mm diam, 12.7mm max width 11.5mm min width
Alainve
Newcastle NSW
Re: RA23-28 or 22 Struts Wed, 04 September 2002 09:09 Go to previous messageGo to next message
what type of 13 inch rims are they? if they are stockies then they wont fit over the RA23 brakes. Because i had a wrecked 23 and tried to put a 13 on it to roll it around and it didn't fit. Confused the caliper fouled on the inside of the rim.
The RA23 strut is 430mm long from retaining plate to the mating plate on the bottom, and 360 from the mating plate to the top of the spring lands. Cool
GIN51E
Berowra-Sydney
Re: RA23-28 or 22 Struts Wed, 04 September 2002 10:57 Go to previous messageGo to next message
http://www.planet.net.au/~gins/wheel.jpg
but they are now gold of course Very Happy
i'll measure the struts tomorrow should be able to get to them simply by having the wheels at full lock.
Re: RA23-28 or 22 Struts Wed, 04 September 2002 11:57 Go to previous messageGo to next message
Yeah, I tried putting 13" wheels on my RA23 once and it wasn't going to happen. It sounds like you've got TA22 or TA23 struts dude!
GIN51E
Berowra-Sydney
Re: RA23-28 or 22 Struts Wed, 04 September 2002 22:23 Go to previous messageGo to next message
and whats the difference between the TA struts vs RA
also i've got washers on the studs, this may be whats giving the wheels the extra clearence?
[Updated on: Wed, 04 September 2002 22:24]
TOY77
Re: RA23-28 or 22 Struts Thu, 05 September 2002 03:34 Go to previous messageGo to next message
Mate,
that sounds dodgy as! as i told you i think you will find that 13 in wheels are illegal on a 23.... as probly are your washers.... not to mention dangerous... you have to wonder why someone would swap to what you have...
you have my email, talk to me, i have everything you need to fix it back... bar shortened springs....
Stew
GIN51E
Berowra-Sydney
Re: RA23-28 or 22 Struts Thu, 05 September 2002 03:39 Go to previous messageGo to next message
i don't think it is illegal, i thought you could up or down 2inches in rim size plus no one ever says anything when its registered or cops or tyre place, when we first got it as i said earlier it was 2inches ground clearance and 13's were up in the guards it was that low.
Alainve
Newcastle NSW
Re: RA23-28 or 22 Struts Thu, 05 September 2002 09:49 Go to previous messageGo to next message
its illegal to have the washers on the studs. As the rta put it its illegal to use loose spacers on your wheels between the hub and rim. and effectively they are loose spacers.
but i think its ok to go down in rim size but why would you downgrade? No No No
GIN51E
Berowra-Sydney
Re: RA23-28 or 22 Struts Thu, 05 September 2002 10:37 Go to previous message
i don't know why you would downgrade they are just what came with the car, we have had it for like 6 years now and its had those spacers the whole time and never had anyone comment on it so oh well who cares and when is a cop pulling me up and asking me to take a wheel off????????
Previous Topic:4agze into ta22
Next Topic:1jz question
Current Time: Thu Oct 29 14:43:39 UTC 2026
Total time taken to generate the page: 0.0089640617370605 seconds
